Stubborn ghosts - the old mower finally? Defeated me
Discussion in 'Chainsaws and Power Equipment' started by cnice_37, May 15, 2015.
  1. cnice_37
    cnice_37
    You may have seen that I bought a new mower.
    I was sure the old one had a bad starter. I figured it was a cheap fix so I would give to a friend or sell for cheap on CL.
    Tonight I fought that thing for 2 hours. New starter was not a fix.
    Symptoms are the engine won't turn over much past one revolution. This is the same on both starters. This is the same whether on battery, jumping battery off my running car, bypassing solenoid entirely (removed from circuit completely), and jumping straight to starter post and grounding on the block. I also tried a jump pack before the car.
    It's like an electrical gremlin except I don't see how it can be once I am down to the block and starter.
    Any ideas? 15hp Briggs on a Craftsman rider
    HDRock likes this.
  2. rookie1
    rookie1
    Overhead valve engine ?
    MasterMech likes this.
  3. cnice_37
    cnice_37
    Yes, single cylinder OHV
  4. rookie1
    rookie1
    You have too much valve lash and the compression release isn't working properly.
    MasterMech, pappy88, old 040 and 2 others like this.
  5. cnice_37
    cnice_37
    Well might as well make this my guinea pig for learning how to adjust valves.
  6. rookie1
    rookie1
    Lol. Easy peasy. I think it's .005 intake and .007 for the exhaust. Take off the sheet metal and get to the valve cover and pop it off. Some oil will leak out. I'd pull plug so you can turn over easy and get followers on low side of cam.
    For the heck of it see how far out the lash is right now. When your done you can spin over slow by hand and see the exhaust rocket arm bump just a little bit to bleed compression on the compression stroke.
    HDRock and cnice_37 like this.
  7. Horkn
    I had to do the valve adjust on my 16.5 HP Briggs ohv single in the mtd mower tractor when I had to put a new head on her . It was simple.
    HDRock likes this.
  8. mijdirtyjeep
    mijdirtyjeep
    Muskegon MI
    This is how I bought my JD la115 for $50. Guy thought it had a blown engine. I ended up needing to put a new push rod in "$8.00", on the intake side as it was bent from not doing the valve adjustment. The factory uses an aluminum push rod on the intake and a steel push rod on the exhaust side. They are both the same size so I put a steel one on the intake. I hit the key and she fired right up. Have not done a dang thing to it but change the oil, and this wil be my fourth year with it.
    blsnelling, raybonz and cnice_37 like this.
  9. old 040
    old 040
    Buckeye State
    i've found that .004 on both rockers works every time, though there was a small time frame where briggs had issues issues with the cam/compression release on some of these ohv engines.............may also want to make sure the engine is solidly grounded as well as the battery to frame...........
    MasterMech and cnice_37 like this.
  10. basod
    basod
    Mount Cheaha AL
    Pull the plug and try to crank over before going into the valves.
    seen a few hydro locked from tipping during oil changes
    old 040 likes this.
  11. old 040
    old 040
    Buckeye State
    or gas in the crankcase/cylinder..............
    cnice_37, basod and Kg461 like this.
  12. cnice_37
    cnice_37
    It won't spin with the plug out. My suspicion is the valves are out but I fried the solenoid in the process of "figuring" this out. Solenoid is clickety clacking like crazy while engaged.
    I should have asked sooner. Someone will get a deal like mijdirtyjeep !
    Oh, and to top it off, the rear axle is now locked up, like the parking brake is engaged but it isn't. One more thing to fix before it goes. This thing is like a jealous ex-girlfiend; next thing you know I am gonna wake up tomorrow morning and my car is keyed.
    I'll offer it the classifieds for Karma for a week here first.
    basod and raybonz like this.
  13. basod
    basod
    Mount Cheaha AL
    clicking solenoid sounds like a poor ground or faulty safety switch interrupting the circuit.
    If you test voltage to the solenoid with wire removed to ground key turned to start you should have exactly what the battery reads from positive to negative post.
    With the plug removed so it won't start in neutral :
    use a jumper cable attached to starter post + and touch it to battery + (it will arc) have a meter across the battery it might read 12V but with the starter load it will probably drop to 4V which will also cause a solenoid to chatter.
    Do you have any of the other safety switches jumpered out?
    Stinny likes this.
  14. Greenstick
    Greenstick
    A fine adjustment of 10 pounds of tannerite placed just below the deck and a tweek with a rifle as a activator and it will be tuned to perfection.
    basod and cnice_37 like this.
  15. basod
    basod
    Mount Cheaha AL
    I wonder if that isn't the cause of the engine not turning over?
  16. old 040
    old 040
    Buckeye State
    the brake lever on these (and others) like to stick, reach under the rear of the trans and find where the brake lever is, pull back on it, i'll bet it will release..............
    rookie1 and cnice_37 like this.
  17. MasterMech
    Whew.... What a wreck! Ever since Craftsman switched to MTD as their supplier, their lawn tractors have been J-U-N-K.
    Many valid points here. Briggs had a ton of problems with the compression release mechanisms on these. Hold the intake rocker against the cam while turning the engine over. If you don't feel a tiny "bump" when the piston approaches TDC on the compression stroke, you have a problem.
    Checking for bent pushrods is also prudent.
    The rapid fire solenoid thing is usually a weak battery or bad ground. Use a jump pack and/or jumper cables to diagnose. Use the jump pack on the battery, if it cranks fine/no clicking, then it's the battery. Use the cables to connect the engine block directly to the negative terminal of the battery. If that solves it then you have a bad ground.
    cnice_37 likes this.
  18. cnice_37
    cnice_37
    Nah that just happened as I pushed it across the yard to jump off the car.
    It's going on here first for free, then CL for parts. And if nothing then I will revisit all these good suggestions. I have cut my teeth learning small engine repair on this mower. I am sure I can get it running, but it won't fetch me much money in return so just a learning experience. Problem is time isn't on my side right now.
    MasterMech and basod like this.
