£~€×¡^$ fuel pump
Discussion in 'Everything Else (off topic)' started by Greenstick, May 8, 2015.
  1. Greenstick
    Greenstick
    Fuel pump krapped out on me today. 97 ram. How big a job is it to drop the tank n put a new one in. Anyone ever pop a hole in the tank and put on a 30$ napa electric fuel pump. Howdja seal a line into the tank with no leaks?:ithappened:
  2. pappy88
    pappy88
    Missouri
    A lot of times it's easier to take the bed off than drop the tank. The napa pump won't work right.
    Chvymn99, Bret Hart, wildwest and 2 others like this.
  3. Horkn
    Good luck, but yeah, it may be easier to take the bed off.
    Chvymn99 and wildwest like this.
  4. fox9988
    fox9988
    NW Arkansas 72717
    Take the bed off, its easy.
    ETA: You don't even have to pull the bed. Unbolt the bed,unplug the tail lights and unhook the filler hose it-then slide the bed back a few feet. The fuel neck is the worst of it and it ain't bad.
  5. wildwest
    I paid over $700 for a new one in my 1997 tahoe in 2003............
    Chvymn99 and Horkn like this.
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    Yep, definitely easier to pull the bed.
    Horkn and Chvymn99 like this.
  7. jetjr
    jetjr
    Pa/Md line
    I dropped mine using a motorcycle jack one time. Worked pretty good, but pulling the bed may be betterer.
  8. rookie1
    rookie1
    In the northeast here where we use salt on the roads cars rust pretty bad. My sons 97 Chevy 1500 needed a pump and it was easier to cut an access hole in the bed with a sawzall. All worked out because he has a tool box that covers it.
    fox9988 and Horkn like this.
  9. fox9988
    fox9988
    NW Arkansas 72717
    I had a '79 Ford work truck years ago, an old beater. I cut three sides and bent a flap up, in the bed, to unstop the fuel pickup. Before I got around to welding it back down, I had to bend it up and unplug the pickup 2 more times. Never did weld it.
    rookie1 likes this.
  10. Elderthewelder
    Elderthewelder
    Washington State
    I bought my son a used Hyundai Tucson a few weeks ago and was doing the brakes on it, started looking around for the fuel filter and could not find it in any of the normal places, Finally looked in the book and found they put the filter in the tank, I about came unglued, why would you put a filter that needs replaced in the fuel tank?. Than found that they put a access cover under the back seat to gain access to top of tank to pull filter and pump, still have to pull the back seat out though but better than pulling the tank
    rookie1 and fox9988 like this.
