Reminder - A Cleanout T is easier than not. See Pics
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, May 6, 2015.
  1. don2222
    don2222
    Salem NH
    This Enviro Meridian Insert did not have a Cleanout-T so it plugged up easier. The new close clearance Adapter-T has a built in stove adapter to fit in the back of the fire place insert exhaust flange and make the stove much easier to clean. Also if a small amount of ash builds up it will not choke the stove!
    Pic 1 - 4" liner connected to adapter to stove flange
    Pic 2 - Cleanout adapter T connected to Flex adapter to 4" liner[
    Horkn, IHATEPROPANE and wildwest like this.
  2. DexterDay
    A clean out T should be recommended in any install that goes vertical inside the house (liner, up and out, or straight up).
    savemoney and wildwest like this.
  3. Lousyweather
    Lousyweather
    agreed with above, unless the rigid pipe is too close to the floor, which would keep you from removing the bottom of the tee. Some pellet vent outfits (ICC) make a quick disconnect as well
  4. eatonpcat
    Mine has a quick connect with a cleanout.
  5. don2222
    don2222
    Salem NH
    Hello
    This Breckwell P22i is almost touching the floor, but I made the cleanout work! Made my job easier!
    Pic shows a 4 " Cleanout T with 3" reducer adapter and a 45 deg elbow with 4" flex adapter to 4" liner.
    Smokinpiney and wildwest like this.
  6. wildwest
    My tee is only a couple inches above the floor. I would do it differently if I ever did one again.
  7. don2222
    don2222
    Salem NH
    What would you do differently?
  8. Lousyweather
    Lousyweather
    might be seeing this wrong, Don, but by adding the extra 90 degree ell, you're increasing your EVL by another 5', and in many cases, might throw you over the 15' max
  9. wildwest
    Don, I do not have the know how, but I would like the bottom of my clean out tee high enough for me unscrew the cap easily, and put a bowl underneath the catch the chimney sweeping. It's a PIA to remove and replace the cap, and I am using plastic bag to catch the flyash below. Oh, the answer to your question would be, I would ask for suggestions here :)
    imacman and eatonpcat like this.
  10. jtakeman
    I have used 45º to tip the clean outs. May not get it off the floor, But should allow easier removal.
    One way to get the stove higher is to build a base to raise it up higher.
    Ol Donny should know all about that. And some tidbits about rope lights too. :D
  11. don2222
    don2222
    Salem NH
    Hi LW
    The diameter is 4" so EVL can be over 15 :)
  12. Lousyweather
    Lousyweather
    DexterDay and jtakeman like this.
  13. wildwest
    Could you elaborate on that more in womanspeak?
    jtakeman likes this.
  14. jtakeman
    It would look like this pic, But instead of the 90º which tips the tee level. The 45º would tilt the tee on a 45. Yet the pipe that connects to the tee would still be straight up the wall.
    How close is the tee to the floor?
  15. T-Stew
    T-Stew
    I just used a 90º elbow up out of the appliance adapter. The exhaust ports sit so low on these stoves I don't see how most are usable. No way I could get a brush in mine with only a few inches between the cleanout and hearth, and I pretty much have to disassemble to clean anyhow since I have another 2 90ºs where the pipe goes through the thimble so the pipe on each side of the thimble has to be cleaned separately. This setup has proven to be a pita and I'd like to do something different but don't want to drill another hole through the walls! So using the existing chimney.
  16. don2222
    don2222
    Salem NH
    It is almost touching the floor but now the stove is a breeze to clean! Easy Peasy!
  17. wildwest
    How about cleaning the pipe?
  18. don2222
    don2222
    Salem NH
    Oh yes, the flex rods go in all the way to the top!
