I went hunting for.................
Discussion in 'The Wood Pile' started by thewoodlands, Apr 30, 2015.
  1. thewoodlands
    thewoodlands
    some smaller wood since I don't think I'll have time for the bigger trees this spring/summer.
    I took a bunch of pictures which include Maple,Cherry,Beech and some Hemlock.
    I should have some time for this smaller stuff.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Is no. 55 too far gone? Looks punky all the way through
    wildwest, Drvn4wood, Eric VW and 3 others like this.
  3. Woodrat1276
    Woodrat1276
    Ky
    Small stuff adds up too
  4. Shawn Curry
    Shawn Curry
    Western NY
    Need a sawbuck? I know a guy... ;) :D
    wildwest, Drvn4wood, Eric VW and 4 others like this.
  5. Horkn
    Beech can get punky quick. 55 may or may not be ok yet. Hard to say until you cut a fresh slice.
  6. weatherguy
    weatherguy
    central massachusetts
    How do you take down 62, I have one in my neighbors yard but want to make sure I approach it right.
  7. bogydave
    Maple, cherry, beech & hemlock
    Sounds like a good line up to me :)
    wildwest, Drvn4wood, Horkn and 3 others like this.
  8. crzybowhntr
    crzybowhntr
    WV
    You should add the link to your sawbuck post in your sig??
    wildwest, Drvn4wood, Horkn and 2 others like this.
  9. Shawn Curry
    Shawn Curry
    Western NY
    I just dealt with a bunch of trees like that at my BIL's place. I knocked a lot of the limbs off first - you may or may not need to do that. Then I started from the top of the tree, where it was touching the ground, and started knocking blocks out, keeping an eye on the broken end in case it broke free. Out of 4 trees, one broke loose, the rest stayed attached. For those ones, I took enough blocks out to leave the broken end dangling off the ground, then I felled the stump in basically the same direction as the hanger. They looked a lot scarier than they ended up being. Stay Safe, and Good luck! :yes:
    wildwest, Horkn and Eric VW like this.
  10. Shawn Curry
    Shawn Curry
    Western NY
    I should add - there are a lot of variables to consider first. Size and species of the tree, the height of the break, etc. I have a poplar out back that I haven't dealt with yet. It's a 20 incher or so, and the break is about 35' up, so the dangling part is hanging almost straight down, and there's a lot of it. Id need to stand right inside the drop zone to trim the tops away to access the stump. I'm going to try pulling on that one to get it to break.
  11. thewoodlands
    thewoodlands
    I'm hoping once I start working towards the top it will get better, I've had them do that but it could be punky.
    wildwest, Shawn Curry, Horkn and 2 others like this.
  12. thewoodlands
    thewoodlands
    This wood I never got off the hill last year so I'll be rolling it down this week, some Sugar and Cherry.
  13. Horkn
    I hauled in a nice sized beech my buddy cut for my parents 2 years ago. It was simply let in the woods, not really off the ground. It was totally fine. No punk, no rot, even on the few that had dirt on the bark from laying on the forest floor.
    Hopefully you'll have the same results as me.
    thewoodlands, wildwest and Eric VW like this.
  14. Well Seasoned
    Nice job! Rolling downhill is a good method! :D
    thewoodlands and Horkn like this.
  15. Horkn
    I employed that method today too. :yes:
  16. thewoodlands
    thewoodlands
    After going in to see our family member this morning I hit the woods, I rolled this down and split it after the Cherry.
    milleo likes this.
