IS stove, wood scheme
Discussion in 'Modern EPA Stoves and Fireplaces' started by chucker, Apr 23, 2015.
  1. chucker
    chucker
    New York
    i take it the catalytic stoves burn differently from the secondary combustion stoves and that they thrive on low moisture content wood. i'm going to find out either way with the IS coming in june for next year's heat.
    this goes against a lifetime of wood burning experience. you would always want some dry wood when loading heavily, with wetter wood on the top, otherwise the whole thing would incinerate in short order.
    how do you handle your wood storage schemes, is it a two year rotation, or what, when do you cover, etc.
    this is a novel thing to get one's head around. i am already making provision for some extra storage space.
  2. Unhdsm
    Unhdsm
    Bradford, Vermont
    Not to reopen the debate but a lot of people say that cat stoves perform much better than non cat stoves with marginal wood:
    http://blog.woodstove.com/2012/01/catalytic-combustors-wet-wood.html
    As far as drying wood, I am a big believer in getting as much sun as you can. I tend to leave mine uncovered with airspace and as much access to sun and wind as I can, within reason.
  3. HDRock
    I top cover as soon as I stack it, try to get 3 years ahead "The 3 Year Plan"
    What stove were you running before?
    Gark, wildwest, fox9988 and 2 others like this.
  4. papadave
    Always a trade-off.
    I used an older air-tight stove for a few years, but knew right away that wet wood just doesn't do much.
    Any stove should run better with dry wood.....my old Ashley did, and so does the NC30.
    I'm with Unhdsm on the sun thing. I can get Oak down into the 20% and under MC level in just over 2 years when I stack in the sun and wind. More is better, but unless I cover it (which I don't do), it can start punkifying after about 2.5-3 years.
    I stack everything in an open field for as long as possible, then during the longest stretch of warm dry weather I can find (waiting for this weather can be a fairly long process), I load the shed with the oldest stuff.
    Experiment when you get the new stove, but I'll bet it'll burn at least a little better with dry firewood.
  5. fire_man
    fire_man
    North East MA
    I'm on a 4 year rotation plan - and yes definitely top covered after the first 6 months or so.
    My cat stove loves dry wood - burns slow and hot. I have uncovered one problem with what I believe is wood that is TOO dry.
    If I load the stove less than 1/2 way and choke it back too far, I get the perfect air/fuel ratio to produce a violent lid lifting, spark flying, smoke alarm inducing EXPLOSION due to the
    heavy outgassing. Full loads don't behave this violently, and neither do less dry small loads.
    burndatwood and wildwest like this.
  6. Fanatical1
    Fanatical1
    I have 3 - 4 year wood that is all very dry and have no issues with it in my IS stove. I can easily get 10 - 12 hour burns.
    I agree with be others that the sun helps with seasoning. I have both topcovered and not. Mostly topcover now.
  7. Backwoods Savage
    I do not think that is because of too dry wood. Instead, you are trying to burn a part of a load which means you don't want too much heat. Therefore, you cut the air back and the smoke cools before it gets to the top of the chimney. It sits there until an explosion forces it out but you get the benefits (?) of the backpuff. So even though you may not fill the stove all the way, you still have to give it good air at least for the first 1/2 of the fire. The smoke has to have enough air to force it out of the chimney.
  8. chucker
    chucker
    New York
    getting the last few burns out of a jotul 500 oslo. i may well go for the 3 year plan which sounds like a good thing.
    here's my setup and it makes a difference for moisture content. the stove is in the foyer with a floor to ceiling wood rack behind it against the wall. you walk in the door, turn, and the wood goes right there. the rack is divided into 3 spaces with one small space at the top for kindling and small splits.
    the wood is used in rotation so the stove has had an opportunity to bake on each area for a number of days before it's used. it's not a definitive answer for having the proper MC for a catalytic stove, it just helps and makes a difference.
    you guys are taking me to school with this. it's new territory.
  9. fox9988
    fox9988
    NW Arkansas 72717
    This is your best bet :yes:. Just keep adding to your stash until you are 1,2,3.... years ahead. If you can do it in one year, even better.
    Storing wood close to the stove for a few days will dry off surface moisture, but little else.
    papadave and HDRock like this.
  10. Backwoods Savage
    Okay, I'm trying to decide if this is legitimate or someone just trying to stir the pot. But, buying a new IS speaks well for sure.
    Now about that lifetime of experience. Never forget that it is easy for many to have 20 years experience, or so they say. But what they really have is one year experience 20 times. There is a big difference. We run into people constantly who think they know it all when it comes to wood burning. Funny thing is that most of them are just repeating what Grandpa told them so the go out in the fall, cut the wood then burn it that winter. Many times the wood is not even split until it is needed to put into the stove right then. Sorry, that has always been extremely poor practice. Yes, you can make it work but it will work poorly and you will do a lot of unneeded extra work.
    In the first place, we do not yet know how to burn water and until we learn how to do it, then we'll keep drying our wood before burning it. For those who think they have to put wet wood in a stove to "hold it down" and not burn too fast, they need to realize that wood will not burn much at all until that moisture is out. So put green wood in the stove and the first thing that has to happen is to evaporate the moisture so the wood will burn. Now when one realizes how much energy is required to evaporate the moisture, think of how much heat is lost in doing so. Would it not be better to burn all dry wood and keep all the heat you can in the house. You would not even have to cut as much wood every year because that dry wood will heat the home much better.
    But, won't the stove get too hot with dry wood? Well, that is one very good reason they put draft controls on a stove. Learn to use the draft controls to your benefit and you will be one very happy camper and the stove will work much, much better. In addition, no creosote!
    Here is some excellent reading. You can either read it online or download a PDF:
    http://firewoodhoardersclub.com/forums/resources/primer-on-woodburning-by-backwoods-savage.6/
    Please allow me to give an example of what dry wood can do for you. We purchased a Woodstock Fireview several years ago. Before that we had an old Ashley. With that Ashley, we cleaned our chimney 4-6 times every year and the stove never performed well. When we put the Fireview in, it was either 3 or 4 years before we cleaned the chimney and even then got maybe a quart of soot and fly ash.
    During this time we were burning wood that had been cut, split and stacked no less than 6 years with most of it being 7 years in the stack. With the Fireview, which is a cat stove, we immediately cut our wood needs in half! Rather than burning 6 cord per year, we found we needed only 3. But wait, there is more! With the Ashley, we were never warm in the winter. With the Fireview, we keep our home around 80 degrees all winter long; even on those -20 or colder nights.
    How do we handle the wood? We cut during winter then split in spring. Stacking comes immediately after splitting. We do not cover until late fall or early winter (before snow sticks). Then we top cover. This is important to only cover the top of the stack, else you lock in the moisture. Let air circulate through the wood to dry it and keep it dry. We like to use something solid when top covering and therefore use old galvanized roofing.
    In the photo below, the stacking was completed in early or mid April of 2009. We burned the last of that wood this winter. It was beautiful. It was about 96% white ash, 3% elm and 1% cherry. Notice that we just cut saplings in the woods, laid those down and stacked the wood on top of them. This keeps the wood off the ground and allows more air circulation.
    And sometimes we get a little snow but it does not bother the galvanized roofing. Some of the wood that is not in this picture but was to the right of this, was covered just with tarps. I believe that is the last time we used tarps. Also in this picture is our splitter, covered with a tarp and that covered with snow.
    We now are in the habit of moving enough wood for the winter into the barn so we don't have to mess with snow and ice.
  11. Backwoods Savage
    And good luck to you. Once you get onto the 3 year plan, you'll wonder why you didn't do it sooner!
    Incidentally, we took some of our 7 year firewood to the Woodstock factory and burned it in both the Fireview and Progress. Sweet!
  12. fox9988
    fox9988
    NW Arkansas 72717
    Why didn't I do it sooner? I ask myself the same question.
    I grew up burning the way grandpa did, it "worked" so why change. Now I'm 5 years ahead, burning in an efficient cat stove and life is so much better.
    Water doesn't burn.
  13. fire_man
    fire_man
    North East MA
    That makes some good sense, Dennis. But I'm not convinced yet. According to a well known Blaze King technical contact (I think you remember him) they did some testing on their cat stoves and found the following:
    "Our studies of this suggest that when burning fuel that is below 12%, it's not a bad idea to also load some 18% fuel. This typically fixes the issue."
    Let's not forget about Texas Boy - he burned bone dry ancient wood and had stove moving backpuff explosions.
  14. wildwest
    20+ years of burning extremely dry wood, never had a problem. I was under the impression any wet wood produces more creosote, and we never had more than built up flyash in our old home.
    Flash forward, the new to us home had a used and abused BKK, slammer install, and the second load of wood we bought was marginal. What a PIA! Then when we tore into things for a new stove with a safe install, it was clear that they burned wet wood in this poor thing since about the 1980's, what a $$ mess. I shudder now to think we burned it 24/7 from Oct -May that winter, somehow we did not have a chimney fire!
  15. JA600L
    JA600L
    Lancaster, Pa
    Cut lots of softwood to mix in. My silver maple seriously impressed me in the Ideal Steel. You will notice certain woods will do better than what you expect. For example my white ash seems to do better for me then the white oak. In my Quadra Fire that would not be the case. Grab any and all firewood types you can and be ready for a great performance.
  16. jeff_t
    jeff_t
    SE MI
    My thoughts....
    You will have a hard time getting wood 'too dry' on this side of the Mississippi, and possibly anywhere, for a properly controlled catalytic stove. I wouldn't hesitate to load my Blaze King full of anything. Moisture content or size of splits. Excessive draft or unusual weather conditions may play a role, but maybe not. My sister's BKK is on 26' of straight up pipe, and it has never overfired. It may somtimes burn hotter than desired and blow through a load faster than mine, but it's never gotten out of control.
    Non-cat stoves with unregulated secondary air can be a different story.
    What really dry wood does allow me to do is burn at an extremely low rate in the shoulder seasons, and still get clean, complete combustion. I don't notice much difference in the dead of winter, but 4-5 yo oak burns FOREVER in the spring and fall.
    Maina, Oldhippie, TurboDiesel and 6 others like this.
  17. wildwest
    x2
    jeff_t likes this.
  18. chucker
    chucker
    New York
    this is the kind of stuff i was looking for... the advantage in the shoulder season.
    i will find out when the IS gets used next winter. however. during cold weather and full time burning, the stove saves a LOT of wood as it can easily be rekindled at 14 hours and better. it would take less than 2 loads each day. it's just not a whole load of wood. then it will particularly sip in transition weather.
    interesting subject to say the least. i can't get to 4 and 5 year old wood but will set some extra storage space up and do what can be done.
    jeff_t, Backwoods Savage and papadave like this.
  19. My IS heats my home
    My IS heats my home
    Albany, NH
    As many have commented on with regards to the 3 year plan, this is my third season doing it and I have to say it works best for me and my situation. Once a year you have to replace what was burned the previous season and your good to go. Questionable wood such as oak can be put aside if more time is needed but I have found that 3 years is enough to get that under 20% mc as well.
    chucker , congratulations on your new IS! I don't think you'll be disappointed at all in the performance of this stove compared to your Oslo.
    I'll be curious to see what medallions and colors you chose.
  20. chucker
    chucker
    New York
    i went charcoal body with moss green fenders and door, no ash pan, no design cutouts, the top is smooth no inserts, no andirons. with the jotul 500 the ash pan was a PIA needing a glove or pot holder to use it and with the IS it seems to generate little enough ash as to not raise to an issue. plus one door seal gets eliminated. the progress was what originally caught my eye but in time the IS looked like the guaranteed simple plan so the simple theme is in effect.
    one downside is we have to get out to the flea market this weekend and search out an ash shovel. this as well as a shorter poker, we have this old coal stove poker that is incredibly long, something 30"-34" could replace it, or even down to 24". with these types of items vintage is preferable. our tools no longer fit the circumstance.
