compression tester recommendations
Discussion in 'Chainsaws and Power Equipment' started by Elderthewelder, Jan 24, 2015.
  1. Elderthewelder
    Elderthewelder
    Washington State
    can anybody recommend decent compression tester to use on my saw as well as a vehicle , under $50 would be nice
  2. millermodsaws
    millermodsaws
    I really like my lisle. What ever your get make sure it has the Schrader valve in the end of the hose.
  3. Jon1270
    Jon1270
    Pittsburgh, PA
  4. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Wow that is a good deal for an OTC tool
  5. crzybowhntr
    crzybowhntr
    WV
    I think the actron from advance auto is ok.
    w8ye likes this.
  6. w8ye
    w8ye
    Mansfield, Ohio
    I've had this one about 5 years and it has always worked perfect. I have compared it with other testers and got the same readings.
    Cut4fun and crzybowhntr like this.
  7. Elderthewelder
    Elderthewelder
    Washington State
    well it work on chainsaws as well as cars and trucks?
    here is one of the questions asked on Amazon
    What difference between this kit and OTC 5604 Motorcycle Compression Tester Kit?
    The spark plug adapters in this kit may not fit into a motorcycle or small engine. This kit is intended for car and truck engines that have bigger plugs. The OTC 5604 Motorcycle Compression Tester Kit are for small engines that have smaller plugs. So if you're testing a car or truck, get this kit. If it's something small like a motorcycle or boat engine or even a lawn mower engine, get the OTC 5604.
  8. w8ye
    w8ye
    Mansfield, Ohio
    My compression tester from Advance Auto had the 10mm adapter for the 550XP/562XP as well as the regular auto ones. The size I use the most is the short reach 14mm for the saws that use the BPMR6A spark plug
    Cut4fun likes this.
  9. Jon1270
    Jon1270
    Pittsburgh, PA
    The one I linked to works just fine on saws. Every saw I've worked on uses the shorter "standard" 14mm hose, which is included with this kit. I looked up the motorcycle kit, and it doesn't include anything that would make it better for saws. I think the guy who wrote than answer just likes to hear himself talk.
  10. pantelis
    pantelis
    Europe
    I never use a compression tester , i like to pull the muffler and see what hapend , the next video tell much more
    fox9988 likes this.
  11. mike bayerl
    mike bayerl
  12. fox9988
    fox9988
    NW Arkansas 72717
    Hmm, I didn't know a saw could have good compression with a badly scored piston.
  13. Cut4fun
    Cut4fun
    OHIO Redneck
    Jim didnt we test our comp testers to compare and my cheapie one and yours were dead on same?
    Been using this one for years from wallyworld.
  14. foragefarmer
    foragefarmer
    Central, Virginia
    Jon1270 how are you liking this tester? Mine has gone bad at a hose end and I am needing another one.
  15. Jon1270
    Jon1270
    Pittsburgh, PA
    I'm very happy with it.
    foragefarmer likes this.
