can't get chains to self feed..
Discussion in 'Chainsaws and Power Equipment' started by crzybowhntr, Apr 16, 2015.
  1. crzybowhntr
    crzybowhntr
    WV
    Like a new one does. I can get them sharp but I just can't them to where they self feed. If I dog in I can get clean cuts with little pressure. I've tried granberg, husky jig, stihl file guide, oregon file guide, and my timber tuff bench mount grinder. I go at 30° and have set the takers a tad lower than normal but no go. Someone help.... Using 7/32 and tried whatever stihl has that's close to 7/32.
  2. SquareFile
    SquareFile
    somewhere
    Do you have any pics of your cutters?
  3. mdavlee
    mdavlee
    Might be not enough hook on the cutter. File is riding too high.
    splitoak and concretegrazer like this.
  4. crzybowhntr
    crzybowhntr
    WV
    Let's see if this works.
    concretegrazer and DexterDay like this.
  5. SquareFile
    SquareFile
    somewhere
    They are dull
    splitoak, Sunfish, Moparmyway and 4 others like this.
  6. HittinSteel
    HittinSteel
    Wooster, Ohio
    I continue to struggle with the same problem.... Is the top plate dull shawn?
    Moparmyway and DexterDay like this.
  7. crzybowhntr
    crzybowhntr
    WV
    One more
  8. SquareFile
    SquareFile
    somewhere
  9. crzybowhntr
    crzybowhntr
    WV
    This was probably the worst chain to show you all. I'll get better pics of a chain I think should be good to go tomorrow and go from there...
  10. crzybowhntr
    crzybowhntr
    WV
    So, I need to get that back to fresh metal.
  11. SquareFile
    SquareFile
    somewhere
    Yes
    splitoak, DexterDay and clemsonfor like this.
  12. mdavlee
    mdavlee
    Yes. Edge isn't quite sharp. One or two more strokes will fix that. The corner point was blunt also.
    splitoak, CTYank, Sunfish and 4 others like this.
  13. Shawn Curry
    Shawn Curry
    Western NY
    And maybe the file is a tad low? Looks like a nice clean gullet, but the top plate should feel sharp like a knife.
    splitoak, DexterDay and crzybowhntr like this.
  14. clemsonfor
    The hook looks like it could be a bit more aggressive to me, more of an angle. But I also agree top looks dull.
    How did you measure the rakers? I have on gauge that is no where near the other when I check rakers. The new one is much bb
    Better and allows the chains to bite more.
    You can use the flat edge and feeler gauge thing but when checking every raker when lowering them its a two step process with a feeler and flat bar. Where as the gauge thing I got now I just throw it up there look and a few strokes of the file and a recheck and then move on.
    splitoak likes this.
  15. DexterDay
    I agree with the above. Ride the file higher, or a couple added strokes would have touched the top plate.
  16. mdavlee
    mdavlee
    6-7° is good for raker height also. set the chain up on a holder or bar and get a level section and check all of them there.
    Kg461 and Moparmyway like this.
  17. crzybowhntr
    crzybowhntr
    WV
    I use the Oregon raker checker thingymobob.
    splitoak and Shawn Curry like this.
  18. clemsonfor
    Maybe thats the same one I use? The one I use is countyline brand that I got at TSC. It sets over the chain and the raker protrudes through a slot. And came with a small flat file.
  19. crzybowhntr
    crzybowhntr
    WV
    Yes. I ditched the small flat for my old mower blade file. MUCH faster!
    mdavlee likes this.
  20. clemsonfor
    I thought the small file was way better. Showed me how dull my big bastard/flat files were!!! Ha
    crzybowhntr likes this.
