Logging "tree tops"
Discussion in 'The Wood Pile' started by dgeesaman, Apr 15, 2015.
  1. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Talking to someone about the neighboring property today - he mentioned that the woods there were selectively logged a couple of years ago and that they left behind tree "tops" that might be good firewood.
    Do these have the bulk to be good firewood and worth pursuing?
    I hate to sound spoiled but I still have a lot of heavy logs to cut as part of my instant 3 year plan. If I scrounge for tree tops it will slow down the log processing. But if the tops are good stuff and 2 years old it might be excellent to C/S/S now for next winter.
  2. Eric VW
    I personally like tree tops, but only down for a year, and can depend (for you) if they've been covered with leaves from autumn(s). That said, I'd still have a dissecting look at them, testing them for punkiness.
    splitoak, CTYank, Shawn Curry and 4 others like this.
  3. Locust Post
    I cut a lot of tree tops a few years ago.....loggers leave some pretty big stuff, some of it may be starting to go bad but I would guess you could still get some prime firewood out of there because a lot of the stuff is probably up off the ground on top of brush and other tops.
  4. Eric VW
    ^thats for sure!
    Drvn4wood, Horkn and Locust Post like this.
  5. haveissues
    haveissues
    Hudson Valley
    Tops are great IMHO. Don't need your big saws and the rounds are light so it is easy work and a lot of them are split once and on the pile. I'm guessing the wood is fine if cut a couple of years ago.
  6. Woodchuck
    Woodchuck
    Southeastern Ohio
    Working on tops right now. Best bang for the buck...all hardwood (Red Oak White Oak,Hickory) :dex:
    Here's a quick pic
    They average 12-18"diameter and are quick to cut :saw:
  7. Horkn
    Yep, tree tops from loggers are good stuff. Yes they can be a little more work than big rounds, but there's less processing to do once cut to length. A split or 2 and they are stackable, if not a cut and stack.
    I take branches down to about 3.5" most times, and this past year I took nearly everything, even down to a half inch for kindling to start my fire. I had enough wood without buying any.
  8. Woodchuck
    Woodchuck
    Southeastern Ohio
    I have access to a 70 acre tract that had been timbered two years ago. It is pretty fast and easy to get with the Kubota.
    I took a quick check with the MM just to see where it was....17% on the 10" stuff :thumbs:
  9. Horkn
    What kind of wood? Even maple should still be good at 2 years down.
  10. Woodchuck
    Woodchuck
    Southeastern Ohio
    With two saw running, my buddy and I cut a pickup load in less than 30 minutes.
    It would be more difficult without the tractor to pull the free
  11. Woodchuck
    Woodchuck
    Southeastern Ohio
    It has been about all Red Oak & White Oak, but there is some Shag Bark too
  12. Hellbent
    Hellbent
    North Central Kansas
    That looks like a magical land with rainbows and cotton candy clouds! Was that stuff cut above or below the chocolate waterfall? :faint:
  13. Horkn
    You are all good then.
    Drvn4wood likes this.
  14. Horkn
    You forgot the unicorn that poops out doughnuts.
    Jack Straw, Drvn4wood and gboutdoors like this.
  15. HDRock
    Go take a look , see what's there
    Cut a bunch 0f tops ,couple years ago , good stuff :saw: :tree: [​IMG]
  16. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Sounds like the Big Rocky Candy Mountains
    David
  17. Woodrat1276
    Woodrat1276
    Ky
    I would definatly go check it out. You might find a good mine of wood
    Horkn, Drvn4wood and gboutdoors like this.
  18. Gasifier
    Let us know how it turns out for ya. It won't take long to cut one truck load and see if you like the access part of getting to it, cutting it up and tossing it into truck, etc. :popcorn:
  19. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I doubt I can use my truck - I'm thinking about running my tractor over the ditch between our fields and working one bucket at a time.
    Horkn, Gasifier and Drvn4wood like this.
  20. haveissues
    haveissues
    Hudson Valley
    How about filling up your bucket and skidding some closer to your property at the same time?
    splitoak, Horkn, Gasifier and 3 others like this.
