Re-purpose a water pressure tank
Discussion in 'The DIY Room' started by Beetle-Kill, Apr 12, 2015.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Just had a few pressure tanks dropped off for scrap. 4'-5' tall, 22"- 28" diam.
    What can I make out these things ? Steel is good, bladders are bad so I was told.
    BBQ's ? Smokers? Large capacity tanks for my air compressor ?
    Ideas?
  2. XXL
    XXL
    Ontario, Canada
    I like the bbq and smoker ideas :yes:
    Horkn, wildwest and Beetle-Kill like this.
  3. Hellbent
    Hellbent
    North Central Kansas
    All excellent ideas! I usually end up cutting them in half for feed troughs. Extra air compressor storage is something everyone wishes they had. Maybe a giant portable air bubble if you don't have an engine driven compressor.
    Have you ever seen the wood powered pickup trucks? They call for two or three tanks about that size for the gasifier.
    I've also had kids turn them into snow plow blades for atv's
    Beetle-Kill and wildwest like this.
  4. jetjr
    jetjr
    Pa/Md line
    I'm going to have one soon to mess with as well.:popcorn:
  5. basod
    basod
    Mount Cheaha AL
    I can say 50cal handguns make holes in them;)
    Beetle-Kill likes this.
  6. Horkn
    Tanks for hydro fluid for a splitter?
  7. wildwest
    Were you able to diagnose the pressure bladder as the problem?
    Beetle-Kill and Horkn like this.
  8. basod
    basod
    Mount Cheaha AL
    way more volume than you'd ever need, and they are probably rusted inside.
    They make good extra reservoirs for an air compressor. I had an old 50gal water heater set up in my shop when I lived in NC, used a twin cylinder engine from the scrap yard and built a compressor that you could paint cars with for under $200, found a 220 motor in an auction pulleys check valves and a bit of ingenuity and you can have near unlimited air supply
    Beetle-Kill, wildwest and Horkn like this.
  9. Eric VW
    Rocket stooooooove! You'd have to build the feed, burn tunnel and heat riser of course.
  10. Beetle-Kill
    Beetle-Kill
    Never tried. These came from one of the Lodges in Breckenridge, consumable items for them. I took them for scrap metal.
  11. Beetle-Kill
    Beetle-Kill
    That's where I'm headed with one or two of these. I'll bet they're .188 wall or thicker, they weigh a bunch. I could link two together and have an air system that would never run out, for all intents and purposes.
    basod and wildwest like this.
  12. Beetle-Kill
    Beetle-Kill
    Actually, that thought crossed my mind. Better than a 55 gal. drum. Hmmmmmm....... :yes:
  13. jetjr
    jetjr
    Pa/Md line
    Yea its not holding air pressure. I have the new tank, but want to make it as easy as possible if it ever needs changed again. I went to 3 stores and could not find the tee I wanted so I had to order 1.
  14. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    I remember seeing a Youtube video on using a pressure tank for a stove and getting the bladder out seemed to be a big problem. Not sure what it is made of but it was difficult to remove.
    FYI
    Eric VW likes this.
  15. Eric VW
    I'll need to see that video when I come across an available tank. A shop heating rocket stove, whether a J tube style or batch box would require the tank (or drum) being cut in two for best workability.
  16. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Eric,
    Just search Youtube for rocket stoves. That is where I believe I saw it. I think that an air compressor tank might be better. I could be totally wrong but there is some type of bladder inside that pressure tank that needs to be removed. I don't have time tonight to look but maybe later in the week. Working with the kids to get their taxes done.
    Eric VW and basod like this.
  17. basod
    basod
    Mount Cheaha AL
    The stiff neoprene bladders are a PITA to remove - break the valve stem loose/drill or knock out with a hammer, and after cutting your holes bang the tank to knock rust loose and cut it up to remove it.
    If using for an air receiver no need to remove it provided the Schrader valve is holding - cheap replacement
    Eric VW and Minnesota Marty like this.
  18. basod
    basod
    Mount Cheaha AL
    compressor to supply them was where I was steering you;)
    Frankn' compressor - use an old twin cylinder or large displacement single iron block - the web has all kinds of ideas to make them(unfortunately I have no pics from 2002)
    Eric VW likes this.
  19. lukem
    I vote for a whiskey still.
    Canadian border VT and LongShot like this.
  20. ironpony
    ironpony
    Mid Ohio
    I would not do it, that volume of air under pressure would be a bomb going off. Not worth the risk imo
    FarmHand78 and Eric VW like this.
