Stihl Yellow Bar vs Green Bar
Discussion in 'Chainsaws and Power Equipment' started by Woodchuck, Apr 8, 2015.
  1. Woodchuck
    Woodchuck
    Southeastern Ohio
    Can anyone explain the difference between the two different bars?
    I understand the green "low kick-back" concept with the safety chains but what about the bars?
  2. 94BULLITT
    94BULLITT
    Frederick County, VA
    I think the green bars have a narrower tip than the yellow.
  3. prell 73
    prell 73
    ia
    I now about the yellow and green chain but haven't heard of yellow or green bars the bar on my 290 is all white with no color on it .the green chain is low kick back and the yellow chain ia way more agresesive with no kick back protection.
  4. Woodchuck
    Woodchuck
    Southeastern Ohio
    Here's a quick pic...
    splitoak likes this.
  5. DexterDay
    It has a narrower tip.
    The E bar (non replaceable tip) is normally considered Green and ES and ES Light (replaceable tip) are yellow.
    All 3 of these 16" bars are Green (E)
    And all of these are yellow..
    HDRock, FarmHand78, dusky and 8 others like this.
  6. prell 73
    prell 73
    ia
    :dex:damm I guess I learned something new that's why fHC rocks. I'll check my bar tomorrow to see what color it is .thanks fellas
    NYCountry and Moparmyway like this.
  7. clemsonfor
    Dex is right.
    The yellow bars look cooler to be there fatter at the tip and have a larger diameter end sprocket which increases the area kick back can occur on. The green have a narrow diameter tip so therefore less area on the tip to contact wood for kickback to occur, this making it " safer".
    Your (not meaning any member here just a generalized statement) farm boss comes with green tip bars.
  8. $ooline
    $ooline
    WI
    ES bars are heavier and more "heavy duty" with replaceable tips like Dexter says....the E bars are less expensive laminated bars.
    Shawn Curry, splitoak and Horkn like this.
  9. clemsonfor
    But dont get it wrong the green bars are still pretty durable. If you keep your bar groove clean so it can oil, use quality oil and a sharp chain there is no reason a bar won't last years. I am 10 years on a green tip bar. It did not cut much wood its first 5 years or so of life but was abused those years with duller than should of been chains. I pit a lot of wear on it those years!! It still has many more left in it though.
  10. ID1
    ID1
    N.E. Ohio
    damm! Mine are kind of silver and gray with burned brown spots and what looks like dirt!!:D
    Boog, papadave, MasterMech and 4 others like this.
  11. MasterMech
    Just to add to the confusion there were two versions of the yellow ES bars, a std and a Wide-nose.
    Green label bars are laminated construction and the yellows are solid.
    HDRock, Shawn Curry, $ooline and 4 others like this.
  12. clemsonfor
    Dex is the only person I know who can cut 10 cords with even a cheap bar with little more than a small paint chip. And that was probably from a factory imperfection. The only bare shiny metal on his bars is the rails!:)
    Boog, Shawn Curry and splitoak like this.
  13. ID1
    ID1
    N.E. Ohio
    I think that one of my bar and chains is from the mid 1970's :saw::saw::saw:
    Shawn Curry, splitoak and clemsonfor like this.
  14. Horkn
    Then there's hardnose bars too. I read up on those a little last night. Those are good for dirty wood cutting, but I think they have more downside for most types of cutting. They are expensive too from what I saw.
    Shawn Curry likes this.
  15. clemsonfor
    Hard nose take more power to spin the chain around than roller nose. Or should I say you loose more power running a hard nose.
    Shawn Curry, Horkn and prell 73 like this.
  16. Horkn
    That's what I figured. No sprocket, is more wasted power. It's just hardened.
    One came up on craigslist, but the lack of a sprocket, and me needing more power makes me not want that. I've only got an 029 super.
    Shawn Curry and clemsonfor like this.
  17. Machria
    Machria
    Long Island, NY
    Easy! One has a Yellow marking on it, the other has a Green marking on it!!!
    dave70, Boog, redRover and 2 others like this.
  18. Jon_E
    Jon_E
    Southwestern Vermont
    Stihl puts green bars and low-kickback (safety) chain, also with a green link, on all of their "homeowner" grade saws. That's somewhat of a generalization, but I owned an 025 and a MS390 and both came with Rollomatic E bars and low-kickback chain. Neither chain ever got used but I kept the bars. They're not bad.
    Current saws both equipped with Oregon bars and chain. I don't cut professionally so that's my best "bang for the buck".
  19. Evanrude
    Evanrude
    Byron, MI
    There's nothing wrong with the Rollomatic E bars. I actually prefer them on my saws 60cc and smaller. The bar is lighter than an ES, and generally, I don't need the extra strength in a shorter bar.
    Some people can make an argument for the tips being replaceable on the ES bars. Well, I got used saw and the tip was shot on the 20" ES bar that came with it. I thought I'd take it to the saw shop to get a new tip and all would be good. Long story short, the cost to replace the tip was about the same cost as buying a whole new bar.
  20. Gunn
    Gunn
    Plover, Wi
    Es tips can be had for less than 20 bucks. The cost of my 20" es bar was 55 dollars...
    FarmHand78 and $ooline like this.
