Creosote running down stovepipe
Discussion in 'Modern EPA Stoves and Fireplaces' started by CoachSchaller, Apr 7, 2015.
  1. CoachSchaller
    CoachSchaller
    Southeast Michigan
    Had creosote running down the stovepipe today. Between my slip pipe and my connector I have creosote running down on the outside. It doesn't surprise me as the temp has been warm and the stove has been running really low. It also rained all night and day. But it is not a nice look :(
    wildwest and Stinny like this.
  2. fox9988
    fox9988
    NW Arkansas 72717
    My slip joint has the larger (female) piece on the bottom so creosote can't run out of it, just like the other pieces of black pipe.
    Are your other pieces upside down?
    Sunfish, papadave and wildwest like this.
  3. Grizzly Adam
    Grizzly Adam Guest
    I've also only seen this on upside down pipe. Saw a lot of it as a kid...
  4. fox9988
    fox9988
    NW Arkansas 72717
    Yeah, we had some like that as a kid. Stinks to high heaven when the creo runs out :mad:
  5. CoachSchaller
    CoachSchaller
    Southeast Michigan
    Slip pipe going up to the chimney. Below that is a male to male connector attached to the female ends of the slip pipe and the stove pipe which is attached to the stove. It is leaking between the female slip joint on top and the top of the male connector. I put a few pieces in and am running a little hot to dry it out. I am bypassing the cat for this. I think whoever installed the stove pipe had it in upside down.
  6. CoachSchaller
    CoachSchaller
    Southeast Michigan
  7. Grizzly Adam
    Grizzly Adam Guest
    Make end up, female end down. Sounds like the problem.
  8. fox9988
    fox9988
    NW Arkansas 72717
    From looking at the pics, the bottom end of your slip joint should be a male end. Not sure what's up with yours unless it has been cut off (shortened). That would eliminate the double male and solve the problem.
  9. HDRock
    If you're having that problem you're not running your pipe and chimney hot enough
    splitoak and wildwest like this.
  10. Grizzly Adam
    Grizzly Adam Guest
    Dad used to run his plenty hot, but since the pipe was upside down we always had creosote dripping away.
  11. fox9988
    fox9988
    NW Arkansas 72717
    Cat stoves often run less than 250F single wall surface pipe temp. Mine does all winter with no problem and keeps the chimney decently clean.
  12. HDRock
    well maybe it's the wood, I didn't realize he had a cat Stove
    wildwest and fox9988 like this.
  13. CoachSchaller
    CoachSchaller
    Southeast Michigan
    ash is less than 20%. It has been 13-18 %. I have been running really low. The installers put in the slip pipe. I haven't seen a slip pipe with a crimped end yet.
  14. Grizzly Adam
    Grizzly Adam Guest
    Adjustable length? Mine is double wall with a crimped end.
  15. Grizzly Adam
    Grizzly Adam Guest
  16. HDRock
    my single wall slip pipe has crimped end on the bottom
  17. fox9988
    fox9988
    NW Arkansas 72717
    Here's mine. Rust on the upper half from slipping it up during stove cleaning.
    wildwest and CoachSchaller like this.
  18. fox9988
    fox9988
    NW Arkansas 72717
    May be from burning too low, inactive cat.
  19. CoachSchaller
    CoachSchaller
    Southeast Michigan
    yes, adjustable length
  20. wildwest
    Stinks how? Like burning coal?
    fox9988 likes this.
