Are bags of pellets any good for firestarters/kindling?
Discussion in 'The Wood Pile' started by Tasmaniac, Apr 4, 2015.
  1. Tasmaniac
    Tasmaniac
    Tasmania
    Kindling is a pain in the arse and messy and I was wondering if using 1/5 of a bag of pellets as kindling would be enough to start up the firebox with small splits. Im getting tired off sweeping up in the house and cleaning up the chopping area outside. Is it a viable alternative to splitting kindling all the time as we aren't cold enough to run a fire 24/7 down here yet.
    Pallet Pete and fox9988 like this.
  2. Woodrat1276
    Woodrat1276
    Ky
    Personally I would think not. I usually buy fire starters throw one in load the stove light the fire starter and done
    wildwest and rottiman like this.
  3. Tasmaniac
    Tasmaniac
    Tasmania
    So you don't use kindling at all from a cold start? 1 firestarter to start up a few big logs?
  4. Woodrat1276
    Woodrat1276
    Ky
    I throw in smaller pieces but no I don't use or process kindling. I use what ever is on hand that is smaller and works great once the fire is established I'll add a few larger pieces
    weatherguy, wildwest and rottiman like this.
  5. Tasmaniac
    Tasmaniac
    Tasmania
    No worries. At the moment im splitting up everything to the size I like as it is already bone dry but just a little too big. Im putting away about 5 years worth to be forgotten about (emergency use) and was weighing up my options for firestarters. Because of the spiders and snakes here I want to keep everything tidy and not have chit lying around and brought into the house. I was figuring just using a kilo or 2 of pellets stored in a bin near the heater and scooping them in and igniting a firestarter would cut down on the dust and mess a bit.
    fox9988 likes this.
  6. Woodrat1276
    Woodrat1276
    Ky
    I think if you split some smaller pieces and use a good fire starter you won't have any problems with it lighting. If it's bone dry you will be just fine. I will usually when cutting wood cut small limb pieces hear and there.
    They dry pretty quick are small and just toss them in with a fire starter and let it get going goid and load a few bigger pieces until the fire is well established
    Another thing I've done too is keep all the shavings from splitting and but them in a barrel where it's dry in the barn and use that to get fired going it works good too
    I think for a box of fire starters around here is $10 and we get 40 lightings from a box
    trooper and Horkn like this.
  7. savageactor7
    savageactor7
    CNY
    As an aside I'd have to agree with the OP about kindling being a pita and messy . Guess we've just grown use to it as a necessary evil...
    ...btw after a few warm days here I initiated a quickly made fire this snowy morning from a cold start with the help of diesel fuel in an atomizer squirt gun bottle.
    Crude but effective.
    wildwest and Horkn like this.
  8. swags
    swags Moderator
    Pallet Pete uses pellets as a starter, it worked for him. For me I don't split kindling, with dry wood on a cold start and no coals I just put 1/4 super cedar in the stove and that gets the splits going. With the cost of super cedars being low I bought a 100 count a few years ago and it has lasted a long time. I use them more often outside and in my corn stove then the wood stove though.
    DexterDay, Pallet Pete and wildwest like this.
  9. bassJAM
    bassJAM
    Cincinnati, OH
    I used Rutland fire squares most of the winter, and tried out Super Cedars in February. Both worked pretty well, I don't split anything smaller than about 4" and was able to get fires started by just tossing in one fire starter and leaving it.
    Most will disagree, but I think the Rutlands work better than the Super Cedars. I NEVER had to worry about a fire starting when using those, but on 3 different occasions with the Super Cedars I've gone back to check the stove and have found that the Super Cedar burned up without lighting the logs around it.
  10. Woodrat1276
    Woodrat1276
    Ky
    We don't have super cedars around here. A local grocery store chain here has great fire starters that we buy they work great I'll takeva pic of them later and post
  11. yooperdave
    I have not tried super cedars; i also use the fire squares. I am satisfied with them and they are cheap enough...get boxes of them from Menards when they are on sale 2/$1. I don't think they are sold by them any longer. Also use diamond strike a fire.
  12. WES468
    WES468
    Merrimack Vally Mass
    I pick up twigs and sticks in the yard and use pallets split into small pieces for kindling.
    For fire starters I use these, you can often find them at Wall mart for $5 on clearance,
    cut them in 1" squares, about 300/box.
    wildwest and swags like this.
  13. Horkn
    I pick up twigs and sticks from my yard and use them to start fires instead of dulling my lawn mower blades. A little paper, twigs, and splitter byproduct and its good. I'll use bark, and I'll pick up small dry branches and load them with my wood I take from the woods. The wife likes making kindling.
    Now, I have a fireplace. It is always a relight, unless I have coals from the night before, which is rare.
    I might change my habits a bit once I get an insert that has a much longer burn time.
  14. wildwest
    For better or worse, my husband has been using them to start fires in our stove. We have a bag damaged from rain...... We also have cedar starters, but he has been reaching for the pellets more lately.
  15. wildwest
    Us too, smaller splits on the start, I tend to go for the ones with some bark (lodgepole pine).
  16. wildwest
    You can get Supercedars here at FHC in the SWAGS store if anyone is interested, they ship the to you.
  17. fox9988
    fox9988
    NW Arkansas 72717
    I don't use kindling either, a piece of fire starter and a couple smaller splits.
  18. weatherguy
    weatherguy
    central massachusetts
    I'm on my 5th year and only halfway through my box of super cedars. I use cut up pallets for starting but in the middle of winter when I let my coals run too low I throw a coffee can full of pellets for a quick start, works great, never tried them as fire starters.
    fox9988 likes this.
  19. swags
    swags Moderator
    And they are branded FHC!
  20. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I find that if use use an old tin can and buy a bag of pellets that last us all year. It works fantastic... It's an instant coal bed because the pellets are so small. Put down the first layer of wood on the bottom of the stove with a flat or flat top piece in the center and pour out the pellets in a a line front to back set your lighters on that and load up. It is far simpler and faster than kindling.
