Osage standing dead for 50 years!
Discussion in 'The Wood Pile' started by Deacon, Mar 28, 2015.
  1. MarylandGuy
    MarylandGuy
    Maryland
    Deacon, nice score. I have never seen hedge, but would love to check it out. The closest wood to hedge I have seen is locust. By the way, hopefully you realize the MM is supposed to be used on a split piece on the inside, not on the ends of the wood.
    Horkn likes this.
  2. Horkn
    It can be used on the end on a fresh cut. But typically it's more accurate on the inside of a fresh split.
    Deacon likes this.
  3. MarylandGuy
    MarylandGuy
    Maryland
    I have always heard it gives a false reading on the end due to the the way the rings of the tree run. Supposedly It doesn't allow the electricity to flow properly between the two pins, thus distorting the reading. But what do I know. I clang two pices together and get a audible reading.
    Shawn Curry, Deacon and Horkn like this.
  4. wildwest
    Deacon , what is the stuff in the last pic?
  5. Deacon
    Deacon
    Eastern Nebr.
    Meadow Muffins, Pasture Pies, Cow Chips,
    Manure.:picard:
    Shawn Curry, wildwest and Horkn like this.
  6. MarylandGuy
    MarylandGuy
    Maryland
    Without knowing what they were, Meadow Muffins sounds like a nice breakfast treat.
    wildwest, Horkn and Deacon like this.
  7. lukem
    Prairie coal.
    Deacon, wildwest and Horkn like this.
  8. lukem
    Unless you have a very high end woodworker's MM, I doubt that it matters. For firewood purposes you just need to get to the part of the wood that would be the wettest (i.e. the inside).
    Horkn likes this.
  9. Deacon
    Deacon
    Eastern Nebr.
    Your correct, but it was a fresh cut & the grain just grabbed me.
    Split one small piece today ( actually they are all smallish)
    MM did the same... Started around 7-8% then just steadily went down to 5% ish then zero.
    I suspect that I can't get a valid reading below 5%
    :sherlock:
  10. sherwood
    sherwood
    Why was the fence taken down? That wood looks like it would have lasted another century.
    Horkn likes this.
  11. weatherguy
    weatherguy
    central massachusetts
    Can wood get to 0% moisture?
    Horkn likes this.
  12. Horkn
    I think it'd be dust if it did.
