Using an insert without a surround
Discussion in 'Modern EPA Stoves and Fireplaces' started by Scols, Apr 3, 2015.
  1. Scols
    Scols
    I have a decision to make and I'm looking for suggestions. This terrible winter has taken a toll on my old Better N Ben stove. The stove was originally made to be used slammer style but I removed the surround ( it was only bolted on ) shortened the legs and set it up as a free standing stove sitting in my fireplace. Its performed flawlessly for the past 3 years but after running it hard all winter its starting to warp on the top and sides. I would like to replace it with another free standing stove . The problem is , I only have 23 1/2" in height from my hearth to the lentil . So unless I want to open a can of worms and spend cash I don't have, I cant fit a free stander big enough to fit my needs ( ie englander 30). My wife and I both hate the look of a surround and I would rather not have to rely on a blower, but I was wondering if anyone here uses an insert with out the surround and if so are you happy with how it performs and looks ?
    wildwest and fox9988 like this.
  2. fox9988
    fox9988
    NW Arkansas 72717
    People use inserts with no surround, usually to get more heat out of it. Shouldn't be a problem.
  3. Scols
    Scols
    I agree, I'll get more heat for sure. But of course my wife is worried about looks , and I'm just wondering if theres something that I'm missing. Is there a practical reason for the manufacturers to put on a surround in the first place ?
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    Because the opening is so small will you sacrafice size for heat?
  5. fox9988
    fox9988
    NW Arkansas 72717
    Just for a more finished look I suppose. Back in the slammer days, it would help keep all the heat from sucking up the chimney.
    wildwest and Horkn like this.
  6. fox9988
    fox9988
    NW Arkansas 72717
    If you don't have a block off plate, I would definitely install one.
  7. Scols
    Scols
    I think if I went with an insert I could use a fairly large stove. Width and depth aren't a problem, just height.
    I do have a block off plate and a 6'' ss liner. My current set up works great, but the stove is tired.
  8. fox9988
    fox9988
    NW Arkansas 72717
    What inserts do you have in mind?
  9. Scols
    Scols
    Its seems like Englanders are well thought of. My closest hearth shop sells PE, Napolean, and Jotul. I haven't really shopped yet, just considering my options. I'm open for suggestions
  10. fox9988
    fox9988
    NW Arkansas 72717
    Englander doesn't make the 30 in an insert, only the 13 which is small. I assume you need lots of heat if the Better N Ben warped. In PE, the 3 cuft Summit gets good reviews.
    wildwest and Scols like this.
  11. Horkn
    Yep, that's what I have been reading. It's a step that some skip, and regret. So they pull the insert out and put one in.
    fox9988 and wildwest like this.
  12. Horkn
    I like the Buck and quadrafires too.
    Since I plan on installing my insert myself, I'm thinking of buying it from wherever I get the best price. While they are not light, getting a truck to deliver it shouldn't be an issue. Just get one with a lift gate since I don't have a forklift at home. ;)
  13. Horkn
    The summit looks nice, but plain, and getting a different colored/ plated door isn't the answer IMHO.
  14. wildwest
    Scols , you and I are in identical circumstances! I totally agree with whats been said!
    fox9988 and Horkn like this.
  15. KaptJaq
    KaptJaq
    Long Island, NY
    Since the slammer exhaust was not sealed to the flue the slammer surround would also force the draft to pull air through the stove only. If the surround was not well sealed cool air from around the stove would mix with the exhaust from the stove. This would cause creosote and a lot of flue fires. One of the main reasons slammers were banned...
    Most inserts today are stoves dressed up on the front only. They usually have convection paths built into the case also. The surround is decorative. Inserts are usually more expensive than regular stoves. If you can find a stove that fits in or in front of your fireplace you can save some money. The low lintel makes it tough. Have you considered a rear exhaust stove on the hearth?
    KaptJaq
    fox9988, Horkn and wildwest like this.
  16. reelcrzy
    reelcrzy
    Plymouth MA.
    Me tomorrow !
    wildwest, fox9988 and Horkn like this.
  17. Horkn
    Take pics and post them!
  18. wildwest
    We had a slammer that we replaced too. I bought the NC13i, insert, it fit in the fireplace opening (also ~~24" high) because I wanted to save space in the room :)picard: in hindsight). I would gladly have walked around a free standing stove if I knew then what I know now.
    We paid a welder to cut out a hole in our damper, and put in an insulated liner. We spent a bundle of money on cleaning the slammer crap out of the chimney and too much of my husbands free time doing it again to do it right (with more $$ for equipment for him to do it). The liner and stove were not cheap either.
    We installed the new EPA insert and cut the liner to fit, it was difficult to get the insulated liner through the new damper opening, maybe the welding cut was too small? The new insert is now installed an inch or two recessed from the faux brick fireplace opening so the shroud does not fit:headbang:. We ran it all this winter without the shroud without any problems. It looks funny though, and the smell from the soot in the original fireplace bothers us sometimes.
    The other issue is it's too small of a firebox for our situation (no furnace). Stoking the stove every couple hours is chore...
    We aren't going to spend more for a new stove and redoing the fireplace, instead use it as is.
    In retrospect I would have demo'd the fireplace opening to accomidate a free standing woodstove. Depending on how long we are here, there may be an NC30 in our future.
    A fellow members experience for you consider :)
    PS, I was drooling over the Napolean inserts but could not make the dimensions work.
    Stinny, reelcrzy, Horkn and 1 other person like this.
  19. wildwest
    Firebroad has a thread on these right now if you are interested, some good info there. We did one but not that well, installed the stove too late and it was always burning, too hot to do a good job, and we could not afford to let it go cold. No doubt it helps alot, but glad you are doing it when you while warmer so you can do it correctly :) Hopefully we can get it done better this year.....
    reelcrzy, Horkn and fox9988 like this.
  20. cnice_37
    cnice_37
    I run an insert and pull the surround off come January. Put it back on about 2 weeks ago. Strictly for looks, kind of like why my wife married me :whistle:
    You pretty much need a blower to be able to crank on the stove and not overheat it. My squirell cages croaked, and I refused to pay $300 to replace. I use the smallest Vornado fan that sits on my hearth and is super quiet instead.
