Guess the stove - here is the part - yes it is a very current model
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Mar 28, 2015.
  1. don2222
    don2222
    Salem NH
    Hello
    This sure is different, this auger motor and auger assembly.
    Which stove does it go into?
  2. eatonpcat
    I don't know!!
    will711 likes this.
  3. IHATEPROPANE
    IHATEPROPANE
    Quad
    jtakeman likes this.
  4. don2222
    don2222
    Salem NH
    Not a Quad :)
  5. IHATEPROPANE
    IHATEPROPANE
    Looks like a quad motor. Thought maybe they stopped the cork screw. No more guesses
  6. DexterDay
    Before I answer? One question. .
    Is the motor at the top? Or at the bottom?
  7. don2222
    don2222
    Salem NH
    At the bottom on this top feeder.
    DexterDay likes this.
  8. will711
    will711
    Pocono Mts.
    Who gives a Chit ??
    343amc, eatonpcat, imacman and 3 others like this.
  9. smoke show
    smoke show
    Pittsfield, Wi
    Pellet stove?
    eatonpcat and jtakeman like this.
  10. PoolguyinCT
    PoolguyinCT
    Mind reader...
  11. don2222
    don2222
    Salem NH
    The answer is the new PelPros and I have seen one that looks exactly like this in the Pleasant Hearth stove sold at Lowes.
    They all have that single dial control.
  12. IHATEPROPANE
    IHATEPROPANE
    Do they have the same torque as the other auger motors? Seems like they would be easier to change out.
  13. DexterDay
    Maybe a PelPro?
    :rofl: :lol: ;)
  14. don2222
    don2222
    Salem NH
    I do not think they have as much Torque as a gearbox auger motor.
    They motor is held in by a hitch pin.
    What do you mean change out?
  15. IHATEPROPANE
    IHATEPROPANE
    It seems easier to replace one of those when they fail then some of the ones with gearboxes. What's your take?
  16. don2222
    don2222
    Salem NH
    Yes, a little easier than a set screw but I like the more rugged set bolts like the old Englanders ,
    With this type because the auger shaft is only 1/2" I have seen the base of the auger ripped out when it is used with a higher torque gearbox motor such as the Golden Eagle.
    Since this has the quad reversing motor the auger base will not get damaged but it does get auger jams because pushing pellets up is harder than pulling pellets with a spring auger. 100% softwood pellets help prevent jams.
    IHATEPROPANE likes this.
  17. jtakeman
    Maybe its a gas stove?
  18. jtakeman
    My best guess its mainly cost reduction. = More money for the maker!
  19. Lousyweather
    Lousyweather
    pretty sure that's for that Vogelzang Chinese wood burner.....I have no point or reference for size....maybe cordwood could go thru it?
    IHATEPROPANE and will711 like this.
  20. will711
    will711
    Pocono Mts.
    I thought it was an ice auger ,that you could plug in to the lighter outlet on your Ski Doo or 4 wheeler :whistle:
    let's go fishing
