The official Earthquake thread.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Dec 4, 2013.
  1. clemsonfor
    Did u delete your own message? I got an alert but don't see it. I thought it seemed like you were off a good it late afternoon.
  2. clemsonfor
    I pulled this off one of their eBay auctions. Look in the background. They have pallets of the things! I guess they would have to as many as they sell. Screenshot_2013-12-04-15-01-06.png
  3. lukem
    Menard's was selling these for a while and my BIL bought one....I think he paid a $150. I'll save him the pain and never mention this thread.
    I used it once and wanted to throw up afterward. It was pretty painful...but I think most of that was because the chain is absolute garbage.
  4. the GOAT
    the GOAT Banned
    Someone mentioned a 12% off code for one of the sellers?...
    I might just buy a few to sell on cl.
  5. MasterMech
    "The twins keep us on Centaurian time, standard thirty-seven hour day."
  6. DexterDay
    Of course there is pallets of them. Ardisam makes the Earthquakes. The reason the cheapo ones may not be in stock, is they are "As is". Only so many of them to go around.
  7. MasterMech
    This AM the site said they were out of stock on all the new 'Quakes. AS IS saws -- 20 4518's, 10 4116s, and 4 3814s. :emb:
  8. the GOAT
    the GOAT Banned
    Alright I'm in on the Earthquake craze...
    DexterDay, clemsonfor and MasterMech like this.
  9. H 2 H
    H 2 H
    When I got all of them I did; Sears just closed out all there stock of them
  10. basod
    basod
    Mount Cheaha AL
    Curious about this base gasket delete deal - obviously some compression added, but does it slightly change intake/exhaust port alignment(has to right?) As well as the port to piston timing
    What do you guys do? Lap the cylinder and use some sealant(Hylomar/Loctite 516 etc?)
  11. clemsonfor
    They just lower on the engine right? The piston foes below the ports more than the gasket thickness so it do sent matter right.
  12. basod
    basod
    Mount Cheaha AL
    No because it is a fixed intake/exhaust port on a 2 stroke it changes the cycle time - subtle though it is I was curious if ports are opened on the bottom of intake and upper part of the exhaust.
    Really the upper part of the exhaust is where it would affect the "breathability" most
  13. basod
    basod
    Mount Cheaha AL
    This is basically like decking the heads on a 4-stroke but without changing valve lift and timing as there are none.
    I would guess any of these 200psi units are running av-gas as well - who'd of thought your $45 saw drank $6/gal gas:rofl: :lol:
    raybonz likes this.
  14. H 2 H
    H 2 H
    I used
    When I took the gasket out
    You have to measure
    MasterMech likes this.
  15. clemsonfor
    Sure wish I could see these pics your adding? How are u attaching them I only see question marks? Are u uploading them or linking from another site?
  16. amateur cutter
    Clemsonfor, the pics are here. Check the settings on your phone to make sure it will allow pics from FHC. Also pics don't always load if you don't have good data coverage, the things time out. A C
  17. DexterDay
    Make sure to measure squish on these. People elsewhere are getting over 200-220 psi in stock form with 1 tank of gas. Running 91-93 pump gas and mixing 32:1-40:1. So removing the gasket, may cause some interference with #'s that high.
    And Clem, as Basod said above, the piston and cyl make the same travel. But by removing the base gasket, the intake and exhaust ports, do get slightly affected. But it isn't enough to notice. Unless your base gasket is something ridiculous, like .050" thick.
    I'm gonna check mine tomorrow. . :)
    But for now, I have a Gem on my bench.
    H 2 H likes this.
  18. DexterDay
    Yeah, if it times out or your signal isn't up to par, it won't load up. I've only seen it twice, a quick refresh, and pics appear.
  19. amateur cutter
    I would be very interested in a 103 cc saw to play with IP. If that happens can you let me know please. A C
  20. clemsonfor
    Its weird its only like certain people I can't see their pics.
    I'm sitting 20ft from my wifi router!!I have not seen a single pic from H2h. I see every pic Dex posts as well as MM and I think Pete. I see backwoods pics. I see all ironP's pics?? There a few other members that I can't see their pics either, no matter if on wifi or cell signal? That's why I assume its a hosting issue??
    H 2 H likes this.
