Coal burn down/prep for emptying ashes
Discussion in 'Modern EPA Stoves and Fireplaces' started by bogydave, Dec 4, 2013.
  1. bogydave
    Started the coal burn down;
    Rake coals forward, lay a split on top & burn on high.
    No flash:
    Flash:
  2. bogydave
    Raked again
    one more split
    Still getting a lot of heat output.
    Does that look like near 2/3 cord of birch ? Amazing
    split added
    1:30 PM
    Should be good to empty by 3 or 4 PM
    22 ° F outside now :)
  3. Pyroholic
    Pyroholic
    mid michigan
    I guess I've never had to worry about burning coals. My defiant seems to have that job done every day when I get home. Still enough for relight, but barely.
  4. HDRock
    Good info you have been posting, Dave, for me with my first EPA stove
    papadave and Chvymn99 like this.
  5. Chvymn99
    I just find it entertaining, how different style of stove burn. :thumbs: Thank you & keep posting, sir.
    papadave likes this.
  6. bogydave
    With OATs ranging above 15°f at night & mid 20s daytime.
    I don't have many coals, they get burned down to where not much left after 24 +/- hours.
    When getting the -17°f nights to near zero daytime temps, I need the heat from a good fire, so I
    reload after about a 12 hour burn & have lost of charcoal.
    Takes about 8 hours to burn down this many coals, yet still put out enough heat
    for todays 20° temps, using the on split on top.
    papadave and Backwoods Savage like this.
  7. Oldhippie
    Oldhippie
    Ashby Ma
    It really is amazing!
  8. Oldhippie
    Oldhippie
    Ashby Ma
    So the one split on top keeps the temps up while not adding yet too much more charcoal to get burned down? Do you do that with the cat engaged and full open air, or wide open without the cat engaged? ..or some other settings?
  9. bogydave
    Get lots of coal burning down, one splits worth of coals not noticeable.
    Cat engaged, Stat on high 3.5, blower 75%
  10. bogydave
    Crack door (bypass is open) for 15 to 20 minutes just to cool it off enough
    to work with welding gloves.
    Rake most the coals to one side, realizing, the stove is hot & so are the ashes & charcoal.
    Shovel to bucket
    close door, cracked open
    Hurry up with the 1st bucket to the garden. Make some steam.
    Rake coals to the other side, shovel & to the garden. 3/4 bucket full
    Stove clean with some hot coals left to start the new fire.
    milleo and Blue2ndaries like this.
  11. bogydave
    Couple more pictures of the new fire on top of the coals.
    1/3 load since it only has to burn 6 hours
    then full load for the night & it's warmed up to 24°f outside :)
    Close bypass, run in med -high , with fan 60%
    Good to go.
  12. Oldhippie
    Oldhippie
    Ashby Ma
    Beautiful routine! How much does the ask help the garden do you think?
  13. bogydave
    I put it between the raised beds, keeps many of the bad bugs away & most of the weeds out .
    papadave and Oldhippie like this.
  14. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    What model Defiant are you running?
  15. Pyroholic
    Pyroholic
    mid michigan
    1975. Parents bought it new in 1979 for $900. Heated their house until about 95. I pulled it out of storage from the back corner of dads barn last winter.
    That is the exact point when hoarding, cad, etcetera first began.
  16. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Ah, the original Defiant. Okay, the burn time makes sense. I had the old Vigilant from the same time period. Good stove, just not the most efficient.
  17. papadave
    For the first time, I've been doing the same thing with every load of ashes this year.
    Need to build some raised beds this winter too.
    Keep up the pics and info Dave......love it.
  18. Blue2ndaries
    Blue2ndaries
    Oregon
    Nice work and process Dave. This may be a silly question but do you have a pic of the rake you are using? I am working on my process of ash cleaning with coals present. Don't really like waiting for everything to burn down all the way to clean up the box. Thanks in advance.
  19. bogydave
    That would be one thing I need , a better rake for the coals.
    The one that came with the stove.
    May make this into a coals rake :
    Or take one of my garden tools, shorten the handle & use it.
    HDRock likes this.
  20. bogydave
    No burn down last night.
    Stove not putting out a lot
    Just a few hot coals left
    Lots of room for a full load:
