Englander NC30 Hearth build.
Discussion in 'Modern EPA Stoves and Fireplaces' started by clemsonfor, Mar 23, 2015.
  1. Brad38
    Brad38
    S. Indiana
    Someone else mentioned micore. Found some micore online with free shipping. Stuff is kinda pricey, but would make building w/wood an option. This is stated at an R-value of 1.04, then a couple sheets of cement board should give you what you need.
    http://www.efireplacestore.com/sbi-ac02565.html#reviews
  2. FTG-05
    FTG-05
    TN
    If you're talking to me, the joists are less than 12" on center and the cross pieces are about the same. I specified that I wanted the spacing no greater than 12" and I got it. I wasn't counting on the cross pieces, but I had some treated 2x6's left over and asked the carpenters how it could be used here and this is what I got.
    The treated 2x6 platform is as solid as a rock, as-is the four Durock board layers screwed to the top of it. There is absolutely no flex at all in the Durock layers (there really wasn't any after just two layers). The back wall of my hearth also has two layers screwed to the studs all the way to the top. The bottom of the hearth mantle as at least 5 perhaps 7 layers of Durock screwed to it. There was two originally, but the stonemason added more so that the stone work would line up vs. cutting each mantle bottom piece to match the original height of the mantle.
    You guys wondering about the strength of Durock, here's a link to a .pdf on the technical properties data for Durock. https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCAQFjAA&url=https://www.huttig.com/pdf/USG_DurockCementBoard.pdf&ei=j3QRVeKBFMGIsQSTnIKYCA&usg=AFQjCNGWTbfvncwHzVrMKLgW4T7RLneX9g&sig2=EmfrodvjFlgOXrdP72e89w&bvm=bv.89184060,d.cWc&cad=rja (If the link doesn't work, google "Durock cement board CB399".
    On the third page, it states that the flexural strength is >750 psi and the indentation strength is >1250 psi. Of course, none of this really matters since you'll be putting some other concrete/stone cover over the Durock and it won't see any of these pressures, assuming you supported it adequately.
    basod, Brad38, wildwest and 1 other person like this.
  3. Norky
    Norky
    I sandwiched red bricks between 2 pieces of durock, then covered that with stone. The buildup part was cheap and it's very solid.
  4. clemsonfor
    I won't do brick as I will already be doing large cement spacers and already have lots of weight up there.
  5. papadave
    I wonder how you might be able to incorporate air space into the mix to achieve the 1.5.
    milleo, clemsonfor and wildwest like this.
  6. clemsonfor
    I am not as worried about air space now. Was gonna raise it on metal 2x4 but I think there too weak laterally to use. I am gonna stack I am sure now.
    FTG, why did you use treated wood? Did you allow it to dry before installing it?
    papadave and wildwest like this.
  7. papadave
    Was wondering the same.
  8. FTG-05
    FTG-05
    TN
    We did a lot of remodeling of the house after we bought it. It's on a slab. Most of the wood touching the concrete was treated. Hence, I bought treated wood for it, buy once, cry once.
    It sat for probably 4-6 weeks before we could get the carpenters out there; I don't know if that's dry or not, but it is what it is.
  9. Chvymn99
    When i get on the laptop later on. I'll post my hearth with the steel 2x4's.
  10. wildwest
    Are you MST or CST?
  11. Chvymn99
    CST... the kid is doing homework on the laptop... It'll be the morning when I get you it.
  12. clemsonfor
    Ok so if it was on concrete yes it would need to be treated. That time is probably ok if out was climate controlled. It just looked wet in pictures.
  13. Chvymn99
    This is how I did mine and its held my NC13 and currently holds my NC30.
    My 2x4 base. The 5 pieces are all screwed (self tapped) together. I alternated back and forth when I screwed them together. Then they are lightly screwed down to the floor. I used concrete board and then went with Durock all screwed together. Then did my tiles on top of that. On the back wall and the bottom I have free flowing air pockets from the bottom to the top and to the front of the hearth for 1" air insulation.
  14. clemsonfor
    That stuff is so pricey and you would need to stack anyway so I dont see much difference in using all durarock?
    I would like to get just enough for one layer though.
    wildwest and papadave like this.
  15. clemsonfor
    Ok so you laid them down. I was thinking up on their side like floor joists. I like this option. I also like how you did the back wall with them on their side..again. I may borrow at least that back wall idea. And out the durarock over sheetrock then durarock over the studs so that I can get the 1" air gap on back for air flow and to get the 12" ctc.
  16. FTG-05
    FTG-05
    TN
    Ok let's assume the treated wood was wet as installed. Is there an issue? What would come off of "wet" treated wood? Serious question, I have no idea.
    It's done now, and been down for almost 5 months now. Should I be worried about the third arm that's now growing out of my left shoulder blade or the fact that I have a stuttering pro... pro... pro... pro... issue?
    Please advise soo.... soo..... soo.... soo.... as quickly as possible.
    Thanks!
  17. clemsonfor
    The wood is not harm full to humans. Even the old kind with Arsenic was not really harm full, unless you eat like a pound of it!!!!
    But its sealed in now so not much will off gas. well I guess its not more air tight than your walls and they lay those base framing boards down wet. I guess it would eventually dry as enough air exchanes through cracks? It it was too wet it you might have moisture/mold as it condenses in the closed area??
  18. Highbeam
    Highbeam
    I used light steel studs the tall way topped with just two layers of durock and tile. Neither my hearthstone heritage or the blaze king have cracked a tile or fallen through. The tile distributes the stove load somewhat I'd guess. So the stove at 500# + 50# of wood plus at least two fat chicks warming their rumps up on the hearth, nearly half a freaking ton!
    BuckthornBonnie and clemsonfor like this.
