Garage/Man Cave
Discussion in 'The DIY Room' started by Grizzly Adam, Mar 16, 2015.
  1. Butcher
    Butcher
    I meant head room as for door installation. They make low head room kits for over head doors but you will have to take a tape to what you got to see what is available for your needs. If the ceiling is to low a roll up door may not work either.
  2. eatonpcat
    Have an outside slider on my pole barn also...Froze to the ground this year!!:picard:
    Sam, wildwest and HDRock like this.
  3. lukem
    Roll up door. Used in warehouses pretty often.
  4. Grizzly Adam
    Grizzly Adam Guest
    Looked into them, probably going to go that route. Even if its too low, it will only be at the entry point, not 1/2 the depth of the garage.
  5. lukem
    The ones we have are for 40 foot tall doors and are only 24 or so inches tall. We mount them above the header so clearance isn't an issue.
  6. Grizzly Adam
    Grizzly Adam Guest
    We have rafters sitting on too of the header IIRC.
  7. prell 73
    prell 73
    ia
    Lookin good grizz.keep up the good work nothin better than a man cave .
  8. wildwest
    Same here, under the snow drift. He had to chip it out, to get to our pellets in there.
    eatonpcat likes this.
  9. Grizzly Adam
    Grizzly Adam Guest
    Making some good progress today with joist and floor repair in the loft.
    WinonaRail, Deacon, papadave and 6 others like this.
  10. HDRock
    Looks like the chit hit the fan ! man :rootintootin::D
    :popcorn:
  11. prell 73
    prell 73
    ia
    Looks good grizz keep up the good work.
  12. Grizzly Adam
    Grizzly Adam Guest
    Think the floor will be fixed up by the end of the day.
  13. wildwest
    Did you make it back to Menards for correct pipe? Also did you find a good door option?
  14. Grizzly Adam
    Grizzly Adam Guest
    Yep, went back to menards the next day and got it sorted out. I think we will do the roll up even though it will be a little low right at the entrance.
    I didnt quite get it done, my body called it quits. Got most of the floor done, still have to cut about 4 pieces and screw em down.
    papadave, Chvymn99 and wildwest like this.
  15. wildwest
    :thumbs:
  16. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    A fire pole to slide down would be cool. Neat barn you got there Grizz.
    thistle, papadave, Chvymn99 and 3 others like this.
  17. basod
    basod
    Mount Cheaha AL
    Good progress - good time of year to be getting the heavy upstairs work completed, might get a little warm up there when the sun starts shining.
    I guess you checked into codes for fireplaces in garages?
  18. Grizzly Adam
    Grizzly Adam Guest
    Yeah, my brother put one in his in the fall so we will be up to code once we get the rest of the chimney installed. Waiting for the cap to arrive in the mail.
  19. eatonpcat
    We call that a stripper pole in Cleveland!! :D
  20. basod
    basod
    Mount Cheaha AL
    to each his own:whistle:
    firefighters involved?
