MillerModSaws plays with a 440R/046D Hybrid
Discussion in 'Chainsaws and Power Equipment' started by millermodsaws, Mar 14, 2015.
  1. millermodsaws
    millermodsaws
    downloadfile-2.jpeg Ok boys I've wanted a hybrid for awhile so I'm gonna take some time and build mine had all the parts for awhile so let's give it a go. Here's my canidate a very nice ms440 with a toasted top end.
  2. mdavlee
    mdavlee
  3. millermodsaws
    millermodsaws
    downloadfile-4.jpeg I got this super nice 046D cylinder, piston and rings from mister cgraham1! Thank you sir!
  4. millermodsaws
    millermodsaws
    Just starting buddy. Lmao.
    $ooline, DexterDay, splitoak and 2 others like this.
  5. millermodsaws
    millermodsaws
    20150313_155423.jpg I started by taking 1.2 mm off the base sides to narrow it up to fit it the hole and slotted my holes just a bit to line up with the 440 crankcase
  6. mdavlee
    mdavlee
    Is it one with short blowdown or just the D chamber?
    DexterDay likes this.
  7. millermodsaws
    millermodsaws
    Give me just a minute and I will answer that question. Take a guess! Lol.
    DexterDay, Chvymn99 and mdavlee like this.
  8. mdavlee
    mdavlee
    Hard to tell. If it's short blowdown it's only about .170" between exhaust and transfers.
  9. millermodsaws
    millermodsaws
    20150313_201605.jpg Next I had to cleareance the clutch side fins just a little bit.
  10. millermodsaws
    millermodsaws
    20150313_201811.jpg 20150313_201517.jpg I then drilled the bolt passages to 8.5 mm. Not much bigger just a little. This is to cleareance just a little because I converted the cases to an m6 bolt instead of the m5.
  11. millermodsaws
    millermodsaws
    20150314_074400.jpg Then I cleareanced the cases to fit the larger trans tunnels. O ya and I will have to cleareance the flywheel but I just removed it for starters.
  12. millermodsaws
    millermodsaws
    And here's the numbers. Lightly tightened with gasket I have .056 squish. With out a gasket I have .036" squish and the numbers are 104/121/72. Only 17° blowdown on a factory cylinder!
  13. millermodsaws
    millermodsaws
    I just seen I'm an idiot and put this under the wrong forum. Hopefully the moderators will move it for me.
  14. mdavlee
    mdavlee
    I've heard of cylinders with 14° from the factory. Should be a fine runner with those numbers to start with.
  15. millermodsaws
    millermodsaws
    I'm headed 102/118 and what ever the intake lands from squish cut. My debate is in whether or not to bridgeport this one. Lol.
  16. millermodsaws
    millermodsaws
    I'll try and get some pics later I have a 460 cylinder here too and you can see the trans tunnels are bigger on the 046D jug. That coupled with the case volume makes me hesitate on trying the bridgeports. Lol.
    DexterDay, Chvymn99 and cgraham1 like this.
  17. Scotty Overkill
    Moving this thread to the chainsaw room, fellas.......
    concretegrazer and Chvymn99 like this.
  18. cgraham1
    cgraham1
    Nor Cal
  19. Moparmyway
    Moparmyway
    New York
    Nice choice for proting and a build thread............ following along !
    DexterDay and Chvymn99 like this.
  20. millermodsaws
    millermodsaws
    20150314_070130.jpg Without a gasket I have roughly .055 till it is at the bevel on the piston. I'm gonna use all of that. Lol.
