4" vent after 2 ton
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by DexterDay, Mar 5, 2015.
  1. gbreda
    gbreda
    NH
    I would lean towards the Lint Eater just for the fact of getting it around the 90. Plus as my clean out T is so close to the basement floor, I need a lot of bending there to.
    Great job Dex, that venting looks new !!!
    DexterDay and wildwest like this.
  2. wildwest
    LintEater is here now! I will try from the inside for the pellet stove Friday. If possible, or advisable, I think I need to get the clothes dryer too. The drying cycles are taking longer and I am having to rerun them. My question on the dryer is it's only about 5'. Would it be easier to just take it off and rinse it out?
    thanks.
    DexterDay likes this.
  3. chbryson
    chbryson
    Don't believe if you duct tape the joints they wont come apart in reverse. They do. And then you have a super tight piece of tape that is stuck all over the place and a black arm if you can get to the rod stuck in the pipe. Luckily mine came apart just inside my chimney liner from the PVP and I was able to reach.
    gbreda, DexterDay and wildwest like this.
  4. DexterDay
    Speaking from true experience :thumbs:
