Ideal Steel
Discussion in 'Modern EPA Stoves and Fireplaces' started by Backwoods Savage, Mar 11, 2015.
  1. Backwoods Savage
    New email sent out by Woodstock. Thought some just might like to save a few dollars.
    Why is it time to go Hybrid?
    Because hybrid woodstoves combine the technologies of secondary burning and catalytic combustion to create the most efficient, cleanest burning wood heat on the planet.
    Take a look at our award-winning Ideal Steel Hybrid!
    Why does the IDEAL STEEL Hybrid have the largest firebox and the highest efficiency, but the lowest price of all of our woodstoves? The answer is that we were challenged by the Woodstove Design Challenge to design a stove that was both very efficient and affordable. So we did!
    If you haven’t looked at new woodstoves for a while, we invite you to check out our new Ideal Steel Hybrid, for both its technological advancement in this industry, as well as its affordable price. You can still purchase an Ideal Steel Hybrid for as low as $1795 during our hybrid sale... and get free shipping too! (up to $250)
    Our Hybrid woodstoves are on sale through April 10, 2015. Our Hybrid prices will not be this low again! So, take a look at our sale prices, and call us at 1-800-866-4344.
    Brad38, Gark, HDRock and 3 others like this.
  2. dirtdevil
    dirtdevil
    Northern central Indiana
    Got the email, really want one. But not sure it can do what we need. We have a PE Summit right now, and we had trouble with coals building up with the 0 to -10 degree days. What does anyone else think about the IS versus PE Summit? Will it do better with longer medium to medium high burns?
    fox9988 likes this.
  3. My IS heats my home
    My IS heats my home
    Albany, NH
    I got the email today too. Glad I had one in October last year, not sure the Jotul would have carried us another year.
  4. OhioStihl
    OhioStihl
    Southern Ohio
    I have a T6 which is a summit dressed in different clothes but same insides. Though I have not had experience with the IS personally I would say the IS would be an upgrade. My stove was coaling some and the ash pan leaves a lot to be desired. Easy ash management without having to deal with coals is making me look at the Progress Hybrid.
  5. T-Stew
    T-Stew
    Good timing. Just signed up here (was a poster on that other forum), and thinking about upgrading to the Ideal Steel. While my Jotul Rockland does a great job, it just isn't quite enough on the coldest few weeks of the winter and with my hours at my job no way can it last through my workday, stone cold and not even embers enough to re-lite when I get home. So looking for something bigger and longer burning. So far the IS sounds like it may be on the top of the list plus has the value factor making it my prime consideration so far.
  6. JA600L
    JA600L
    Lancaster, Pa
    Welcome to this side T-Stew! I think I was part of the discussion over there.
  7. fox9988
    fox9988
    NW Arkansas 72717
  8. T-Stew
    T-Stew
    Thanks Fox and JA!
    Yeah I was Ohioburner over there. I'll likely create a similar thread over here to get some more opinions and specifics, now that I have a better idea and some direction. Hopefully next winter I'll have a better heating arrangement one way or another!
    papadave likes this.
  9. papadave
    Welcome aboard T-Stew.
    T-Stew likes this.
  10. oldspark
    oldspark
    NW Iowa
    I had a Summit that I had no luck with what so ever, the IS is probably more versatile then the Summit.
    The coal build is normal for a EPA stove that you do not let cycle through, which means you are not getting the heat out of the stove you need when it's cold.
    For the most part my Drolet has ended my coaling problems because it put out more heat then my Summit ever did.
    I also am considering the IS as they have a return policy but not sure if I would have enough time before the 6 months runs out to get a good feel for it.
  11. MightyWhitey
    MightyWhitey
    x2!!!:D:thumbs:
    If I weren't hoping to get out of Illinois before too long, I'd consider that IS for sure.
    T-Stew and Backwoods Savage like this.
  12. Backwoods Savage
    Welcome to the forum T-Stew.
    On the coaling problems, it can definitely be a problem. With our stove, we found that if we open the draft fully just before the burn gets all the way down to coals, the stove will hold the temperature and burn down the coals at the same time. On occasions when perhaps we've been gone before the burn gets to that point we do end up with lots of coals. In those times we will add a small split or maybe 2 if it is really cold outdoors. Leave the draft full open and even rake through the coals to loosen them and that will help burn them down quicker. As they get down a bit, move most to the front of the stove.
    Brad38, T-Stew and MightyWhitey like this.
  13. MightyWhitey
    MightyWhitey
    This^^^^!!!
  14. Gark
    Gark
    SW Michigan
    Welcome to the FHC, T-Stew.
    We installed our Ideal Steel last October and I'm astounded to have 2/5 of what firewood was stored for winter still left. I can't talk to whether the IS would work for you, but there are several long in depth threads here on the IS.
    Brad38, T-Stew and papadave like this.
  15. chance04
    chance04
    Denton Md
    Is the cat probe a standard now on the IS or is there just a port there to add one later? Some picture show a probe, others show a port, and yet others don't have either.
    fox9988 likes this.
  16. JA600L
    JA600L
    Lancaster, Pa
    There is no cat probe from Woodstock. Most folks like me just stick a magnet on the front. Others have ordered one from condar and cut it to length.
  17. chance04
    chance04
    Denton Md
    So there is a port there for a probe?
  18. chance04
    chance04
    Denton Md
  19. JA600L
    JA600L
    Lancaster, Pa
    Yes there is. It just has a screw in it when it is delivered.
    chance04 likes this.
  20. chance04
    chance04
    Denton Md
    Perfect!
    fox9988 likes this.
