Great article
Discussion in 'The Wood Pile' started by Backwoods Savage, Mar 10, 2015.
  1. Backwoods Savage
    The link to this article is: https://nationalfirewoodassociation.org/2015/03/moisture-meters-in-the-field/
    Moisture Meters in the Field
    Posted March 6th, 2015
    We do a lot of talking about the moisture content (MC) of firewood, and for good reason — but do you know the actual moisture content of the wood you’re selling — or burning? Kiln-driers are quite familiar with probes that require drilling pilot holes and specialized equipment to read the data. We can’t claim to match the accuracy of these established methods, but we can come close.
    We’re using a commonly available moisture meter that costs around $25.00. While pro-grade meters can cost hundreds, the major difference is in build quality and long-term reliability. On the inside, a moisture meter is simply a specialized ohmmeter with a mathematical algorithm to make it read in percentage of moisture detected based on the electrical resistance between the pins.
    One thing to know about moisture meters is that readings become inaccurate below about 9% and above 25% or so. That’s okay, because we’re mainly interested to find out if a given piece of wood is suitably dry enough to burn. By taking four readings, we can determine the actual moisture content with a fair degree of accuracy.
    Moisture inside a piece of firewood exists as a gradient — if you could see it, the moisture contained would resemble the shape of a football — with the most moisture in the middle and tapering off toward each end. With this in mind, we know that we should measure near one end and then in the middle to get a good average.
    The industry-established way to measure moisture is with insulated probes driven halfway through the thickness of the wood to measure the core. Here, we are simply splitting the sample to reveal the core, approximating the accepted method.
    Start by measuring the freshly exposed face (from splitting) in the exact center of the sample. Since this is always going to be the dampest part of any piece of seasoned wood, a reading of 20% or less here means your wood is plenty dry enough to burn. If it reads above 20% — or you want an accurate estimate of the exact number, you will want to take more readings. Remember that numbers above 25% or so are not accurate.
    The second reading is taken 1″ from one end of the piece. While you might think it should be measured at both ends, this would skew the results by over-representing the drier state of the ends when compared to the middle.
    If the two readings from the fresh face average out to less than 20%, you’re good to go. Note that it is possible for very dry wood to absorb moisture from the environment, so theoretically it would be possible that the ends could be more damp than the middle.
    To get an accurate estimate of the total moisture content of your sample, you will repeat the readings (center and 1″ from one end) on the weathered face, the average all four numbers by adding them together and dividing by 4.
    Finally, it must be understood that this measurement only indicates the MC of one single piece of firewood. If you wanted to know the average MC of an entire wood pile, you’ll need to measure several samples from the top, the middle and the bottom of the pile — seven or eight samples per face cord.
    While any one of the readings taken with a meter is expected to be accurate within +/- 1%, a 5% margin of error is considered acceptable due to the nature of wood fiber structures within, species, temperature, and relative humidity. If the temperature is much below 50F, you’ll want to correct your figure up about 1% — and if it’s much over 80F, correct it down by 1%. Similarly, some species measure a bit differently and require correction of about 1-2%. These variables illustrate the reason that a large margin of error is acceptable.
    The inescapable conclusion is this — it is a lot easier to determine whether wood is dry enough to burn using your eyes and ears than it is to use a meter. Experienced wood burners immediately recognize the musical ring that two pieces of dry wood make when knocked together — and using a meter on wood that rings properly would show a reading of less than 20% MC. A visual examination of this ‘ringing’ wood would show a grayish coloration and tiny cracks (checking) in the end grain.
    Then why mess with using a meter? Personal education is one reason. You can test your skill at judging dry firewood against actual numbers, and you will learn quickly how to identify it without a meter. A better reason is because this data is quantifiable. It would be hard to argue with a firewood supplier that the wood they delivered just doesn’t sound right. With actual numbers, you can prove that it either is or is not dry enough to burn. Wood over 20% MC is hard to light, and over 25% will make a sizzling sound when it burns. At 30% you will see water bubbling from the end.
    Also remember that it is possible for wood to be too dry, although not likely in any typical scenario. Wood that is too dry burns too intensely, using up all the available oxygen in the stove before the gaseous and airborne byproducts of combustion can be burned in the firebox. The result is increased smoke output. If there is, by chance, enough oxygen available, burning very dry wood results in a very hot fire that’s difficult to control and can warp and crack your stove and/or chimney.
    Shoot for wood that’s between 15 -20% MC for the best results.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Great info Dennis. This should be a sticky for sure
    HDRock, schlot, BrianK and 4 others like this.
  3. Backwoods Savage
    That is an idea. Perhaps we should ask Grizzly Adam about that.
  4. billb3
    :handshake:
    XXL, wildwest and Shawn Curry like this.
  5. Shawn Curry
    Shawn Curry
    Western NY
    Loved it - until I read the final paragraph. Nobody who is burning wood that's stored outside will ever need to worry about wood being "too dry". Why do they always feel it's necessary to put that in there? If they're worried about dummies burning nothing but cardboard and kiln dried lumber, they should say so.
    Otherwise, great info, as always. :thumbs:
    crzybowhntr, HDRock, milleo and 3 others like this.
  6. Backwoods Savage
    I agree Shawn. But some never learn.
  7. prell 73
    prell 73
    ia
    Awsome info.
    XXL, Shawn Curry and wildwest like this.
  8. Woodchuck
    Woodchuck
    Southeastern Ohio
    This is an awesome thread! I bought a MM just to experiment with. It is the same one used in the pic.
    Not expensive, but gives good repeatable results :yes:
    The Cherry I've been burning lately reads between 12-13% :dex:
    HDRock, Backwoods Savage, XXL and 2 others like this.
  9. wildwest
    Wyoming high plains
    Thanks
    Backwoods Savage and Shawn Curry like this.
  10. swags
    swags Moderator
    Good read
  11. Paul bunion
    Paul bunion
    Pretty good info until the part about dry wood being grey and showing signs of checking. That statement is close to useless. Greying is an indicator of weathering, not drying. Case in point, kiln dried lumber isn't grey and top covered cubes do not yield grey wood. Checking means that the exterior just got a bit drier than the interior, it has no indication of how dry it is. It will happen just as easy when the interior is fully saturated and the exterior has just begun to dry and it was left out in the rain for a few months. (However a radial crack down the length of a round does mean something).
  12. Gasifier
    A good article Sav. Thanks.
  13. Locust Post
    You better just give all that old wood away that you have stacked Sav.....it's way too dry and we don't want to see you warp your stove.
    HDRock, Backwoods Savage and wildwest like this.
  14. Gasifier
    I'll take it!:handshake:
  15. wildwest
    Wyoming high plains
  16. Backwoods Savage
    Very well stated Paul. I couldn't agree more. I knew some folks would pick up on those couple of dumb statements but usually find that just about any article has that sort of bull in it. I doubt we'll ever get all that out.
  17. Backwoods Savage
    Do you mean this stuff Locust? It was cut to length about 14 or 15 years ago and just laid on the ground all that time. There are 3 rows there and we did burn 2 of those rows this winter. This is perhaps the oldest wood we've ever burned, and it is all red and white oak. Sweet!
  18. Lumber-Jack
    Lumber-Jack
    Great article! except for the part that is boldly highlighted.
    This is absolutely not true.
    When they talk about those electronic moisture meters they often mention how there could be 1%-5% errors due to various factors like temp, wood species, etc. Some people even balk at their usefulness because of these possible small errors. What never seems to get mentioned is the % of error that would likely be associated with using your eyes looking for gray weathered wood and checking, or using your ears banging chucks of wood together. My guess is the degree of error associated with using those methods would be far higher, no mater how experienced the person is. And for complete novices only relying on their eyes and ears, the % of error they would come up with would most likely be nothing more then a completely random guess.
    Case in point, try this experiment. Take a video camera and two splits of wood to some busy section of your local town, hand random people those two splits of wood and ask them to examine the wood with their eyes, and bang the pieces together and listen, then get them to tell you what the MC of the wood is. Just how accurate do you think they will be? 1%-5%? Not likely.
    Now do the same experiment but give them an electronic moisture meter and ask them to check the wood?
    I'm pretty certain the "inescapable conclusion" will be that the people with the moisture meters in their hands will have a lot easier time determining "accurately" the MC of that wood then those just using their "eyes and ears".
    PS, make sure you get it on video, I love being proved wrong. :emb:
  19. bearverine
    bearverine
    Winchester, Indiana
    At 13.95. From Harbor Freight, it's almost too cheap not to have one. And talking with wifey about m.c. has proven educational for both of us, as she always has questions, and I have to research the answers...
    HDRock and wildwest like this.
  20. Gark
    Gark
    SW Michigan
    I appreciate the article for its description of the % error of reading due to temperature and species. Never read anywhere before that info... good stuff to know. Thanks, Dennis.
    Even with a three-year plan and other evidence of dry wood, it's still fun to jab a device into the splits to satisfy that "instrumentitis" urge. Heheh.
