I found this quite interesting
Discussion in 'Chainsaws and Power Equipment' started by Woodrat1276, Mar 8, 2015.
  1. Woodrat1276
    Woodrat1276
    Ky
    does anyone here use carpide tipped chains.
  2. Dascro
    Dascro
    Southwest PA
    Impressive. Wonder how hard they'd be to sharpen once dulled?
  3. MasterMech
    Special ($$) diamond wheels on a grinder or I think I heard of one guy using a diamond file.
    thistle, Dascro and Duane(Pa) like this.
  4. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Fire Departments for rescue saws. If they were suitable for firewood they would be marketed for that purpose.
    Sunfish likes this.
  5. Woodrat1276
    Woodrat1276
    Ky
    No. The ones you are referring to are full carpide chains and no most fire depts don't use them. At least in my region and I've been doing it for 15 years.
    The above vid shows carpide tipped chains which in the vid obviously shows cutting cookies. Fire rescue saws are and assiocuated full carpide chains will not cut straight across the grain they designed to use just the tip of the saw which makes sense for ventilation purposes
    Fire depts around here don't fall into the hype of special built saws designed for rescue only. They just buy saws and use the same chains we do and run the hell out of the saw when it comes that time
    Loon likes this.
  6. haveissues
    haveissues
    Hudson Valley
    A tree service friend of mine keeps a loop on one of his saws in case he encounters a tree with junk in it. Old fences, nails, etc.
    Moparmyway likes this.
  7. MasterMech
    The rescue saws really aren't that much different than the base model. Of course the rescue chains and depth limiter are all available separately.
  8. Woodrat1276
    Woodrat1276
    Ky
    Hence what I said they don't fall for the hype. They beat the saws they have and replace with new ones when needed And they don't say fire rescue bs on them either. Usually just a mid level saw of what ever brand that has the closest dealer
  9. MasterMech
    Or fulfills state purchasing contracts/municipal bids. :);)
    Smokinpiney likes this.
  10. Woodrat1276
    Woodrat1276
    Ky
    Yeah some places might I don't get that far into it. here they just buy whatever's close. A couple are brand specific but it's not set in stone. It's really a small expense compared to everything else.
