project for the wife.
Discussion in 'The Smokehouse' started by Pallet Pete, Mar 1, 2015.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    New shelving unit for kitchen.
    Daryl, Horkn, Eric VW and 16 others like this.
  2. jetjr
    jetjr
    Pa/Md line
    Looks nice. I could see one of my kids climbing it now.:rootintootin: We could use some more storage space in our kitchen though.
    Horkn, Stinny, WeldrDave and 3 others like this.
  3. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I like those Pete. We have a narrower version in the laundry area and it holds quite a bit.
    Horkn, wildwest and Pallet Pete like this.
  4. wildwest
    I have a similar unit in my laundry room, it holds more weight than I thought! Nice use for the cast iron :)
  5. jetjr
    jetjr
    Pa/Md line
    I am thinking of making something to hang my cast on when I finish the kitchen. Might find an old piece of barn wood and some old hooks or nails.
    Horkn, Eric VW, mike bayerl and 3 others like this.
  6. Well Seasoned
    Great setup Pete! Commercial kitchens use 'em, so those metro shelves should last a lifetime!
  7. DaveGunter
    DaveGunter
    I like it. Nuthin worse than knowing you have the right piece of equipment and not being able to find it.
    I ran a commercial kitchen in a previous career, I used to hide stuff so I'd know where it was when I needed it.
    Horkn, Eric VW, Stinny and 5 others like this.
  8. Pallet Pete
    Ovid
    I hide it and its gone… :rofl: :lol: She hates the lack of counter space so we came up with this based on a friends setup. He has a calling pan hanger and it works great but we wanted more storage. The unit was $74.99 at Lowes so not bad. I do more cooking than here but lately thats been changing for various reasons so I thought it was time to give in...:emb:
    Horkn, Eric VW, Stinny and 2 others like this.
  9. papadave
    Nice setup Pete.
    I'd like to hang up most of the pans, but when I look in the kitchen, I can't see any room to do it. Maybe when we get around to redoing the kitchen, I'll make some room.
    All our pots/pans are in a base cab., and they all but fall out when I open the door.:headbang:
  10. My IS heats my home
    My IS heats my home
    Albany, NH
    Now thats a working kitchen PP. At first when I saw the thread title I knew it was food related, I was close
    Horkn, Pallet Pete and wildwest like this.
  11. wildwest
    We hung a rack from the ceiling in our previous house, close quarters so after bumping our heads on the pots & pans a few times I gave it away. If I had an island there I would have kept it. Just a thought :)
  12. My IS heats my home
    My IS heats my home
    Albany, NH
    We have a pot rack on the wall and it works well for us. I just did that section of wall over with some new cabinets and I'll replace the rack when I have the wall painted. It saves space and it's easy access.
  13. papadave
    I have a spot where that might work and I've thought of it a few times. My wife doesn't like my kitchen ideas too much, even though I'm the one in there 99.9999999999999% of the time using all the pots/pans. :headbang::stirpot:
    She makes sammiches most of the time.
  14. Woodwidow
    Would an overhead rack work with a pulley system to raise it when not in use and lower it to use it?
    Horkn, campinspecter and wildwest like this.
  15. TurboDiesel
    We have the same problem.
    this solved most of our kitchen storage problems
    I had a friend build this
    Horkn, mike bayerl, Chvymn99 and 3 others like this.
  16. Pallet Pete
    Ovid
    It would be really good if you had a hand crank with steel cable. Maybe an old boat trailer winch on the wall?
    Horkn and wildwest like this.
  17. Woodwidow
    You have been reading Campinspecter's clothesline threads!!!
  18. Jon_E
    Jon_E
    Southwestern Vermont
    I have a timber frame home so all of my cast iron and a fair number of vintage utensils pull double duty as decorations. I put up a bunch of wrought-iron hooks and nails and stuff is hangin' all over the house. The most-used stuff is closest to, or in, the kitchen.
    We have two of those wire shelves in our kitchen too, they hold almost all of the appliances, pots, pans, tongs, and a whole pile of other junk.
    Horkn, papadave and wildwest like this.
  19. Horkn
    Same here, stainless pot rack that mounts to a wall above our butcher block table across from the fridge and range/ oven.
    Great location for cooking, and saves space.
