nc30 chimney question
Discussion in 'Modern EPA Stoves and Fireplaces' started by Smokinpiney, Feb 20, 2015.
  1. Smokinpiney
    Smokinpiney
    "South" Jersey
    Does anyone have there nc30 vented into an 8" chimney? I've been thinking about replacing the old volcano in the basement with a standard cast iron or steel stove. Im tired of relying on electricity to run the dang blower. The nc30 seems to be a good candidate for my needs but I have an 8" ICC chimney. It's roughly 20ft vertical outside and 4ft horizontal inside. I don't have exact draft numbers but she pulls pretty hard, especially when it's this cold.
  2. Norky
    Norky
    I think the thing I'd be concerned about would be if the smoke temps cooled too much before they got to the top and created creosote. Might not be an issue, just the first thing that came to mind.
  3. fox9988
    fox9988
    NW Arkansas 72717
    24' of total chimney height? I would expect it to draft fine.
    ETA: I misread the OP. So, 20' chimney. I would try it. As Well Seasoned suggested, shorten the horizontal if possible.
  4. HDRock
    Not an NC30 , but my stove w 2.2cf box I have approximately 5' of 6" pipe and then 10' of 8" chimney, with no problems.
    BrowningBAR and wildwest like this.
  5. Well Seasoned
    Any way to shorten the horizontal? Can you take a pic?
    wildwest and fox9988 like this.
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    It's actually 22' vertical including the tee at the bottom. I could shorten the horizontal by ordering a 3ft section of double wall icc to replace the 4ft going through the foundation into the tee. I need the length outside to get out past the eave but inside i could spare a ft at least. No clearance issues as it's poured foundation walls on the side and back of the stove. My stove drafts just fine now, i was just worried about venting the 6" nc30 into an 8" chimney and having too much draft.
  7. DexterDay
    mike holton @Englander could probably answer this best.
    I would think you would be fine with that much vertical outside. The 30 is known to be a hot burner and probably part of the reason it burns so clean.
    I have 18 ft of 6" outside and 3 ft of vertical double wall in the basement and 4' of horizontal. And this stove will suck small kindling splits up the flue because of strong draft!! :rofl: :lol:
    Hoping Mike has a good answer for you.
  8. mike holton
    mike holton
    Old Dominion
    8 inch flue is ok with that stove , cross sectional value is 50.24 sq inches( 8XPiRsquared) so not outside of the 2X 6xPi R squared (28.26) so the flue is not too big for the unit.
    at 20-24 ft you should not have draft issues that i can see unless as an exposed flue if it cools too much as said above , with the strong draft you are seeing i doubt that would be an issue as well. if worried about too much draft you could install a key damper though they usually are not necessary in order to back it down a little.
  9. DexterDay
    Thanks Mike!! I love the Tagging feature!! :D
  10. Smokinpiney
    Smokinpiney
    "South" Jersey
    Thanks for the info mike holton. Im gonna keep my eye out for when they go on sale. Might just pick one up :binoculars:
    mike holton and Chvymn99 like this.
  11. rottiman
    4th burn season on my 30 and I love it....................
  12. Lovinwood
    Lovinwood
    NE USA
    Seems to be the consensus on your 30. From what we have read, it might just be the best stove for the money out there.
    Chvymn99 and Mitch Newton like this.
  13. clemsonfor
    Yea I was thinking I read something about the chimney should not be more that like 2 one 3x greater than the outlet so basically what Mike said.
  14. DexterDay
    4th burn season for mine as well and I love it! Solid heater that really cranks the heat!!
    The homemade convection deck really helps to extract a little more out of the stove. Being in the basement, I push the 30 pretty hard and this helps keep the stove top temp so it is livable.
