I must get a stove for next year and...
Discussion in 'The Wood Pile' started by capetownkg, Feb 25, 2015.
  1. capetownkg
    capetownkg
    southern, MD
    Well the plan is to use my tax return money to get a woodstove for the house finally. This harsh winter definitely drove home the need.
    First pic is of our electric usage compared to neighbors and what not. We are the blue line.:faint: 20150224_032950.jpg
    This morning i was drinking coffee and getting ready for work. It was about 20° outside and my heat is set at 62° inside. I like it cold when I sleep. But sitting there I was pretty cold. Took a thermometer to several of the windows, all original (30 years).
    So obviously by these pics it would behoove me to replace all the windows (24) in the house. Double :faint::faint::hair:
    Kitchen window
    Bonus room window
    Sorry about the long post just feeling frustrated but this is life and its one day at a time.
    So this is wood related here is some spoons i carved from firewood :D
    savemoney, Todd 2, milleo and 17 others like this.
  2. Paul bunion
    Paul bunion
    Definitely time for a wood burning appliance. $750 per year will be a good savings.
  3. papadave
    So, can we presume you have electric heat of some kind?
    Otherwise......holy cow!
  4. cnice_37
    cnice_37
    Is that wet spot on your bill from your tears?
    21 windows here, single pane from 1985 install. Time for mine to go too.
  5. capetownkg
    capetownkg
    southern, MD
    Yea papadave. I have electric heat. My thermostat doesnt go above 68 and goes down to 62 at night. Still had a 400 dollar electric bill last month. Its only my wife and I, I do my part to turn off lights and electronics when not in use.
    reelcrzy, Horkn, Shawn Curry and 5 others like this.
  6. papadave
    I think I'd just move or something.
    We've got electric stove/oven and dryer and man, are they ever hogs.
    Oh, and I don't know when our 22 windows were installed, but 18 of 'em are single pain:) with storms, and the other 5 just absolutely and completely define the term SUCK.
    How big's the house? Got a stove in mind?
    Nice spoons too.
  7. WeldrDave
    I'm not to far away from you as the "crow" flies, and My highest electric bill has been $183.00. My whole house is electric but the heat hasn't been turned on in 30+ years. I blame $83.00 of that electric bill on my Daughter and her 30 minute steamer showers! when she's home on the weekends. Yes Buddy, you need a stove! Go to the flouresent bulbs in your lamps or L.E.D. , They are more expensive at first but pay down the road! It's not your lights so much as it is your refridge, Water heater, and close dryer. I work with two AC/R guys here in the CG and since I've pulled my refridge away fron the wall just 4" I have noticed a difference in the running times and slight change in my bill. You also need to keep the back area clean as best you can. I have three dopey dogs and the hair builds up quick!o_O For the record, my neighbor two houses away from me, "all electric" had a $765.00 bill :eek::startled:
  8. wildwest
    saran wrap on windows?
    Deacon, Horkn, Shawn Curry and 4 others like this.
  9. papadave
    I've had fairly good luck with the shrink window film.
    Helps keep the drafts down, and some of the cold.
    Sitting here noticing cold coming from the window behind me. The trim is probably covering a nice gap that didn't get insulated well. Pretty typical for this place.:headbang:
    savemoney, Horkn, Shawn Curry and 3 others like this.
  10. capetownkg
    capetownkg
    southern, MD
    Its 1900sqft or so. If i get an insert a osburn 2400 is the one and if its a free standing probably the nc30 with chopped legs so it will fit.
  11. wildwest
    FWIW, I like free standing better than my insert.
  12. My IS heats my home
    My IS heats my home
    Albany, NH
    :eek:, saran wrap??
    Horkn, tuneighty and wildwest like this.
  13. My IS heats my home
    My IS heats my home
    Albany, NH
    You can always hang out your laundry Dave, is there any room in the basement?
    Horkn, Shawn Curry, wildwest and 2 others like this.
  14. wildwest
    :picard:womanspeak:rofl: :lol:
  15. papadave
    I'd get at least a 3 cu. ft stove. Unless your house is fairly tight (sounds like it may not be), anything less might be a disappointment if you're trying to heat the whole house.
  16. papadave
    Yeah, we've done the laundry hanging in the stove room trick.:thumbs:
    No basement.
    The elec. use is usually under 400 Kwh/month and would be less if I could get others to be a bit more aware of their habits.
  17. Backwoods Savage
    I'd say that would be making excellent use of the tax return. For sure I know I could not live in a house with those temperatures. Don't mind it cool when sleeping but still like to get up to a warm house.
    Replacing that many windows can add up to a lot of dollars. I remember years ago when every fall I'd make "storm windows." It was a bit time consuming but still made a big difference in the comfort of the home. You might try replacing just a couple of them each year rather than doing the entire thing at once.
    On the other hand, please go to this link: http://firewoodhoardersclub.com/forums/resources/primer-on-woodburning-by-backwoods-savage.6/
    Click on the "Download Now" button and you'll get a pdf file. This can help you a lot. In addition, if you plan on burning wood next fall, you should have that wood already cut, split and stacked out where the wind can help to dry it. Be careful what kind of wood you get the first couple years until you can get yourself ahead on the wood supply. Good luck.
    Shawn Curry, wildwest and papadave like this.
  18. jetjr
    jetjr
    Pa/Md line
    I get the same kind of graph and mine is always higher than the neighbors. They estimate our bills here a lot and I know a lot of my neighbors have propane or oil heat. My windows are junk as well, but u only just recently turned my heat breakers back on for the wife, so she doesn't have to fool with the stove in the morning when I work night shift.
    WeldrDave, splitoak and wildwest like this.
  19. wildwest
    :jaw:
  20. papadave
    Um, huh?
    WeldrDave and wildwest like this.
