FHC novice here....
Discussion in 'Chainsaws and Power Equipment' started by D2082, Feb 24, 2015.
  1. D2082
    D2082
    VA
    I joined this site and have been reading threads now for about a month and just wanted to thank you all for all I've learned so far. Your threads are very informative and even though some of the abbreviations are German to me I've picked up on a lot already. My wife and I are building a house and are installing an OWB so I'm about to be neck-deep in firewood cutting. Other than helping my Dad cut firewood growing up I've never been been into cutting much wood (or had to). Bought an MS362 and am ready to get to work. Always liked it just have never had to do it for myself. I've followed a lot of Masterminded's posts and it's got me interested in that process. I know I don't "need" it but how much do we "need" anything that we have right?
  2. TurboDiesel
    Welcome D
    Thanks for introducing yourself
    Good bunch here
    Chvymn99, Horkn and D2082 like this.
  3. lukem
    Nice saw choice. It will serve you well making firewood. Don't wait for the boiler to be installed before you start cutting.m..get started ASAP. Don't forget the PPE. Real men wear chaps.
  4. JRSDWS
    JRSDWS
    Central Illinois
    Welcome D2082!! You need it...and you don't even know it yet...but you need at least 3 more too!!!
  5. D2082
    D2082
    VA
    Have been lookin at that stuff. Def need it for sure, especially being pretty unexperienced with it all. And this saw is a beast!
    Chvymn99 and Horkn like this.
  6. Moparmyway
    Moparmyway
    New York
    Welcome to FHC !!
    That saw is your first. Its a good one, take good care of it and it will serve you well.
    I predict that it wont be long before you realize that you need a few chains ..................
    Then you will feel like you need a back up saw.....................
    Then you will feel like you need a few saws, and since you already threw out Mastermind, the ported saw will be in your stable before too long as well
    Chvymn99, HDRock, mdavlee and 2 others like this.
  7. D2082
    D2082
    VA
    That's what I'm thinking.... May wait til this house is done though - not sure if I worked it into this construction budget! I assume you've had yours worked on?
    TurboDiesel and Horkn like this.
  8. D2082
    D2082
    VA
    Yes I would say you're right. I've got a Husky 262xp and Jonsered (2150, I believe?). I inherited them so not 100 % sure.... Thanks for the welcome! I like this site.
  9. Well Seasoned
    Welcome D2082 ! Definitely get PPE....... If we knew when accidents would happen, they wouldnt be accidents.
    HDRock and Horkn like this.
  10. D2082
    D2082
    VA
    Good advice. Going to build a woodshed and cover for the boiler with leftover lumber from the house. Lots of poplar, wild cherry and locust on the land, but have access to some good hedge apple (or I learned on here that's it's called Osage orange too - never knew that).
    Horkn and mdavlee like this.
  11. dgeesaman
    dgeesaman
    Elizabethtown, PA
    MM is full of great information.
    The 362 is a top notch saw that should serve well as long as you're not working logs 3+ feet across.
    Cutting wood (safely) takes some patience and practice, as does felling and splitting. I'd start with laid-down logs first, work you way up to felling easy standing timber, then finally (if necessary) taking on leaners and hung up trunks. Sharpen the chain often and keep the ethanol out of it. Get wood cut, split, and stacked because there is no such thing as too dry. (And just because a tree is dead does not mean it's seasoned!). A woodshed is nice but getting it elevated and covered works really well too.
    Some of the useful tools to consider:
    Cutting: Saw, filing kit, safety gear (helmet, chaps, gloves. I strongly recommend Ansell cut-resistant gloves), wedges
    Moving wood: truck / UTV / tractor / ATV / skidsteer / whatever. Trailer / drag / tractor loader / pickup bed, whatever works for you.
    Splitting: Splitting axe / splitting maul / wedges & sledge / powered splitter.
    Felling: wedges / ropes / winch
    You'll notice that wood is really heavy stuff. This means you don't ever want to be in between a piece of wood and gravity, even if it's just rolling toward you. It's also valuable to work toward a system that involves the least handling and movement.
    These are a few of the lessons I've learned since I got started this past year.
    David
    D2082, Chvymn99, HDRock and 1 other person like this.
  12. D2082
    D2082
    VA
    Thanks! Appreciate it. And thanks for the advice.
    Well Seasoned and Horkn like this.
  13. Horkn
    Welcome to FHC D2082!
    You've got a great start saw wise.
    D2082 likes this.
  14. Woodchuck
    Woodchuck
    Southeastern Ohio
    Welcome to the club! Lots of good conversation here, please share what you know. Oh yea...we like pictures :ithappened:
    Chvymn99 and D2082 like this.
  15. D2082
    D2082
    VA
    David[/QUOTE]
    David[/QUOTE]
    Thanks David. Appreciate that. Luckily I've got access to most of the equipment. It'll just take getting started to see what I lack and best ways to get it done safely. Thanks again for the post.
  16. lukem
    Get all the hedge. All of it. Especially with a boiler setup.
  17. D2082
    D2082
    VA
    Thanks. Love that thing. I've got a couple of pics on AS gallery but am trying to get them loaded on here now.
    Horkn likes this.
  18. HDRock
    D2082 likes this.
  19. lukem
    It's pretty alright. I am biased though.
    Elderthewelder and Horkn like this.
  20. HDRock
