Hopper Slide Issues
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by IHATEPROPANE, Feb 23, 2015.
  1. IHATEPROPANE
    IHATEPROPANE
    What techniques, if any, do you use to help the pellets slide down the hopper. Both of my stoves could be better in this area and I may get myself to do something. My current thoughts are between a graphite spray or high temp aluminum tape (600℉). Any thoughts or ideas?
    wildwest and ivanhoe like this.
  2. jtakeman
    I used pledge(on a cold stove) and it help greatly. I plan on scotch brite-ing the hopper(one of these days-yep hasn't come yet).
    wildwest, ivanhoe and IHATEPROPANE like this.
  3. ivanhoe
    ivanhoe
    Northern Ontario
    X2
    My Harman would build up a residue with time. Hopper gets really hot on one side which melts the resin of the pellets:mad:Which pellets you use makes a difference, softies has more resin. Sticky pellets is another culprit.
    wildwest and IHATEPROPANE like this.
  4. ivanhoe
    ivanhoe
    Northern Ontario
    Scotch brite-ing meaning using a green scour pad. If yes, I do not recommend it. I've use the pad to clean the chrome racks inside the kitchen oven and it would scratch the chrome off to a dull looking sink appearance with fine scratch marks. It might work inside the hopper, trial & error!?!?
    wildwest, IHATEPROPANE and jtakeman like this.
  5. imacman
    imacman
    Denver, NC
    IHP, I used foil furnace tape on all the corners that lead down to the auger. Along with that, I sprayed Behold furn. polish on all the flat surfaces and buffed them good. Seemed to help some.
  6. jtakeman
    Yeah, I wouldn't use the Green or Red. I would use the white or grey pads. They are finer grit IIRC.
    My hopper is galvanized and the surface is pretty rough. Just trying to lightly polish the surface a tic. Most pellets are fine and slide without issues. The dusty pellets seem to be the best. Coarse pellets are the ones with slide issues in my heap. So really not an issue unless I get pellets that have a coarse texture.
    I might try the aluminum tape in the corners and the lower portion. That's seems to be were they stick the most. BTW imacman(pete) is where I got the furniture polish trick from many moons ago!! ;)
    gbreda, will711, wildwest and 3 others like this.
  7. imacman
    imacman
    Denver, NC
    An oldie but a goodie. :thumbs:
    gbreda, ivanhoe, will711 and 3 others like this.
  8. eatonpcat
    You or the trick??
    ivanhoe, Gary_602z, will711 and 4 others like this.
  9. imacman
    imacman
    Denver, NC
    Both!! :rootintootin:
    ivanhoe, will711, wildwest and 2 others like this.
  10. Horkn
    Sounds like a better industrial coating is needed than what comes from t he factory. Maybe an industrial plating business can help you guys out with a permanent solution? Black hardcoat? Maybe with a silicone impregnated finish to reduce sticking and proper sliding?
    ivanhoe, wildwest and IHATEPROPANE like this.
  11. imacman
    imacman
    Denver, NC
    Teflon?
    ivanhoe, Horkn and wildwest like this.
  12. Lousyweather
    Lousyweather
    tape a vibrator to the side of the bin, put it on a timer.....say, one minute on per hour? Or, you could install a proximity sensor, and have it turn the vibrator on....would probably have to be an electric model, rather than battery operated, maybe a big one (might look funny attached to the side of the bin, but sure would be a conversation piece!).....you probably also don't need to spring for the ones in certain colors or shapes, with rotating beads, etc.....just a thought.....
    :eek:
  13. imacman
    imacman
    Denver, NC
    I'm not going anywhere near this topic......:picard:
    T-BONE, ivanhoe, slvrblkk and 2 others like this.
  14. Horkn
    Teflon, silicone, and vibrators. Oh my!:rofl: :lol:
  15. subsailor
    subsailor
    Winthrop, Maine
    You guys aren't OCD enough. I can't walk by the stove without opening the hopper and smoothing the pellets. That takes care of the issue for me.
  16. will711
    will711
    Pocono Mts.
    You seem to be very informed about these :whistle:
  17. ivanhoe
    ivanhoe
    Northern Ontario
    IHATEPROPANE likes this.
  18. Lousyweather
    Lousyweather
    Idem ad vos
    ivanhoe likes this.
  19. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Yup, same here. A look in the hopper and a smooth out does the trick for me
  20. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    That's the sign of a great relationship and a very happy man!
    :D:D:D
