Hot water cost
Discussion in 'Everything Else (off topic)' started by savemoney, Feb 21, 2015.
  1. TurboDiesel
    Yes if your heating the house with a heat pump in a cold climate they are less efficient but this is a water heater sitting inside your home. it is picking up room temp air and extracting the heat out of it to make hot water thus cooling the room air slightly
  2. TurboDiesel
    it may take a few hours to heat the water this way . HPWH (heat pump water heaters) are a hybrid system. if you need more hot water or quick recovery the electric elements kick on to speed things up
    wildwest and Triple A Arsenal like this.
  3. wildwest
    thanks! :thumbs:
    TurboDiesel likes this.
  4. wildwest
    I bought a GE dishwasher that wasn't right. They sent a new one out for me. I have renewed faith in GE.
    raybonz and Triple A Arsenal like this.
  5. crzybowhntr
    crzybowhntr
    WV
    Unlimited
    TurboDiesel and wildwest like this.
  6. Certified106
    Certified106
    In The Hills
    The heat pump water heaters seem like a great idea in theory but there are a lot of parts to go bad on them. Coming from a guy who does HVAC I would be very Leary that the initial cost saving wouldn't t hold up in the long run.
    wildwest and raybonz like this.
  7. DaveGunter
    DaveGunter
    I should add that we weren't heating the water with electricity prior the the HPHW, so the $10-$15 a month increase in the electric bill is how much it's costs total to run the HPHW per month.
    I live in Maine, and my HPHWH (stiebel Eltron) is in my basement and it does fine. I do heat my basement though. Total cost to heat the water per month is never more than $15. My unit is not a hybrid like the GE, it does have a resistive booster but it never kicks on. It has a large (80G) super insulated tank, so I set the temp very high, 170f and use a mixer valve to supply 115f to the house, also if you plumb in at least a 24" drop you won't be constantly losing heat from the tank due to heat siphoning.
    wildwest and savemoney like this.
  8. Fanatical1
    Fanatical1
    I have a Geospring since 2012 and it works really well in my situation and uses about half the electricity of a conventional electric hot water tank, but here's the catch, it really depends on your specific situation as to if you will like it or not.
    - it expels cold air and needs a reasonably large space to be located in. If you have a small enclosed room, it won't work well, a warm basement or something similar would be ideal.
    - the recovery time is slow in heat pump mode. It does have traditional heating elements so it can be set to use those when needed, but we find the slow recovery time is not an issue, we just are aware of it.
    - yes, it does counteract energy used for heating your home if you have it in a heated part of the home versus your basement etc..it will also help cool and dehumidify your home when running your air conditioner. I heat with wood, so I my firewood now helps heat my water. You can always use it in the standard electric resistant setting if you don't want the heat pump running. No noise or cold air expelled when operated like this.
    - you need a condensate drain for the heat pump since its removing water from the air when operating in HP mode.
    - it makes noise in heat pump mode, similar to a small window air conditioners or dehumidifier.
    I bought mine for $899.00 At Lowes and our electric company, AEP, has a $500 rebate on top of that, so $399 plus tax. Can't beat the price for a well insulated tank that can operate in both heat pump mode or standard electric resistance. Mine has already paid for itself.
    I think it can make sense if you don't have natural gas available to you . You also need the right location to locate it, this is critical to your satisfaction. I have mine in a utility room. We leave the door to that room open and it does dehumidify and cool our home slightly.
    It really does use half the electricity if it has reasonably warm air to draw from, but it's not for everyone.
    This guy does a good explanation.
  9. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Yeah you need to have the correct conditions, especially a heated room where the tank is or it's not ideal.
    fanatical1 explains it must be the right situation.
    wildwest, savemoney and Certified106 like this.
  10. IHATEPROPANE
    IHATEPROPANE
    Have you ever seen a cabinet cooler?? Google Vortex tube. I am not sure how similar the technology is but it basically splits air into a hot and cold. There's a lot of cool stuff people have figured out.
  11. 343amc
    343amc
    Northeast Lower Michigan
    That was a concern I had also. When I bought mine, Lowes was offering a 10 year warranty for $99. I bought the warranty, figuring that I'd get that money back at some point in 10 years.
  12. fox9988
    fox9988
    NW Arkansas 72717
    That's what I was thinking. I you heat with electric, are you gaining efficiency (in the winter)?
    The Energyguide label appears to show that it will only save you $44 a year compared to the least efficient similar model.?
    http://pdf.lowes.com/energyguides/084691228998.pdf
  13. basod
    basod
    Mount Cheaha AL
    If you heat with electric you'll lose efficiency.
    It's the same for anyone heating with electric - going to a more efficient appliance or CFL's & LEDS you're no longer putting off the wasted heat at the appliance and your heat source if baseboard electric, central air heating element etc. has to make up for the difference.
    wildwest, Certified106 and fox9988 like this.
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    I have a tempering valve at my tankless coil and haven't had this problem.. When the tempering valve fails I end up with luke warm water.. For hot water setting I have the furnace operate at 140 degree water jacket temp and if heat is needed (which is rare) the furnace water jacket goes up to 195 degrees but the tempering valve still keeps the hot water at 120-130 degrees.. Wondering if your tempering valve was bad?
    Ray
  15. basod
    basod
    Mount Cheaha AL
    wildwest and fox9988 like this.
  16. fox9988
    fox9988
    NW Arkansas 72717
  17. Backwoods Savage
    It is possible Ray. However, I know of many others who bought this same unit and all of them did it. Funny, that guy went out of business in his second year....
  18. Fanatical1
    Fanatical1
    Your correct that some/most of the savings will be lost in your situation during the winter months if you use electricity to heat your home and you locate it in an area of your home that you heat versus an unheated basement. I use firewood to heat my home, so my situation is different. The warmer the surrounding air is, the more efficient a heat pump becomes in removing the heat from the air around it. This situation is slightly offset during the summer months because your HP will aid your air conditioner in cooling and removing moisture from the air.
    The energy guide you show is comparing the Geospring to other heat pump hot water manufacturers, not to a standard electric resistant hot water tank. A traditional electric tank for a family of 4 uses just over 5,000 KWH/year so your saving roughly $300.00/year or more depending on what you pay per KWH for electricity.
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    Hmm you have to wonder .. The reason I stay with the tankless is I still have the furnace for backup and the generator can handle the furnace and well pump otherwise I'd consider a change (can take a warm shower :) ).. When it was below zero I did run the furnace a little bit to get the house to temp and that didn't take long so the woodstove could take over..
  20. fox9988
    fox9988
    NW Arkansas 72717
    Me too, 100% :yes:. Just forming a question, but thanks for the response.
    savemoney, Fanatical1 and wildwest like this.
