Burn Pot Buildup!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by brokenwing, Feb 14, 2015.
  1. eatonpcat
    Did you see the cut into the piece on the left?
    wildwest and ivanhoe like this.
  2. shaggy wood dump hoarder
    menomonie
    Yea i saw it not entirely sure how i would re fab it. Do you think you could send me the old one and I'll get you a new one made up
    wildwest, ivanhoe and IHATEPROPANE like this.
  3. shaggy wood dump hoarder
    menomonie
    Or at that i could make a couple of them stainless or mild steel
  4. eatonpcat
    If I would have kept the old one, that would be great. If I order a new one (which I will have too) I will send you the old one.
  5. shaggy wood dump hoarder
    menomonie
    If you don't mind me asking how much do they want for a new one? How long does it last you?
  6. eatonpcat
    The cheapest I've found is $111.00. Looks like they're are lasting about 18 months or 1.5 burning seasons.
  7. shaggy wood dump hoarder
    menomonie
    Oh wow that's plenty. I can definitely do it for less than that in stainless to if i can figure out how to make the end
  8. DexterDay
    I was curious as to how the end looks as well. You can't see much on that pic, and it looks like it needs to be pretty precise to work.
    Sounds as if you could save some money here. I have a friend at work that makes his own agitators. His last a couple years in his Breckwell.
  9. StihlHead
    StihlHead
    The wild west
    Burn pot buildup?
    Towelie says "Oh no!" Time to clean out the bong!
    Sorry, weed is legal now here in Oregon and Washington...
    Skier76, ivanhoe, will711 and 2 others like this.
  10. eatonpcat
    Not sure why mine cook up so fast...When I order a new one I will definitely get the old one to shaggy for a trail run (Worth putting some money into a prototype if he can figure it out). It does seem to be a fairly precise end cut as it turns onto something when you install it. Found a picture that shows the end a little better.
  11. shaggy wood dump hoarder
    menomonie
    I should be able to make a template and plasma cut that right out. Only other concern is the tapered ends, is it tapered? It looks like it is in a few pictures, is it tapered for a reason that you can see? Clearance to fit into burn pot ends? That agitator is quite different from my dad's lol he had 7beaters on a solid rod with the one end ground flat inn the middle and a simple pin hole drilled into it for a cotter pin to slip through. I'll definitely figure something out though! Oh and btw sorry for this post getting!:Yar:
  12. eatonpcat
    It is tapered...Not sure why, but it needs to be smaller on that end.
  13. shaggy wood dump hoarder
    menomonie
    Nothing a grinder won't fix
    wildwest, ivanhoe and eatonpcat like this.
  14. jtakeman
    I got one of the original agitators for my Omega and its a weldment. I'll snap a few pic's for ya. I can also do some measuring.
    Pretty sure the drive end could be reused if need be. It stays out of the burn pot and should have any wear. No reason a coupler of sorts couldn't be used to connect them? I could see a something like a round sleeve that has a hole for a cotter or roll pin. The stove owner can cut his old shaft. Insert it into the coupler and drill one hole to insert the pin. Might be the easiest route?
    wildwest, ivanhoe, Spock and 4 others like this.
  15. shaggy wood dump hoarder
    menomonie
    A very rough drawing of the hook up my dad has. Drawing of the beater and rod coming out of motor and a flipped down view 1424286411344.jpg
  16. DexterDay
    Is he running an old Magnum Countryside 3500? Those are great stoves!
  17. shaggy wood dump hoarder
    menomonie
    I'm not sure what it is but I'm pretty sure the one in his garage is the same as the one in the basement. I made him 3 mild steel beaters and a stainless beater.
    ivanhoe, wildwest and eatonpcat like this.
  18. Spock
    Spock
    MA
    Looks like that end could recreated with some simple tools. I would use a chamfer bit to create the bevel on the cup then use a rounded grinding wheel to create the catch and the cut on the opposite. Probably need a jig to keep that catch angle.
    ::edit :: and thinking a little further, the catch end could be made using a collar that slides over the agitator shaft. Set it with weld or use stainless set screws to secure. Then like jtakeman suggested you could just replace the agitator since the catch end doesn't see much action.
  19. Skier76
    Skier76
    CT and SoVT
    Jayman,
    Interesting pics! Did you get buildup on the outer edges of the liner? I seem to get carbon there more than the other areas of the liner.
    wildwest, ivanhoe and jtakeman like this.
  20. jtakeman
    My biggest buildup is usually this area. Since I have drilled holes near the igniter port.
