For Sale Deluxe Folding Sawbuck
Discussion in 'FHC Classifieds' started by Shawn Curry, Feb 13, 2015.
  1. Shawn Curry
    Shawn Curry
    Western NY
    IMG_1195.JPG IMG_1812.JPG IMG_1809.JPG IMG_1806.JPG IMG_1701.JPG IMG_1702.JPG
    I know many of you have seen my sawbuck before - now here's your chance to own one! All this snow has me stuck inside with a bad case of woods withdrawal and CAD. So I need something to keep me busy and help pay off my chainsaw addiction!
    I have an extra one of these on hand from the last batch I made. I was going to keep it for myself but I never got around to putting it together. So I'd be ready to ship it out right away.
    The kit will include everything required for assembly (you provide the drill and mallet :))
    For an extra $20, I can add the FHC logo with a wood burning pen.
    Features:
    • Classic sawbuck design
    • Half-lap joinery
    • Wooden construction is easy on chains
    • Offset center leg
    • Lightweight - under 35lbs
    • Improved folding ability
    • Higher toe kick takes less damage and lets you work closer to the log
    Specifications:
    • Width (total): 46"
    • Width (short side): 16" OC (or let me know your firewood length!)
    • Width (long side): 24" OC
    • Height (folded): 45"
    • Height (open): 38.5"
    • Height (crotch): 28"
    • Max working load: Chuck Norris size
    • 2x4 construction
    • 1/2" bolts, 2-1/4" screws, and glue included
    Price:
    • $125 + shipping (35# from 14012 - if you have a "commercial" address to ship to it's about 30% cheaper!)
    • Stain - light or dark - $10
    • FHC logo: $20
    In Stock:
    • 1 - unstained, no logo
  2. Shawn Curry
    Shawn Curry
    Western NY
    Well the first one has been spoken for, but I'll have another one available in a couple days! :)
  3. clemsonfor
    How the heck do you get the logs into it?
    I cut mostly oak. Thats pretty tough to get a 15" like 7 foot long oak log into one of those!!:eek:
    Is it faster to cut like that vs on the ground considering you have to lift the wood? I can see for really small stuff though.
    papadave and Shawn Curry like this.
  4. Shawn Curry
    Shawn Curry
    Western NY
    I'd buck a 15" shorter than 7' when I'm cutting up the tree. I have to get them up on my trailer in the first place! Once they're up on the trailer though, I'm home free. You can see in the action pics: my trailer is about the same height as the horse, so I can just slide em right onto it at that point.
    I find its much easier on the back and the chains to have em up off the ground. :)
    Eric VW likes this.
  5. clemsonfor
    I generally cut most of the way through then roll the log and finish from the other side. Course several cuts have to be made all the way through so I can roll it in the first place
    papadave, Kg461 and Shawn Curry like this.
  6. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
  7. Stinny
    You've spent some time putting all of this together Shawn... :yes: I have no doubt they'd be worth every dime you're asking.
  8. Stihl Livin
    Stihl Livin
    Minnesota
    I'm excited to get my new sawbuck this week. Hopefully it will warm up so I can try it out with my mastermind 064.
    Eric VW, Loon, concretegrazer and 5 others like this.
  9. DexterDay
    These are a quality piece to own!
    I love mine!! Thanks again Shawn!! :D
    Eric VW, raybonz, HDRock and 5 others like this.
  10. Deacon
    Deacon
    Eastern Nebr.
    Love mine too!
    Very well & PRECISELY made. The fit $ finish is excellent.All hardware & glue is provided
    Crotch sits 26 inches off the ground.
    Folds almost flat. Optional FHC logo is great.
    Handy for those glamour shots!
    Very nice work Shawn
    Eric VW, raybonz, papadave and 9 others like this.
  11. DexterDay
    Great pic!!!
    Eric VW, savemoney, raybonz and 5 others like this.
  12. gary courtney
    gary courtney
    texarkana,texas 75501
  13. Shawn Curry
    Shawn Curry
    Western NY
    It looks like Stihl Livin should be getting a delivery tomorrow, so I thought I would include some assembly instructions here. I posted some similar instructions on my build thread a while ago - that goes into how I make them, if anyone wants to check that out: http://firewoodhoardersclub.com/forums/threads/sawbuck-build.5730/http://firewoodhoardersclub.com/forums/threads/sawbuck-build.5730/
    You'll need:
    The legs are all identical, but each of the rails are unique. Arranging them this way helps to visualize where the legs go.
    It's best to stain the parts prior to assembly, so do that first. Next, apply the glue and assemble each half. It's best to lay the rails down with the notches up, and insert the legs one at a time. I moisten the rail, and apply the glue to the leg on all mating surfaces of the joint. The joints may be a tight fit; make sure they are fully seated, using the mallet if necessary.
    Next, flip the assemblies over, pre-drill and drive 2 screws into each joint. Notice how the overhang of the rails is longer on one side. Make sure the "outer" legs get the longer overhang.
    Allow the glue to cure, then stand up the 2 halves and bolt them together. Leave a gap between the legs at first so you can locate the bolt holes.
    And that's basically it! Go make firewood! :saw:
    Eric VW, raybonz, Loon and 2 others like this.
  14. Stihl Livin
    Stihl Livin
    Minnesota
    I'm missing something here. It looks to me the outer leg gets the shorter over hang.
    Shawn Curry likes this.
  15. Shawn Curry
    Shawn Curry
    Western NY
    Sorry - what I mean is, when you line them up to bolt the two halves together. The outer leg needs to rest on that longer rail. Basically, if you bolt the legs together the wrong way, the overhang won't line up.
    [EDIT] You should probably just ignore the words and look at the pics. I'm doing a terrible job explaining this! :rofl: :lol:
    clemsonfor and eatonpcat like this.
  16. DexterDay
    Yep. You will notice right away. They should be equal lengths when bolted.
    I didn't read his thread when I assembled. I fixed it the following day.
    If you did. It wrong? The ends won't be even. This is after I fixed. I erased all my photos of when it was built the wrong way.
    Eric VW, HDRock, HoneyFuzz and 2 others like this.
  17. SquareFile
    SquareFile
    somewhere
    Shawn built Dex's custom for him.......couple inches lower :drunk:
    MasterMech, jon1212, Eric VW and 9 others like this.
  18. eatonpcat
  19. DexterDay
    :rofl: :lol: :smoke::saw::dancer:
    Eric VW, raybonz, HDRock and 4 others like this.
  20. clemsonfor
    I almost spit my drink out when I read this!!:rofl: :lol:
