440/460 hybrid
Discussion in 'Chainsaws and Power Equipment' started by Kg461, Feb 11, 2015.
  1. dgeesaman
    dgeesaman
    Elizabethtown, PA
    This might be too nice to cut with!
    Kg461 likes this.
  2. Moparmyway
    Moparmyway
    New York
    Whats that dark grey spot on the flywheel side of the side wall on the intake close to the cylinder. Looks like the intake got real thin there and you filled the hole with JB
  3. Moparmyway
    Moparmyway
    New York
    Do you remember how much came off the base ?
  4. Kg461
    Kg461
    Provencal, La.
    Dont have a clue. Something in the metal that was harder than the aluminum around it that polished out shiny compared to everything around it. Its not jb weld. I didnt take enough out to get close to the outer wall
    Moparmyway likes this.
  5. Kg461
    Kg461
    Provencal, La.
    I dont. I sanded until I got .020 clearance
  6. Kg461
    Kg461
    Provencal, La.
    Definetly not. I didnt widen the port at all so that spot is almost where factory was. I usually take out way more than I did on this one. I didnt hardly widen the intake or exhaust
  7. DexterDay
    Looks great and sounds great as well..
    I need another 440 :(
    Nice job Keith! ! :thumbs:
    Moparmyway, Chvymn99 and Kg461 like this.
  8. Kg461
    Kg461
    Provencal, La.
    I need a cylinder and a fuel tank for another 440 I have. Ill probably build it stock and sell it
    DexterDay likes this.
  9. Moparmyway
    Moparmyway
    New York
    Sounds good, but the spot above the word "Here" looks wierd. The saw does run like its pretty angry !!
    Kg461 likes this.
  10. Kg461
    Kg461
    Provencal, La.
    Definetly not. I use a light touch with a double cut burr for final finishing and that spot was harder than the aluminum around it and the lighter the touch on that spot it just got shinier than the aluminum around it. Jb weld wont polish!! Lol! Almost like nikasil got on it
  11. DexterDay
    That looks like a small air pocket in the casting to me?
    Kg461 likes this.
  12. Kg461
    Kg461
    Provencal, La.
    Solid as a rock
  13. SquareFile
    SquareFile
    somewhere
    Its an non metallic inclusion. Typical for any castings. Not always visible.
    1128 hybrid is my favorite firewood saw
  14. Kg461
    Kg461
    Provencal, La.
    What does that mean squarefile? Is it aluminum? Seems much harder. Burr just didnt want to cut it but just shined it
  15. SquareFile
    SquareFile
    somewhere
    It can be anything of different material. Usually its pieces of filters, but will have honey comb shape. Could also be sand which is bad but picks out easy.
  16. Kg461
    Kg461
    Provencal, La.
  17. SquareFile
    SquareFile
    somewhere
    Hard to tell but looks like a gas pocket. Indented and smooth?
  18. Kg461
    Kg461
    Provencal, La.
    Whatever it is hard as a rock, metallic, and didnt want to cut with a burr. Just shined alil whatever it is
  19. SquareFile
    SquareFile
    somewhere
    Its considered non metallic. If it were me, I would pick at it. If firm leave it. If loose dig it out and fill with the silly puddy
    Moparmyway and Kg461 like this.
  20. Kg461
    Kg461
    Provencal, La.
    Ill take cylinder back off and check it out
