Sealing hole in concrete outside?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Triple A Arsenal, Feb 12, 2015.
  1. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    What did you guys use to fill the gaps around the exhaust that exits the house on the outside?
    I went out to make sure exhaust was clear from snow and noticed black soot on the vinyl siding. Also see I didn't fill around the exhaust with anything on the outside.
    The inside I filled with high temp caulk but I remeber I ran out. That stuff had to be ordered.
    I don't think anything caulk related will dry in these cold temps unless the exhaust heats it.
    ivanhoe and wildwest like this.
  2. PoolguyinCT
    PoolguyinCT
    Depends.. Throw up a pic of inside & out of penetration.
  3. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Yeah I will take some when I get home
  4. Lousyweather
    Lousyweather
    black soot is likely NOT a sealing issue, rather, cleaning of the pipe and stove, OR the quality of your pellet
  5. krooser
    krooser
    Waupaca, WI
    I did a quick cleaning of the house stove a couple days ago but it seemed that the flame on anything but #2 was getting a little lazy. Yesterday I unloaded some pellets into the house and noticed the screen on the exhaust cap was nearly plugged with soot. Did the LBT but that didn't do a 100% fix so I have to go back in the stove and clean it a little better.
    The last couple of weeks I've been using Marth hardwood pellets because they are easy get at my local Fleet Farm but they are hardly my favorite pellet… way too ashy. All that soot confirmed that the stove is plugged with ash…
  6. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Yeah I changed over to Greene Team Platinums. They are hardwood and I noticed they are more ashy but much hotter. I had to clean the furnace a week after burning them. About 10 bags and there were fines EVERYWHERE. So much the fines on the side caught fire and we're just burning. I saw that and cleaned it after cool down. The ash in the furnace was nice cream color though.
    I am going to try the LBT, I also have 1/4" mesh screen on the end cap that looks sooty. I'll remove the mesh as it could be causing buildup. The manual said 1/4" was ok but nothing smaller
    ivanhoe likes this.
  7. T-BONE
    T-BONE
    I was told not to have the mesh cap on in the winter.
    just put it back on in the spring time.
    ivanhoe likes this.
  8. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Took it off just now! Thanks.... Here are some pics before I took off mesh. It was lightly covered, it was not much. I did follow specs in manual regarding distance off ground and away from house!
    Looks like I siliconed the end cap so it's not budging when I twist it. You can see in the last pic:doh:
  9. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    I was watching the exhaust, looks like it hits the floor and bounces back up:picard:
    wildwest and ivanhoe like this.
  10. badbob
    badbob
    Well it is almost legal.Yep exhaust hitting ground and bouncing back.I would not like that.At very least if you put a straight vortex cap on it would probably cure the soot on house problem 99%.If was mine I would prob go up and then away from house.And plenty of heat to dry any caulk,but you may have to scrub to make it stick.
    Russell, wildwest, ivanhoe and 2 others like this.
  11. smoke show
    smoke show
    Pittsfield, Wi
    That termination is above the potential snow depth for your area?
    wildwest, eatonpcat and ivanhoe like this.
  12. T-BONE
    T-BONE
    Yes definitely go up.
    Russell and ivanhoe like this.
  13. T-BONE
    T-BONE
    just like this
    wildwest, ivanhoe and IHATEPROPANE like this.
  14. IHATEPROPANE
    IHATEPROPANE
    What are the clearences?
    ivanhoe likes this.
  15. imacman
    imacman
    Denver, NC
    I don't like the color of that ash.....way too dark. Sure looks like not enough comb. air.
    Anyone else have a comment?
    Russell, wildwest and ivanhoe like this.
  16. IHATEPROPANE
    IHATEPROPANE
    Agreed, looks too dark.
    It also does not look like it is at least a foot away from the house. Maybe just the angle of the picture though.
  17. DexterDay
    You need to increase your burn air (open damper) That is a dirty burn, caused by to little air.
    As for the clearance? I would want to be higher than that. At the minimum, I would add a 1 ft horizontal piece and add a jet cap (shoots straight out).
    I added a 45° to angle mine down, but that's because it is over 6ft off the ground.
    will711, ivanhoe and T-BONE like this.
  18. prell 73
    prell 73
    ia
    May be high temp caulk??
  19. subsailor
    subsailor
    Winthrop, Maine
    If that termination was at my house it would be under 3 feet of snow right now.
  20. ivanhoe
    ivanhoe
    Northern Ontario
    It was cleaned not too long ago, it could be the residue from cleaning. Too short and low in my book.
