Burning Wet Wood
Discussion in 'The Wood Pile' started by mywaynow, Nov 27, 2013.
  1. mywaynow
    mywaynow
    I thought nothing of doing it, but also feel it is a good question to pose to the posse' here. Wood that is seasoned multiple years, but was stacked 2 weeks ago uncovered near the house. Rained for a couple days so the stuff was soaked. I did not flinch and chucked it in the stove. Not an issue??
  2. papadave
    When I stack on the front porch, rain and snow will get to it.
    I'll bring it into the stove room and let it sit for a while, then stick it in the stove.
    Gooder to go. It's never soaked though.
    I burned fresh c/s wood for 2 years before I could get even slightly ahead, so It can be done.....just not well.
    What you're describing is different than that.
  3. blujacket
    blujacket
    Kettering, OH
    Surface moisture dries quickly.
    thistle and Oliver1655 like this.
  4. MrWhoopee
    MrWhoopee
    Shingletown, CA
    +1
    Rain water won't penetrate very far. Just don't leave the wood soaking in the puddles.
  5. Lumber-Jack
    Lumber-Jack
    I heard burning wet wood is good because you can get longer burns. :thumbs:
    papadave, DexterDay, BrianK and 3 others like this.
  6. campinspecter
    campinspecter
    Seasoned multiple years? Split or unsplit?
    In this part of the world, we have several species that will just rot if the rounds are not split, and in most cases have to stacked in a well ventilated area, under cover from wind driven rain if you want the the splits to dry.
    thistle and Gasifier like this.
  7. Backwoods Savage
    I'd get it top covered asap but it should dry off quickly; usually within 24-48 hours. No, it won't hurt the stove but if you have a cat stove, then you may need to leave the bypass open a bit longer but some say don't use it in a cat stove until that surface moisture is gone.
    clemsonfor and raybonz like this.
  8. firecracker_77
    firecracker_77
    IL
    Wet wood for me goes under cover in a wheel barrow before coming inside, then lives by the hot stove for a while, and then into the stove. Surface moisture dries quickly as others have said. Especially when next to a warm stove. I like the moisture off the wood sometimes. Helps relieve the dry air in the winter.
  9. SolarandWood
    SolarandWood
    Syracuse NY
    Most of my wood has been scrounged and I don't have a great way to get rid of stuff that I wish I hadn't brought home. I try to make sure this stuff gets under a roof because it can be a PITA when it gets rained on. No issues with the solid stuff.
  10. thewoodlands
    thewoodlands
    I've been having problems with wet wood this year, I finally found out Y.
  11. bogydave
    You burn what you got.
    Burn wet wood on high longer to evaporate the moisture
    out before adjusting the stove for the long burn.
    If you burn wet wood on cooler exhaust temps, just realize you are making creosote &
    need to clean & inspect the chimney often.
    Shoulder season burning at low stove & exhaust temps , burn good dry
    wood & you'll get less (or no )creosote build up.
    campinspecter likes this.
  12. Well Seasoned
    I would say wet and sticky, possibly sap :thumbs:
    thewoodlands and campinspecter like this.
