home made chain vise
Discussion in 'Chainsaws and Power Equipment' started by jackel440, Feb 9, 2015.
  1. jackel440
    jackel440
    Galveston, IN
    I thought I'd share with you guys my homemade chain vice.I use it for filing rakes down after sharpening a bunch of chains.
    I have it clamped in a vise and it allows the chain to hang down off the edge of the table just like when the chain is in the grinder.
    I can quickly gauge and file them pretty quickly with it.
    included a pic of one of my filthy benches were my grinder is mounted.Mine is a Jolley star from Baileys. Works real good and in happy with it
    FarmHand78, w8ye, cgraham1 and 10 others like this.
  2. JustWood
    JustWood Guest
    Sweet and simple set up. NICE !:yes::thumbs:
    FarmHand78, Chvymn99 and jackel440 like this.
  3. HDRock
    That thing looks beefy man :thumbs:
    FarmHand78 and jackel440 like this.
  4. prell 73
    prell 73
    ia
    Sweet set up .nothin better tha makin things your self.
  5. Gasifier
    Way to get it done jackel. Do you sharpen for others, just yourself?
  6. jackel440
    jackel440
    Galveston, IN
    It's nothing fancy but works pretty well.Made it out of 10 gauge steel and a some rod.
    I think a cam lever type lock upgrade in the future might be happen.The T handle bolt works good but a cam lever would be even quiker.
    FarmHand78 and Chvymn99 like this.
  7. jackel440
    jackel440
    Galveston, IN
    No I just sharpen my own stuff and I'm no expert at it.I did find out I had my grinder angle set wrong the other night.Been wrong for 2 yrs now.:emb:
    FarmHand78, cnice_37 and Gasifier like this.
  8. Moparmyway
    Moparmyway
    New York
    Nice idea !!
    Do you have any build pics ?
  9. jackel440
    jackel440
    Galveston, IN
    No I don't but I can get you some dimensions And more pics tonight after work.
  10. Evanrude
    Evanrude
    Byron, MI
    Looks very nice! Not fancy? Heh, it's much fancier than mine...
  11. jackel440
    jackel440
    Galveston, IN
    Evanrude I like that! That is wider than mine so that will make less tme moving chain through the vise.I think should have made mine a little wider.
    Evanrude likes this.
  12. Evanrude
    Evanrude
    Byron, MI
    It's just scrap aluminum. When doing any work, I have to stay within the vise jaws. Otherwise, it just flexes too much. I have a piece of thicker aluminum angle that I'm going to use for V2.0, hopefully it'll be a little more rigid and allow me to atleast do the depth gauges outside of the vise jaws.
    FarmHand78, Moparmyway, w8ye and 2 others like this.
  13. Evanrude
    Evanrude
    Byron, MI
    jackel440 You've inspired me to fiddle with making the new one with the thicker angle stock. I just got it done about an hour ago. I didn't get to test it out yet, I was tired and wanted to come in the house. It is much sturdier than the old one. I kept it the same length because that always seemed to work well.
    I don't want to hijack your thread, but I thought you might want to check it out.
