MS461 air filter question
Discussion in 'Chainsaws and Power Equipment' started by Woodrat1276, Feb 2, 2015.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Good picture and representation of an average day of cutting with a 461.:thumbs:
    Chvymn99, $ooline and Drvn4wood like this.
  2. Woodrat1276
    Woodrat1276
    Ky
    That helped a bunch thank you. The way some was describing it on another site you would have thought it was caked with dust.
    One other question as i dont want to start another thread. Diws the decompression valve stick up high. Another issue I have read is its too high and easily broken off.
    Chvymn99 and Drvn4wood like this.
  3. mdavlee
    mdavlee
    A thirsty saw is a 660. A 461 gets about 20% longer on a tank than a 460 did.
  4. NewToStihl
    NewToStihl
    Central Indiana
    This may not sound like an answer to that question, but it most certainly is...
    After putting a decent number of tanks through my 461 before I traded it off I can't honestly say that I ever noticed the decomp sticking up excessively far. That's considering I used it in most/all normal use positions including off-hand horizontal cutting. Never hit the valve on anything.
    Additionally, it doesn't take three men and a boy to start a 461, even with higher compression, so you can always pull the valve and plug the hole. That would be a very simple solution.
    Chvymn99, $ooline, Drvn4wood and 2 others like this.
  5. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I suppose it could happen. Here's a couple of shots from a few different angles to give you an idea of how it's exposed. It could definitely happen but was never something I considered or would worry about. The third one is parallel with the top cover.. put my thumb there to give some perspective and I have kinda fat fingers..lol.. 20150205_155145.jpg 20150205_155106.jpg 20150205_155221.jpg
  6. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    20150205_160843.jpg 20150205_160859.jpg Parallel side shots might give you a better idea. Here's one from each side.. 20150205_160859.jpg
  7. $ooline
    $ooline
    WI
    Looks about right from I know of the 461
    mdavlee and Drvn4wood like this.
  8. Ralphie Boy
    Ralphie Boy
    No different than my former 441 or my new 660. No problem.
    $ooline, mdavlee and Drvn4wood like this.
  9. Ralphie Boy
    Ralphie Boy
    All this talk leaves me with a question. Will the pre-filter on the 441 and 660 work in the 461? Same filter so I would think that it would.
    Drvn4wood likes this.
  10. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Maybe I'm missing something, but would it be that hard to take off the cover and knock off the filter every 4 or 5 tanks if you're running it non-stop over an 8 hour day? I'm very anal about maintaining my stuff but I haven't thought twice about this filter.
  11. DexterDay
    Yes. Same filter. And the outerwears for a 440/460/461/660 will work on a 261/362 saw as well. That oval 460 filter is about the same circumference of the round 261/362.
    As for the decomp? It's nothing I would worry about. The decomp just doesn't have the plastic sticking up around it like on the older generation of saws (260 Pro on up to the big )
  12. DexterDay
    For under $10, this will let you cut all day. It doesn't stop 100%, but it's pretty easy to clean. Heck, once the saw shuts off and the suction stops, most of the big stuff falls off.
    A lot better than letting it pack in between the pleats of the HD2 filter.
    You can pick out of numerous colors.. I like the orange ;)
  13. mdavlee
    mdavlee
    The outer wears would be great for the HD 2. I hate using them for milling.
    $ooline and Ralphie Boy like this.
  14. Ralphie Boy
    Ralphie Boy
    Drvn4wood and $ooline like this.
  15. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    It was a Christmas present from my wife.. I've definitely used it but I'm very particular about maintaining my stuff so it probably looks "less used" than it is..
    $ooline, Chvymn99, DexterDay and 2 others like this.
  16. $ooline
    $ooline
    WI
    Nice pic Dex, you beat me to my pic in the 046 filter thread...that stihl orange is pretty cool imo too
    Chvymn99, Drvn4wood and DexterDay like this.
  17. Ralphie Boy
    Ralphie Boy
    Dex, where did you purchase that pretty orange pre-filter?
    Drvn4wood, $ooline and DexterDay like this.
  18. Gunn
    Gunn
    Plover, Wi
    Outerwears is the name
  19. Evanrude
    Evanrude
    Byron, MI
    Drvn4wood, $ooline and Ralphie Boy like this.
  20. DexterDay
    Yep... Sums it up. :D
    They are cheap too. And they work on the 362 (new style) and 261 filters.
    $ooline likes this.
