Saw dies after 8-10 seconds of idle time
Discussion in 'Chainsaws and Power Equipment' started by NewToStihl, Feb 8, 2015.
  1. NewToStihl
    NewToStihl
    Central Indiana
    This is a new one for me. I have a saw that will start easily and rev just fine. However, if I leave it to just idling after 8 or 10 seconds it will slow and die. It'll fire right back up, but will repeat the slow & die routine again and again. It doesn't have low compression and acts differently than a saw with poor compression as it's been my experience they won't idle for even a few seconds. Here's what I can tell you about it:
    • Piston & cylinder are in decent condition (has new Caber rings)
    • Passes vacuum and pressure tests on the engine
    • Passes vacuum and pressure tests on the fuel line, tank, and tank vent
    • Makes about 155 psi compression
    • L screw is set to about 1 turn out
    • Running the LA screw in to speed it up does not fix the problem
    • I have not cleaned or rebuilt the carb
    • I have not pressure tested the carb
    That's all I can think of for now. I welcome suggestions and questions. Thanks.
    Gunn likes this.
  2. NH_Wood
    NH_Wood
    What kind of saw? Impulse line? Plugged exhaust port/spark screen. I'd be thinking carb rebuild - weak/stiff diaphragms not keeping up with crankcase pulse perhaps. You'd think these issues wouldn't lead to good revving though. Will it rev over and over for a long time and only quit at idle? Cheers!
  3. Woodrat1276
    Woodrat1276
    Ky
    Maybe a dirty fuel filter. Just a guess snd its a cheap place to start
    bert the turtle likes this.
  4. NewToStihl
    NewToStihl
    Central Indiana
    Stihl 064. Very recently replaced impulse line (which is also tested during the p/v test). No screen in the exhaust, and a clogged screen has always presented with lack of high end revs for me, not idle issues. It will rev and run at anything above idle just fine. Thanks for the questions/suggestions.
    Gunn likes this.
  5. NH_Wood
    NH_Wood
    Hmmm......I guess I'd lean toward the carb - partially plugged jet? Cheers!
  6. NewToStihl
    NewToStihl
    Central Indiana
    Good suggestion, but it's a recently replaced fuel filter, and that has always been a rev/high throttle presentation for me as opposed to idle.
  7. MasterMech
    Perhaps it's set a bit rich on the L side? Determining wether it's stalling due to a lean or rich condition will go a long ways as to isolating the issue.
    clemsonfor likes this.
  8. NewToStihl
    NewToStihl
    Central Indiana
    That's a valid thought. I've adjusted the L a bit to both sides with no changes. It doesn't sound/feel lean or rich on the L side though; the idle is 'perfect' for a handful of seconds and then it just slows down and dies. The best way I can describe it is if you just pulled the fuel line from the carb; doesn't sputter like it's running out of gas, just slows and stops like the fuel supply stopped all-together...
    MasterMech likes this.
  9. DexterDay
    This was my thought as well?
    Original air filter with pre filter?
    Clogged filter?
  10. nmurph
    nmurph
    Leaking welch plug.
    Leaking check valve--- I have seen this a good bit in some of the C3 carbs.
    clemsonfor and Adirondackstihl like this.
  11. NewToStihl
    NewToStihl
    Central Indiana
    The air filter has been upgraded to an HD2 and it's clean as can be; no prefilter.
  12. NewToStihl
    NewToStihl
    Central Indiana
    Could be. Due to limited time out in the shop the carb is the only thing I haven't exhausted as a possibility based on my knowledge.
    What is a "C3" carb?
    NH_Wood likes this.
  13. Oliver1655
    Oliver1655
    Central Missouri
    You mentioned tank vent, a clogged vent will cause this type of problem.
  14. Jon1270
    Jon1270
    Pittsburgh, PA
    How about some details on how one would recognize or diagnose these conditions?
    NewToStihl likes this.
  15. NH_Wood
    NH_Wood
    When you first start the saw with choke on, then do your revs warming the saw, then it dies at idle, will it start warm again at normal idle position or do you always need to choke it? My thought is once you are opening the throttle plate and vacuum starts to draw from the main jet the saw is getting plenty of gas, but as the throttle plate closes and transitions to idle circuit, that circuit is clogged and not allowing enough fuel to keep idle. I'm not sure how you would test for leaking welch plug - pressurize carb while submerged with no diaphragms and look for bubbles from the plug before the needle unseats? Never seen a carb pressurized this way. From everything you've said and done, if it were me, I'd do full carb cleaning and if diaphragms are suspect, put in a carb kit. Seems like you've ruled out most everything else. Good luck! Cheers!
  16. MasterMech
    The fact that it is not responding to the L screw is a clue. Also the restart is a good indicator as you get an idea if it's lean/rich depending on if you need to choke it to restart or only crack the throttle.
    If it's not responding to the L screw and stalling because it's too rich, I'd say leaking welch plug or other leak/fault in the carb. If it is lean, then the L circuit is restricted somewhere/somehow.
    Moparmyway likes this.
  17. Jon1270
    Jon1270
    Pittsburgh, PA
    I haven't messed with welch plugs yet so they're kind of a black box for me. What is under them? What are they sealing away from what?
  18. NH_Wood
    NH_Wood
    I think the are at the base of the main jet and and seal the carb body from where the main jet was milled - but not positive. Looking forward to seeing what the problem ends up being on this one. Cheers!
  19. NewToStihl
    NewToStihl
    Central Indiana
    You're correct, but as I mentioned, the tank vent passed testing; i.e. held pressure, but not vacuum.
  20. NewToStihl
    NewToStihl
    Central Indiana
    Very good thoughts & a carb cleaning with possible rebuild is on the list! To answer your question, it'll fire right back up warm with the swith in the 'run' position - no choke or throttle lock.
