Blower Thermodisk Kit
Discussion in 'Modern EPA Stoves and Fireplaces' started by Grizzly Adam, Feb 5, 2015.
  1. Grizzly Adam
    Grizzly Adam Guest
    Picked one of these up while I was out today. Once I get it installed the blower should turn on automatically when the stove heats up and back off once it's cold.
    Backwoods Savage, HDRock, Sam and 5 others like this.
  2. Certified106
    Certified106
    In The Hills
    Sweet! Mine has one of those and it works well.
  3. Grizzly Adam
    Grizzly Adam Guest
    I figured I was going to fudge it a bit, but it turns out that the thermodisk is actually made for my stove model!
  4. raybonz
    raybonz Moderator
    Carver, Mass.
  5. Grizzly Adam
    Grizzly Adam Guest
    image.jpg Got it wired up and mounted, now waiting for the fire to get warm enough to kick it on.
    Well Seasoned and wildwest like this.
  6. Grizzly Adam
    Grizzly Adam Guest
    And it just kicked on, success!
  7. Well Seasoned
    Awesome Adam!
    wildwest and raybonz like this.
  8. Highbeam
    Highbeam
    The only thing I'd worry about is that I need to shut my blowers off when I reload. Did you retain the regular on/off switch?
  9. Grizzly Adam
    Grizzly Adam Guest
    Yeah, I still have the switch and speed control.
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    I don't shut off the blower to reload and no problem.
  11. Grizzly Adam
    Grizzly Adam Guest
    Yeah, neither do I. But if I wanted to...
  12. badbob
    badbob
    And if you are not happy with the settings,a good adjustable snap disc is about 20 bucks.Have one on my vent free heater in basement.
  13. MarylandGuy
    MarylandGuy
    Maryland
    I"m curious, but why do you need a blower on your stoves? It seems like you add more heat to the room in the beginning, but rob future stored heat in the stove when the coals die down. I know on my soapstone, using the blower doesn't allow the stone to give off heat later in the burn. It sort of negates the benefit of the soapstone.
    Please excuse the question. I am not trying to troll, but more so trying to understand the benefits. My blower is sitting on the shelf in the garage.
  14. Grizzly Adam
    Grizzly Adam Guest
    We use one because the stove is not in the room that we are typically in, but the blower is pointed in that direction. It can cut 30-60 mins from the time that we are waiting to get warm.
    raybonz likes this.
  15. raybonz
    raybonz Moderator
    Carver, Mass.
    With the T-5 it is a convection stove and to get good heat distribution the blower helps immensely.. If it's mild I do not run the blower to reduce heat output..
  16. MarylandGuy
    MarylandGuy
    Maryland
    I understand. Thanks!
