Build or buy a stove?
Discussion in 'Modern EPA Stoves and Fireplaces' started by RParrotte, Jan 28, 2015.
  1. jeff_t
    jeff_t
    SE MI
  2. Machria
    Machria
    Long Island, NY
  3. Machria
    Machria
    Long Island, NY
    Huh? Your going to burn a wood stove in August, in NY where it can reach 90-100F at times?
  4. RParrotte
    RParrotte
    Saranac, NY
    I meant all burning season. Sorry for confusion!
  5. jeff_t
    jeff_t
    SE MI
    Yep. Just numbers. The point I wanted to make was that the 63% number is a default that the EPA came up with for non cat stoves. Most manufacturers use that because the testing and certification is expensive.
    If you look at the new list, Blaze King and a very few others have actual tested heating efficiencies. I suppose Woodstock would be there too, if they didn't get left off :doh:
    concretegrazer likes this.
  6. WeldrDave
    Ok, here goes…. The gang will scold me for this but oh well, they'll get over it…:p It's your money, I too have been a welder and fabricator of "many" years. But I would buy as well! "NOW" you can find some old school stuff out there. I burn the old smoke dragons but I do it very efficiently and correctly with the proper seasoned wood. I will say that the newer EPA stoves are much cleaner, but I've seen some old Fishers, kodiaks, all nighters for as little as $100.00. If you go that route, be careful as some said with insurance, but sometimes it's better to ask forgiveness than ask permission!:whistle:
  7. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I know what you are trying to say, but I don't think that saying works well when it comes to a insurance for a home fire...
    WeldrDave and clemsonfor like this.
  8. clemsonfor
    Yep especially when they will show you the fine print that let's them weazel out of paying off a $200,000 claim due to the use of an in posted and untested and or non production wood stove.
    The insurance companies will do whatever they can to minimize payouts. This is the same reason you have to fight to get what you think a totaled car is worth. There trying to pay you the bare minimum.
    WeldrDave likes this.
  9. JA600L
    JA600L
    Lancaster, Pa
    I think its safe to say that most of us are on here for more reasons then just heating our houses. We care and want to learn about how to do things efficiently and in the cleanest way possible. Its a packaged deal. Heat, efficiency, and cleanliness. It all works together. Don't buy an old stove or build one. Its that simple.
  10. WeldrDave
    I understand what both of you are saying, And agree to an extent. I've been heating since 1980 with the same stove without any trouble! If a stove is installed correctly you won't either.
    Many of folks have used older stoves with great results. The ones who burn their house down are the ones who; don't clean their chimney, install it incorrectly, burn it incorrectly, burn trash etc... you can't blame the stove for peoples irresponsibilities! Thats like blaming a gun because you commited suicide.
  11. clemsonfor
    I am not as worried about a 30 year old smoke dragon in serviceable condition but more the home made job.
  12. NW Walker
    NW Walker
    Olympic Peninsula
    I believe there is no better value than some of these new heaters coming out now. The amount of heat put into the space from the fuel is amazing, and the upfront costs are low, and getting lower thanks to market entries like the IS from Woodstock. That said, not everyone can afford the proper chimney, let alone the stove. If you can afford it, buy one and be done with it. If you are looking at burning a dangerous, dirty smoke dragon for years due to not being able to afford a modern install, than I would say, build one. While insurance is a good reason for caution, I truly believe I would have burned my house down by now with the old dragon. It really was that bad, and my only options were use it, or build something better. I did the latter. Just one opinion, things have come a long way and stoves are way better than they were just a few years ago, it's now possible to build one inexpensively that meets or exceeds the efficiency of commercial offerings. That said, if I could, I'd just buy an IS or the like and be done with it.
  13. JA600L
    JA600L
    Lancaster, Pa
    I understand continuing to use an existing "older" stove, but adding an old stove to new pipe in today's world makes no sense. If you were thinking of doing that I would say go get the Englander in a heartbeat.
    NW Walker and clemsonfor like this.
