Zero Turn Mower Recommendations
Discussion in 'Chainsaws and Power Equipment' started by bigwalleye, Jan 19, 2015.
  1. Firewood Bandit
    Firewood Bandit
    A friend of mine is commercial mower mechanic. Walker is his mower of choice. Not large, but the Rolls Royce of zero turns.
    Minnesota Marty and wildwest like this.
  2. DexterDay
    Lawn is courtesy of Chem-Lawn.
    After several years of service, it's pretty cheap and I only do 3 treatments. Not the 7-10 they recommend
    wildwest and raybonz like this.
  3. wildwest
    They also sell in Australia and South America, good company.
  4. komatsuvarna
    komatsuvarna
    I have a Gravely ZT HD60 as well. I only mow about 2 acres, but it sure does it a lot faster than my old Deere rider. I like it very well.
  5. joshmain
    joshmain
    Sullivan Ohio
    NCM_0475.JPG Like DexterDay said I have a bad boy i went with the kohler because it was a 1000 upgrade to get the kaw!!! It cuts great and pretty quick. Not as fast as dex's dixie.
    fox9988 and DexterDay like this.
  6. bigwalleye
    bigwalleye
    Cuyahoga Valley National Park
    Lots of good info and good advice on this thread. Ive kinda narrowed my focus to the Ferris 700 series, with some help and addl info from Dexter. I confess I like the suspension feature on paper though I havent had a chance to 'experience suspension' yet, as their slogan says. Still lotsa white here on the ground in Ohio.
    I thought I was heck bent on the Kaw motor option but Ive been rethinking that. Theres quite a price difference between it and BS Comm Turf series. Since Ill only put 50 hrs a year on it (max guess) Im not sure I need to spend up for the Kaw. Plus some other threads Ive discovered mention all motors being a bit of a crapshoot as far as reliability goes. So why spend the extra money, I guess? And the BS Comm Turf Series seems to power lots of equipment.
  7. DexterDay
    Briggs definitely improved on the series that are in place now.
    My buddy joshmain has the same engine that would be on the 700 series and it's cyclonic air cleaner, bigger crank journals, titanium infused exhaust valves, etc are a large step up over the old 30 hp briggs.
  8. Pallet Pete
    Pallet Pete Moderator
    Ovid
    That thing looks wicked up close and in person too! You could do my lawn in one pass! :p
  9. dgeesaman
    dgeesaman
    Elizabethtown, PA
    If we're doing mower porn, then here
    DexterDay and raybonz like this.
  10. bassJAM
    bassJAM
    Cincinnati, OH
    Here's mine. Well, it's part of mine, and a hitchhiker I found when I went out to mow that day.
    I decided that I'd just mow another day, I HATE spiders!!!
  11. MasterMech
    That design, no matter what trim level it has, has always made great power. Looks like it has a bit better filter than the previous series which was a major weakness with these engines.
    raybonz likes this.
  12. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Ferris is now owned by the people who own B&S. So B&S engines are surprisingly well priced compared to Kawis or Kohlers.
    MasterMech likes this.
  13. MasterMech
    That's right! I forgot that Ferris in now part of B&S Power Products. That makes a lotta sense now huh? ;)
  14. SolarandWood
    SolarandWood
    Syracuse NY
    I never understood why someone would want a 4WD 6' deck diesel powered with a cab mower until I owned one. I see a lot of big JD commercial front mowers in the 3-4K range and a steering wheel frees up a hand for your beer.
    MasterMech and DexterDay like this.
  15. bassJAM
    bassJAM
    Cincinnati, OH
    When I first bought my house someone I knew was getting rid of an older Kubota commercial front deck mower with a 60" deck for $800 so I jumped on it. It was awesome as far as mowing with a beer because of the steering wheel. Even better was mowing the entire season and only using about 5 gallons of diesel fuel! But after 2 seasons the deck fell apart beyond repair and I couldn't find any used decks for under $1000, so I sold the whole thing for $600 and got my 50" ZTR. It's cut my mowing time from 60 minutes to 45, but I do miss having a steering wheel! A front deck was also way better for getting under all my pine trees, and I'm probably using 6 times as much fuel a year!
  16. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Yeah that's the downer to gas engines - they drink heavily. But I figure that unless you go diesel, you're going to burn about the same amount of fuel per acre - you'll just take more hours to do it. So having the big fast machine is just more time doing the things I want to do, and makes the mowing time a lot more tolerable.
