JD Sabre Riding Mower -- Towing Attachment
Discussion in 'Chainsaws and Power Equipment' started by Grizzly Adam, Jan 31, 2015.
  1. Grizzly Adam
    Grizzly Adam Guest
    I want to be able to hook a trailer hitch to the mower for moving the splitter and boat around the yard, can anyone guide me to the right attachment to add a ball hitch.
  2. MasterMech
    It's pretty much going to have to be "custom".
  3. haveissues
    haveissues
    Hudson Valley
    I'm not sure how heavy of a boat you are talking but for the log splitter I would think mounting the smallest shank ball you can find in the existing hitch hole should work, no?
  4. Grizzly Adam
    Grizzly Adam Guest
    No, it is currently set up for pin and I dont have enough room to mount a ball. Also, the splitter pull harder than the little boat.
  5. MasterMech
    They typically do not have enough strength to mount a ball and tow any kind of load. A splitter would fold one over pretty quick.
    It's going to have to be a frame mounted bracket that has provisions for the ball or a receiver. Or, it could be a towable dolly of sorts that would make either trailer into a 4-wheel trailer with a steerable front axle.
  6. Gasifier
  7. Grizzly Adam
    Grizzly Adam Guest
    Maybe something like this?
    http://www.amazon.com/gp/aw/d/B003D...ball+hitch&dpPl=1&dpID=51ZfXYg0WuL&ref=plSrch
    wildwest and MasterMech like this.
  8. MasterMech
  9. Grizzly Adam
    Grizzly Adam Guest
    Maybe, searching from phone isnt the best.
  10. Gasifier
  11. HammerheadC4
    HammerheadC4
    Eastford CT
    I think TSC has a couple different types
  12. prell 73
    prell 73
    ia
    i took some 3/8 plate and made one for my mower.
  13. cutforfun
    cutforfun
    I built one for mine, you want to be careful getting the ball above the center point of the tires. It will want to wheelie, and flip over on you
    Gasifier and wildwest like this.
  14. bassJAM
    bassJAM
    Cincinnati, OH
    I don't know how popular the JD Sabre is, but I was able to find custom built frame mounted ball hitches for my Wheel Horse on eBay.
    Gasifier likes this.
  15. Boog
    Boog
    Where my spirit is free
    I rigged this one up for my sabre. I backed up the thin sheet metal along the bottom/back with some stout angle iron, I think it was about 1-1/2" wide. I bolted this up with 4 bolts. (Doing it over I would bolt an even wider piece to the top of that edge versus under it, and weld to that.) My neighbor then welded an old used hitch channel to the sheet metal. I made a diagonal brace from some flat stock and welded it to the hitch, bolting it at the top through the existing "battery bungee hole" at the top. Does not look like much but its very strong. As you can see from this photo off one of last years posts (http://firewoodhoardersclub.com/for...ord-the-jd-winch-and-subaru-bail-me-out.4355/) it will carry a "trailer load" of weight!
  16. Butcher
    Butcher
    I'm not a big fan of those kind that mount high up on the tractor like that. To much weight and they get pretty light in the front end. I made 1 for my CC that has worked well for me but it is kind of a pain having to pick up what ever you are towing off of the ball.
  17. ironpony
    ironpony
    Mid Ohio
    A combination of the two above posts should get you where you need to be. Some flat/ angle iron bolted together and you should be set.
  18. lukem
    Another vote for keeping the mount point below the axle. Unless you have a wheelie bar.
    Butcher likes this.
