Hearthstone Heritage vs. WS Progress Hybrid.
Discussion in 'Modern EPA Stoves and Fireplaces' started by mike bayerl, Jan 28, 2015.
  1. mike bayerl
    mike bayerl
    Thoughts? Good, bad, ugly. WS PH looks perfect for us, but we REALLY want to put a clear/glass spark arrestor only under our stove. HS Heritage is super simple operation and spark arrestor only. Hmmm... Decisions...
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm a WS fan 100%. The hybrid will be a dream to own, it's simple to run and will give you some long hours of 2 stage burns, cat and secondaries.
  3. concretegrazer
    concretegrazer
    Southwest MO
    No comparison. Two different sized stoves. Hearthstones PH equivalent would be the Mansfield.
    Are you interested in the Manny?
  4. Highbeam
    Highbeam
    I pushed almost 30 cords through my heritage before dumping it. It always ran as advertised but is not a durable stove. Not an efficient stove. And barely made it through the night.
    Between the ph and the heritage I would tell my mom to get the Woodstock.
  5. splitoak
    splitoak
    jefferson co wv
    It works as advertised...easy operation 8 hr burns...i like mine...but there really is no comparison..55k vs 80k...ill be upgrading in a coupla years
  6. Certified106
    Certified106
    In The Hills
    I agree with the others that their really isn't a comparison between the two of them. If you want to similar sized stoves you should be looking at the Mansfield.
    Backwoods Savage and splitoak like this.
  7. mike bayerl
    mike bayerl
    Actually I only need the smaller size. Heating ~1500 as feet. I just like the idea if the hybrid system.
    splitoak and papadave like this.
  8. papadave
    I'd get the WS, then run in cat mode for really long burns.
    Or, an Ashford 30 and do the same.:)
    I'm curious to see if you're able to find something that will work under the stove.
    Good luck in your quest mike.
    concretegrazer likes this.
  9. papadave
  10. splitoak
    splitoak
    jefferson co wv
    I would def go with the progress..its easier to build a smaller fire in a bigger stove....and if you need to break out the big guns well then.....
    papadave likes this.
  11. Backwoods Savage
    We looked at the Heritage and I believe that would be close to the Woodstock Fireview. We got the Fireview and have never looked back. 1500 sq ft is usually pretty easy to heat with a Fireview unless you have no or basically no insulation, bad windows, etc. We're a bit lower than 1500 sf and heat this house very easily, keeping it around 80 all winter long, no matter the outside temperature.
    The Progress could suit you but you would not want to burn full loads no doubt. Good for cooking on the Progress too.
    My IS heats my home and splitoak like this.
  12. Oldhippie
    Oldhippie
    Ashby Ma
    Woodstock will be shipping a smaller hybrid next year that will be a 2.6cu ft stove, currently called "the Franklin" or the "Next Gearhead" stove. That might be perfect for you. Or the Fireview would be in the same size range to heat 1500sq ft but it isn't a hybrid.
  13. Backwoods Savage
    That is true but Oldhippie and I are still happy with our Fireviews. However, I'm getting the itch a bit on that new stove even if not too much has been done to get it ready. Not sure if they'll have it ready before next heating season or not. They's been swamped with orders for the IS and Progress but I don't think it makes them feel too bad. lol
    splitoak and Oldhippie like this.
  14. My IS heats my home
    My IS heats my home
    Albany, NH
    Good tip OH!
  15. mike bayerl
    mike bayerl
    Unfortunately, I can't get the wife to like the looks of the stoves except the PH, especially not the steel plate stoves. She likes the Hearthstone, Jotul and BK Ashford. I think I'm back to the Heritage. Allows installation close to the back wall and a glass spark arrestor below. I think the side door will address the perceived wimpyness of the hinges on the front door??????
    splitoak likes this.
  16. concretegrazer
    concretegrazer
    Southwest MO
  17. papadave
    That one would make you both happy.:thumbs:
  18. mike bayerl
    mike bayerl
    The Heritage at my local dealer has the drop down side door, plus he's taking $300 of the stove MSRP and 20% off the pipe with install. Ashford 20 is MRSP and need R-rated hearth. Just sayin' I'm not going to put anything in this winter, will definitely wait til summer/fall. Personally, I really like the stove tops hidden under the soapstone of the PH, but, yeah, it really is WAY too much stove for us.
  19. concretegrazer
    concretegrazer
    Southwest MO
    Ashford 20 or 30 requires ember only hearth protection.
  20. Highbeam
    Highbeam
    All hinges on the heritage were crap. Hopefully the newest version is more robust.
    I moved from the heritage to a princess. Same house. You do not want a 20 series bk, that is a lame duck stove. It does everything worse than the 30. If you are willing to consider bk then I still keep them as my #1 choice. Can't beat the burntime. Ashford 30 is very hard to beat.
    concretegrazer and papadave like this.
