Just got smoked out!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Smokinpiney, Jan 28, 2015.
  1. Smokinpiney
    Smokinpiney
    "South" Jersey
    A few minutes ago the mrs yelled to me in the other room that the stove was smoking. Soon as she said that the smoke detectors went off. I quickly turned the stove off and opened the windows. Smoke was rolling from the back of the stove and I could hear stuff falling in the pipe. I ran outside and looked at the pipe on the roof and there were a few sparks coming out. The stove cooled down enough for me to pull the back panel off and it looks like the paint burned off the exhaust fan housing :eek: . Any idea what could've caused this? My chimney is clean so I don't think it was a chimney fire. The stove was burning on level 4 at the time this happened.
    ivanhoe and wildwest like this.
  2. XXL
    XXL
    Ontario, Canada
    :bug: No idea what caused it but glad you were home to deal with it and no one was hurt!!!!
    ivanhoe, imacman, Smokinpiney and 4 others like this.
  3. IHATEPROPANE
    IHATEPROPANE
    No idea. Scary stuff. Is it possible your combustion motor went into high gear, as high as it can go, and was sucking the embers through the venting system? The St Croix does turn the combustion motor full blast every once in a while to clean the pot correct? Maybe it got stuck on full blast? Hoping some of the more knowledgeable folks show up and figure out what happened.
  4. will711
    will711
    Pocono Mts.
    Was the smoke in the house from the paint burning off or from the stove exhaust ?
  5. wildwest
    No advice but my ashpan caught on fire. Drolet advised me not to use the highest setting....
    ivanhoe likes this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    Yowza!!!!! First thing I'd do is pull that blower but be careful not to rip the gasket....unless you have another one on hand.
    ivanhoe, eatonpcat, imacman and 2 others like this.
  7. smoke show
    smoke show
    Pittsfield, Wi
    I'd be looking hard at the over temp snap disk.
  8. imacman
    imacman
    Denver, NC
    I agree with with what both Smoke and slvrblkk mentioned above. Also, I never heard of a creosote fire from a pellet stove, but I'd eyeball the exhaust pipe too.
    PS. Last time the exhaust blower was removed & cleaned was..........?
    ivanhoe, slvrblkk and wildwest like this.
  9. jtakeman
    Glad you were home to handle it and nothing was damaged.
    Scary stuff!!
    ivanhoe, Smokinpiney, imacman and 3 others like this.
  10. slvrblkk
    slvrblkk
    Northampton, PA
    Are exhaust housings generally painted? Englanders aren't and I can't really recall any that are.
  11. ttdberg
    ttdberg Pellet Pig
    CT
    Very scary. My pellet stove burning friends think I'm nuts, but stories like this one are why I am so apprehensive about running the pellet stove when no one is home. So glad you were there to take care of it and no damage was done to the house or family or pets! I'm sure you guys will have the cause sorted out and resolved quickly.
  12. imacman
    imacman
    Denver, NC
    I'm not 100% certain, but I thought mine was. In any event, if it's painted w/ Hi Heat paint, shouldn't be an issue unless there was some sort of "overfire" event.....seems unlikely for a pellet stove.
    ivanhoe, Smokinpiney and wildwest like this.
  13. slvrblkk
    slvrblkk
    Northampton, PA
    That paint bubbling just on the housing is very suspicious....at least to me...
    wildwest and imacman like this.
  14. imacman
    imacman
    Denver, NC
    Yes, me too.
    wildwest and slvrblkk like this.
  15. Smokinpiney
    Smokinpiney
    "South" Jersey
    Well i decided to take the mrs and baby piney out to dinner and let the stink clear out of the house for a bit. We just got back and i removed the exhaust blower (since i had 2 extra gaskets) and it looked good inside. After staring at it for a few minutes it dawned on me! When i was cleaning/rebuilding this stove, there was a build up of gooey creosote in the lower part of the exhaust housing and some inside the upper housing. I scraped all that i could off and burned the stove on level 5 for a good while outside. Assuming it burned the remaining creosote off i left it alone :picard:. All i can figure is that the creosote was still inside the housing and finally lit off tonight after running on level 4 for about an hr. Im also burning some greenway pellets instead of the softwoods i've been burning. They do seem to burn a little hotter.
    The stove is back together and burning on level 2 right now with no paint smell and all seems well. I'm keeping a close eye on it until we go to bed and shutting it off like i usually do. Im definately glad we were home when this happened. It could have been ALOT worse. I was just getting comfortable leaving the house with the stove running. Not anymore! :emb:
    Here's a pic of the exhaust housing before i cleaned it. Trust me it looked alot better when i put it back together but i guess it wasn't cleaned enough.
  16. Smokinpiney
    Smokinpiney
    "South" Jersey
    That's the snap disc on the exhaust blower housing? If it got hot enough to melt the paint it should've shut the stove down right?
    It was the cooling fan on the blower blowing the burning paint smoke up the back of the stove. Filled the whole dang room in a minute!
    ivanhoe and will711 like this.
  17. will711
    will711
    Pocono Mts.
    Thanks for the update Man :thumbs: glad all is well now
    IHATEPROPANE, ivanhoe and Smokinpiney like this.
  18. smoke show
    smoke show
    Pittsfield, Wi
    One would think so.
    IHATEPROPANE, ivanhoe and will711 like this.
  19. ivanhoe
    ivanhoe
    Northern Ontario
    X2 Now I see what happened, figures. Keep tab on ash color or dark color corners inside the stove in the future. Early signs symptoms not to be overlooked if was present. Not a pretty sight to reckon with and I'm forever grateful nothing further happened. In these cold spells we have to be vigilant of our heating sources.
    Smokinpiney and IHATEPROPANE like this.
  20. Smokinpiney
    Smokinpiney
    "South" Jersey
    What does a change in the ash color or dark spots mean? I do my best to keep this stove running clean. Those pics of the blower housing were before i even installed the stove. That was buildup from the previous owner. I tore this stove down and cleaned the crap out of it before i installed it but that little bit of creosote that i thought burned off during my outside test burns must've still been there. :picard:
