white oak logs
Discussion in 'The Wood Pile' started by wood, Jan 27, 2015.
  1. wood
    wood
    ia
    I loaded these at jobsite with jd2320 into dump trailer. Cut at 84" and rear loaded. About 50 logs and two trips later. Worked great. 18-24 " diameter. Split and palletize these soon for next fall.
  2. Woodchuck
    Woodchuck
    Southeastern Ohio
    Wow! good score....Lots of BTU's when dry :thumbs:
  3. concretegrazer
    concretegrazer
    Southwest MO
    Sweet!:thumbs:
    Drvn4wood and splitoak like this.
  4. billb3
    Looks like a great spot for seasoning wood.
    one year for white oak ?
  5. Iceman7668
    Iceman7668
    White oak burns better at 2 years of seasoning. This is the only oak that turns my hands black when I split it without gloves one. Looks like I was rolling newspapers up like when I was a kid! Don't know if todays newspapers still turn your hands black or not, but they sure use to!
  6. splitoak
    splitoak
    jefferson co wv
    If your burnin a EPA stove 1 year will be a exercise in futility
  7. Fanatical1
    Fanatical1
    Really nice looking wood.. Usually those would have been destined for a saw mill around here. White oak is pretty hot right now. That's a lot of wood your getting too.. :)
    Do you have forks on that 2320?
  8. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    You may want to check those splits with a moisture meter next fall. I don't think they will be ready to burn I'm a year.
  9. billb3
    If you can, put a bunch of that oak aside for an extra year or two to see how much more heat you get out of it.
    I know I was surprised the first time I tried it on recommendation of someone.
    I always stacked it with the cherry and maple.
    I started keeping it separate a long time ago for aging and seeing how much better and longer it burns saving it for the real cold nights in Jan/Feb. Right now it's all I have so I feel like I'm wasting it but you do what ya gotta do.
    Being in the marine environment where I am it sure seems to burn better after 3 years of aging. It's a long time to look at a stack of wood Same with red oak which I have a lot more of .
    Todd 2 and Backwoods Savage like this.
  10. sherwood
    sherwood
    Boy, quick read of that first post and I got "pelletize". :emb: What the heck???
    Palletize: first time I've seen that. Good word.
  11. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Great stuff man! I can't wait to have space like that someday. Those are some sweet looking logs and a very nice stacking system to go with it. Sweet!
  12. wood
    wood
    ia
    yes, backsaver fork assembly On front. Flat forks.
    I also have a three point rear set of forks so i haul two pallets at a time to walkout basement. Set on two rolling carts in basement. Works great.
    Backwoods Savage and fox9988 like this.
  13. wood
    wood
    ia
    Last year in july I split a bunch of red oak and stacked on pallets with some space between each piece. Alot of southeasterly wind and spacing around double stacks, and they burn great now.
  14. bogydave
    Premium wood !
    Looks like some may make good lumber :)
  15. Smokinpiney
    Smokinpiney
    "South" Jersey
    That's a nice load of white oak! :yes: Got some straight logs there
  16. splitoak
    splitoak
    jefferson co wv
    :sherlock:...
  17. Backwoods Savage
    Wish those logs were on our place!!! Congratulations.
