A few pics from today
Discussion in 'The Wood Pile' started by polarbear, Jan 26, 2015.
  1. polarbear
    polarbear
    s/e michigan
    Last Saturday I filled a 4'x7' and 4'x8' trailers with ash. Today I put the handle on my axe head to hookaroon then split one of the trailer loads. I only had a few hours to play. Last winter a friend came out for firewood and helped cut and split. I told him 18" rounds. He wanted 24"rounds for his fireplace and cut without discussing the change. Yup I got stuck with a face cord of 24" splits. I figured out if I loaded the log cart full I could cut the ends off to get my 18" splits. works perfect and much safer than any other method I tried. I can't wait to build my wood shed. I'm just putzing along this winter cutting a facecord here and there, good dead ash.
    Shawn Curry, Sam, HoneyFuzz and 11 others like this.
  2. HDRock
    What you got holding the wood on the dolly?
    Why you cutting wood on top of the splitter?
    I love the trailer man:thumbs: mine is similar I built the sides and a rear Gate ramp
    Sam and Backwoods Savage like this.
  3. polarbear
    polarbear
    s/e michigan
    HDRock I used 1"1/4" by 1/8" metal. I bent it and bolted it to the cart.
  4. concretegrazer
    concretegrazer
    Southwest MO
    That's slick!:yes:
    Horkn and polarbear like this.
  5. HDRock
    Now that's a cool idea right there I have never seen that one for recutting splits to length.
    Is that like metal banding material?
    Hey I got some of that out in the shop, I think it is three quarter or 1 inch wide heavy duty
  6. polarbear
    polarbear
    s/e michigan
    The trailer was $75 on craigslist and I'm 6'7". Dennis can vertical split all he wants. lol. I usually raise the splitter up a few inches to make it more comfortable for me. I still have enough back and upper body strength to lift the rounds out of trailer to splitter. But I have used it vertically. I don't like to bend over. Wears my back out fast.
    Sam, Todd 2, milleo and 4 others like this.
  7. polarbear
    polarbear
    s/e michigan
    HDRock the strapping is heavier than banding material. It is at least 1/8" or 3/16". Fairly rigid.
    Horkn and HDRock like this.
  8. HDRock
    welcome to the forum, sounds like you have been lurking here awhile:)
    I am 5 foot 3 so we might have a little bit different ways of doing things:D
  9. HDRock
    3/16 yeah that is heavier is there a way to cinch it down
  10. polarbear
    polarbear
    s/e michigan
    :DHDRock if your asking about cinching the load on the cart. No. I use it as you see in the pics.
    Yes I have been around. Pretty sure I was registered here before but lost the info. I know Dennis from years ago on a outdoor forum etc. I am polarbear elsewhere on the net. Lurking? lol. I reregistered when I had something useful to say. lol :)
    thewoodlands, milleo, Paula and 2 others like this.
  11. HDRock
    Can that be removed to function as a normal dolly ??
    I have had this dolly for 25-30 years and it has done a lot more than move firewood around.
    Chvymn99, Shawn Curry, milleo and 3 others like this.
  12. polarbear
    polarbear
    s/e michigan
    HDRock. It's bolted to the dolly with 5/16" nuts and bolts. I have other hand carts so no need to remove. Best advice is get solid tires. Will make a huge difference pulling a big load up the steps. My wife will load the cart and leave it at our front steps and I drag it in.
  13. HDRock
    I got slime tubes in the dolly, no steps on the back deck , bring my wood up in the buggy.
    Chvymn99, Sam, milleo and 3 others like this.
  14. HDRock
    I hope you didn't take offence to my comment :)
    wildwest and polarbear like this.
  15. polarbear
    polarbear
    s/e michigan
    HDRock. No offense my friend.
    wildwest and HDRock like this.
  16. Dascro
    Dascro
    Southwest PA
    I hear ya!! I'm 6"4" and do whatever I can to minimize repetitive bending. Still fit and strong enough to lift, just want to keep my back healthy.
  17. Backwoods Savage
    Hey Polar, I do remember you on the other forum.
    On that upper body strength and bending over, I can relate. Most folks are amazed at how much I can lift even though I have a terrible back. But if I have to bend, that is a different story altogether. My back just does not like bending and even though I can lift, I keep it to a minimum. (And I don't count sitting as bending over.)
    But what about splitting vertically? To keep from both lifting and bending. I can split for hours at a time with no problem. But, if I had to be on my feet, then I'm afraid I'd have to hire it done because I just could not do it.
    In addition, a lot of folks will go cut a load of wood and then split it right away. We don't. We sort of half way stack it up in the winter months and then after snow melt we get the splitter out and do all the splitting at once. When the splitter is put away, then we stack and stack it right where the wood is so we don't have to carry it. It works well for us.
    Shawn Curry, Sam, wildwest and 3 others like this.
  18. polarbear
    polarbear
    s/e michigan
    I have a twisted rib. I'm not sure what caused it. I think it's from being on a ladder and twisting and reaching while working. I have a very hard time bucking logs. The twisted rib will take my breath away. I was able to bend over and pick up these 2 loads of rounds without any twisted rib pain but running the saw bent over is terrible pain. That's about the worst it gets. It generally doesn't hurt while I work installing garage doors. I'm trying to figure out how to get logs up to saw horse height. No loader at this time.
    I like to fill the trailer/trailers with rounds and split them right out of the trailer. One less step handling the wood. Splitter is parked right at the stacks. Works well for us. My wife will stack while I split sometimes. It makes quick work of it.
    Backwoods Savage, Sam, Todd 2 and 3 others like this.
  19. Todd 2
    Todd 2
    :handshake: Welcome polar bear, I might just copy on that dolly, great idea but I don't think I'll paint mine pink.
    HDRock likes this.
  20. Paula
    Paula
    UK
    You'll always find anything pink. Good idea
    Todd 2 likes this.
