Any tips for making a clean bucking cut through a big log?
Discussion in 'Chainsaws and Power Equipment' started by dgeesaman, Jan 25, 2015.
  1. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Been working through some 40" logs using my 28" bar. I cut bar-deep as far as I can from one side, drive a wedge in top, then come down through the remaining wood on the opposite side. Trouble is, in many cases the lower part of the cuts twist a bit in opposite directions and don't line up any more. I hate ugly bucking cuts. Extra work and waste of wood. Chain is brand new.
    Is this just me twisting on the bar and causing it to run crooked, or is there another technique to fix my mistake?
    mdavlee and Dascro like this.
  2. jetjr
    jetjr
    Pa/Md line
    I wonder if a set of double dogs would help keep it straight?
    MightyWhitey, MasterMech and thistle like this.
  3. Dascro
    Dascro
    Southwest PA
    Nothing useful to offer but I'll be interested in the responses cause I have the same question/problem.
    jetjr likes this.
  4. RockyFordOak78
    RockyFordOak78
    Raleigh, NC
  5. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I have a set on the way actually. The standard dog on my 365 is short and when you get below the center of the log it's no good since the chain brake handle bumps the log first.
  6. mdavlee
    mdavlee
    I try to buck everything from one side if possible. Reach over the top as far as possible and then bring the saw back to you. If you're pushing on it it will go to one side a little more than the other. When you go to the opposite side the push is going the other way and they overlap or go away from each other.
    Oliver1655, $ooline, Sunfish and 11 others like this.
  7. thistle
    thistle
    Polk/Guthrie Counties,IA
    twin dogs definitely will help.really keeps cuts straighter when you power through the big ones
    $ooline and mdavlee like this.
  8. Gunn
    Gunn
    Plover, Wi
    On large logs I'll put my saw on top or the log or a little beyond the top and dog in. I start bucking the back side until I'm 1/3 to 1/2 way through. Then I pull the saw back over the top and cut through the rest. The kerf pretty much keeps everything lined up unless I torque the saw in the cut and the saw wanders.
  9. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
  10. angelo c
    angelo c
    People's Republic of North Jersey
    is it cutting straight to begin with ?
    maybe guide bar needs truing up?
    $ooline and fox9988 like this.
  11. dgeesaman
    dgeesaman
    Elizabethtown, PA
    The bar is basically new with about 6 tanks of use on it.
    It cuts nice and straight through the top and middle sections of the log. I'm leaning toward the idea I'm just twisting it.
  12. angelo c
    angelo c
    maybe let the boys have a look at the cutters on the chain next time yer out makin rounds.
    post up some cutterporn....
    or is it chainporn ?
  13. mdavlee
    mdavlee
    This right here is some crazy southeast Alaska bucking. Courtesy of Cody in MT.
  14. Gunn
    Gunn
    Plover, Wi
    Sweet mother of God
    $ooline, splitoak and mdavlee like this.
  15. Ralphie Boy
    Ralphie Boy
    Splane ta me what I sees that...
  16. mdavlee
    mdavlee
    He was bucking this tree
    $ooline, DexterDay, splitoak and 2 others like this.
  17. mdavlee
    mdavlee
    It was the best picture I could think of for reaching over the top to buck the far side first.
  18. maulhead
    maulhead
    Colorado
    I agree with what mdavlee said!!Try to do all the cutting from one side.
    Here is a visual, 28" bar, 40" maple, reach over the top of the log as far as you can, cut like the red line I drew on the pic or so, when you think you went far enough, pull the saw back towards you and cut straight down, stop before your in the dirt, roll log over and finish cut, you should end up with a clean cut, like my 2nd pic.
    That is the round off of the log in the 1st pic, nice clean straight cut,
    Oliver1655, $ooline, UncleJoe and 8 others like this.
  19. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I would have guessed he was simply staying on the uphill side for safety
    JustWood likes this.
  20. mdavlee
    mdavlee
    That too.
    $ooline likes this.
