Electric chainsaw sharpener
Discussion in 'Chainsaws and Power Equipment' started by Mathewsmatt, Jan 22, 2015.
  1. Mathewsmatt
    Mathewsmatt
    WV
    Hey everyone. I am wanting to buy an electric bench mount sharpener. Don't know a whole lot about them but I don't want to spend an arm and a leg but also want to get a quality sharpener that is user friendly. Any advice is much appreciated!!
    Chvymn99 and fox9988 like this.
  2. Woodchuck
    Woodchuck
    Southeastern Ohio
  3. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    1421981299199.jpg I don't know much about them either. I know this is a cheapo one but my sister in law got it for me. Did a fantastic job on my .325 chain. Not sure what it costs but it's intuitive and works well.
    One tip.. Mounting it directly to the bench was awkward. I'd recommend mounting it to a 2x4 like I did and placing it in a rotating vice.
    Shawn Curry, Sam, rottiman and 2 others like this.
  4. Woodrat1276
    Woodrat1276
    Ky
    I have a harbor freight sharpener. I've never used it in fact never even opened the box Christmas gift Id give it to you but it prob cost as much to send it as one is at the store.
    Chvymn99 likes this.
  5. Hellbent
    Hellbent
    North Central Kansas
    I have one of the Oregon ones, can't remember the model off the top of my head. It's freakin fantastic! It can do anything but square ground and is easy to operate. You're gonna hate me but I got it at an estate sale for $30 with 6 wheels. I think nobody really knew what it was. It is the same one that my local stihl guy and the echo guy have.
    I mounted it on a piece of angle iron and clamp it in a vise. Way more handy than on a bench.
    I have come to realize that in this game, quality is worth the money it saves you in time and headaches.
    One idea to help pay for it is to sharpen chains for people. If you did it for $5-7 you'd get guys all the time. Dealers around here charge $12 and the quality of the job is pretty poor. Of course not all places charge that or do crappy work.
    One thing I've noticed is my chains last a lot longer than before because I remove the minimal amount needed to get the job done. If the kid at the dealer does it he is just grinding however much to get it done fast.
  6. Lumber-Jack
    Lumber-Jack
    I've been using a hand held dremel type sharpener for 35 yearsnow. It may, or may not, be quite as accurate as the bench sharpeners, but for sure it's the quickest way I know how to sharpen a chain saw, and very handy in the field.
  7. Chvymn99
    I've got the Northern Tool (Rough Neck). I like it so far. You can catch them on sale for very reasonable. http://firewoodhoardersclub.com/forums/threads/nt-sharpener-on-sale-again.6806/
    MasterMech and Drvn4wood like this.
  8. Backwoods Savage
    I'm with Lumber-Jack. For years I filed by hand and was happy but then my hands and fingers started hurting more and more and I thought it was about time to get something else to sharpen with. I toyed with the idea of a bench grinder but then one day I was in the neighbor's woods when he was cutting. Actually I got there as he began to sharpen his chain. It was a dremel type tool. Then I talked to a couple more and finally went to the saw shop and bought one. Sharpening a chain has never been so easy and so fast. Don't have to remove the chain to sharpen and it takes less than 5 minutes from the time I set the saw on the atv then get out the sharpener. The last time I checked it was 4 minutes before I had the saw started again. Surely saves the hands. Also, I do not own more than one chain per saw so not a lot of dollars tied up in chains. When one wears out, then I get another one. In fact, earlier today I stopped at the saw shop and bought a new chain because there is not much left of the old one now.
  9. Shawn Curry
    Shawn Curry
    Western NY
    If you go the motorized route, especially on the cheap end, make sure you get one with the right size wheel for your chain. There are different sized wheels for different pitches of chain - .375, .325, just like there are different sized hand files.
    I started off with a cheap grinder, and it did a pretty good job. But you'll still need to touch up the rakers from time to time if you want to get back to 'like new' performance. So eventually I broke down and bought a hand file set, because I didn't have a flat file to do the rakers. So I gave hand filing a shot and I haven't looked back. Now I have a couple different chainsaws running different sized chains, and I'd need to get a real-thing expensive grinder with different wheels to sharpen all of them. But I'm cheap and I have the files so that's what I do. It takes a little practice but eventually you'll open up a brand new chain and wish it was a little sharper... :D
  10. Mathewsmatt
    Mathewsmatt
    WV
    Wow thank yall so much. I appreciate all the Input. Going to keep looking and hopefully get the chance to use a couple different ones and make my decision. Thanks again!
  11. Backwoods Savage
    Right on Shawn. With the dremel, I have 2 sized stones but it is very simple to switch them out. If I'm cutting a lot of small stuff I leave the small stone on but if cutting the large, then the large stone. On the large trees I'll use the small saw on limbs so will have to sharpen now and then but not as often and as stated, it is pretty simple to switch the stones.
    Shawn Curry and Mathewsmatt like this.
  12. unclefess
    unclefess Guest
    with the dremel do you hand file the rakers ?
  13. Woodrat1276
    Woodrat1276
    Ky
    I don't doubt the effectiveness of doing it with a dremal but I can see myself not getting the angle right or taking to much off one side am I overthinking it I might try it on a older chain
  14. Pallet Pete
    Pallet Pete Moderator
    Ovid
    In my experience having owned the HF model and now running 3 timber tuff sharpeners for my business I would buy the timber tuff hands down… The HF unit is good but takes a lot of time to use if you want a proper edge as it has a lot of side to side play. It also doesn't allow for raker adjustment.
    Many of us here use the timber tuff with exceptional results. You can find them online at or in most farm stores. Rural King, Tractor Supply, Farm and Home, Lowes and some Menards have them.
    It is also known as the Norther tool grinder at northerntool.com or the roughneck. All the same grinder and worth every penny!
    http://www.ruralking.com/bac-indust...BAdU2-Af3MEozS0c57XDlC8NQzKU5exPQYRoC0mzw_wcB
    http://www.northerntool.com/shop/tools/product_200624012_200624012
    HDRock and Chvymn99 like this.
  15. Pallet Pete
    Ovid
    I won't lie I tried one because your chains where so sharp and I just don't have the touch.:( I wish I did that would be handy!
  16. MasterMech
    Sounds like you are looking for the TimberTuff grinder that is so popular here. They go for about $100 give or take and can be found at your local TractorSupply, ordered online from Northern Tool or I'm sure there are even more options. Watch for coupons/sales and you can get a deal.
    This grinder is out there in a few different colors, all the same machine regardless of what name or paint is applied.
  17. Woodchuck
    Woodchuck
    Southeastern Ohio
    Question...Do any of the grinders maintain the rakers, or this a manual job?
    Pallet Pete likes this.
  18. Pallet Pete
    Ovid
    The only one that doesn't is the HF Unit. I have three timber tuffs set up. One is setup dedicated to rakers and it does a good job.
    HDRock likes this.
  19. redneckdan
    redneckdan
    Northern Minnesota
    I prefer my Oregon 511 for tooth work. I have a rough neck dedicated to raker duty. I use the grinder to reset things after 5 or so sharpenings.
    Hellbent and HDRock like this.
  20. Mathewsmatt
    Mathewsmatt
    WV
    Awesome thanks a lot. Sorry about putting this post in the wrong spot, that's my fault. I am pretty new to all this along with getting more into chainsaws and all the things that go with firewood cutting. I am on here trying to learn as much a possible and my wife is thinking my new found concentration is crazy LOL.
    MasterMech, Chvymn99 and Pallet Pete like this.
