I picked up two of these totes today
Discussion in 'The Wood Pile' started by Unicorn1, Jan 23, 2015.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    (2) totes without the plastic liners for $20 each.
  2. XXL
    XXL
    Ontario, Canada
    Nice score! The only issue I can see with these is getting the last few pieces out of the bottom. I think someone here modified one and added a door.
  3. Horkn
    Maybe an extended log tongs will help with getting the logs on the bottom? Nice way to keep wood stacked and ready.
  4. rdust
    rdust
    SE, Michigan
    Pretty sure it was Machria who added a door.
    Nice find, I've been wanting to buy some but so far can't find anyone who will sell them without the container. I'll deal with the container if I have to but would rather not have to mess with it. Great way to store the unstackables.
  5. Pyroholic
    Pyroholic
    mid michigan
    I took a hole saw and drilled a bunch (A BUNCH) of holes in the liner and sawzalled the top off it. Pallet underneath it and now you have two containers.
  6. swags
    swags Moderator
    We have a recycle center right down the road from us, so I used a saw and cut the plastic into manageable pieces and took it to the recycle center. Easy away to get rid of the plastic.
  7. XXL
    XXL
    Ontario, Canada
    A pickaroon might be a handy option to get those pieces out of the bottom...
  8. rottiman
    When it gets down to the last bottom pieces just flip it up on its side.....................
  9. SolarandWood
    SolarandWood
    Syracuse NY
    How much abuse do those things take? I'm considering a stack to garage strategy to cut out the current stop/stack at the woodshed step.
    swags likes this.
  10. Certified106
    Certified106
    In The Hills
    Those are awesome!
  11. Chvymn99
    Nice find! :thumbs:
  12. Unicorn1
    Unicorn1
    Amarillo, TX
    I'm going to try and stack the totes two high, these pieces are huge but will fit in the wood stove, won't be easy to remove.
    With smaller splits I might be able to pull through the frame holes.
    Backwoods Savage and Loon like this.
  13. Loon
    Loon
    North of the border
    Just cut a good sized hole in it Unicorn.;)
  14. oldspark
    oldspark
    NW Iowa
    Seams like a reasonable price for 20 bucks.
    Horkn and Backwoods Savage like this.
  15. chainsawsoldier
    chainsawsoldier
    NE Kansas
    I pick up the ibc totes from the ag chemical dealer in the area. The totes that are cracked or have broken valves they sell for $15. I pick up 2 every time I drive by when they are open.
  16. swags
    swags Moderator
    Pretty durable, but they arent all the same. Some are made with heavier wire then others. I know a few guys here build their own and stack them two high. One pallet on the bottom and two standing on end in a U shape will hold 1/3 cord and they are stackable.
  17. chainsawsoldier
    chainsawsoldier
    NE Kansas
  18. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I know if you clip the bottom corner of one that's full of liquid with a lift truck fork it makes a giant mess.. :D In some instances hazmat team has to be called in.. :D Not sure who would be dumb enough to make all of that happen.. :whistle::whistle:​
    Todd 2, Horkn, swags and 5 others like this.
  19. XXL
    XXL
    Ontario, Canada
    Horkn, Drvn4wood and fuelrod like this.
  20. Backwoods Savage
    That is a terrific buy at $20. Around here they go for $50
