Venting Thoughts
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by IHATEPROPANE, Jan 21, 2015.
  1. IHATEPROPANE
    IHATEPROPANE
    So I have a 55-TRPEP coming and I am still undecided on exactly where/how I want to vent the unit. Please share any thoughts, pros or cons for my potential options.
    Option 1: Vent goes straight out and up about 7 feet where I have an area of about 2 feet where I would meet the clearances for 1 foot minimum above a window and two feet below the a roof.
    Option 2: Same as option one except I go up then out.
    Option 3: Corner install, vent goes up about 10 feet to clear the roof line by at least the two feet required.
    Option 4: Straight up through the roof, Perhaps the most aesthetic, but i would definitely pay for this installation.
    Thoughts? Comments? Ideas?
    ivanhoe likes this.
  2. jtakeman
    I like option 3 first then maybe option 2. I like roof installs specially if house staining is a worry. But also more of a PITA to clean though. Cost is a major factor. If moneys tight? Go the root that makes money sense and is easiest/cheapest on materials. Up inside is less likely to soot up when low burning(IIRC you seem to burn on low a lot) than the out then up. Plus its easier down the road if you ever change stoves and the outlet height differs with the new stove.
    Keeping it simple(so you can clean) and the material dollars low will prolly be your winner!!
    ivanhoe and IHATEPROPANE like this.
  3. smoke show
    smoke show
    Pittsfield, Wi
    Love my vertical install, but like Jay said pita to clean.
    I vote up and out. :thumbs:
    ivanhoe, badbob, jtakeman and 2 others like this.
  4. wildwest
    Oh darn I thought this was for venting rants and complaining.
    ivanhoe, will711, badbob and 2 others like this.
  5. IHATEPROPANE
    IHATEPROPANE
    You can do that too. :thumbs:
    ivanhoe, wildwest and jtakeman like this.
  6. imacman
    imacman
    Denver, NC
    IMO, straight out and then up, with a cleanout T is the best overall. Easy to hook Leaf Blower to it, or run brush into horizontal & vert. runs.
    Of course, from a stove performance perspective, straight up is best.....eliminate any horizontal runs.
    ivanhoe, slvrblkk, will711 and 2 others like this.
  7. badbob
    badbob
    Up and out,less pipe outside will stay cleaner longer.Put a t at the top instead of a 90 and do not have to go outside to clean.
    ivanhoe, smoke show and IHATEPROPANE like this.
  8. imacman
    imacman
    Denver, NC
    True, but being outdoors helps with any sooty "mistakes" during cleaning.........I'd rather not have to clean the inside of the house if something happens. :headbang:
    ivanhoe, LongShot and IHATEPROPANE like this.
  9. will711
    will711
    Pocono Mts.
    I did # 1 and it works Great ,like Pete says all the crap is outside :)
  10. slvrblkk
    slvrblkk
    Northampton, PA
    IHP...are you going with 3" or 4"?
  11. slvrblkk
    slvrblkk
    Northampton, PA
    Oh...my $.02 is out then up......easy to LBM then....
    imacman, ivanhoe and IHATEPROPANE like this.
  12. ttdberg
    ttdberg Pellet Pig
    CT
    I like #1 as well, seems like the simplest and cleanest method. It also allows you to run a short OAK right out the same thimble along with the flue, no?
    imacman, ivanhoe and slvrblkk like this.
  13. IHATEPROPANE
    IHATEPROPANE
    3" for option 1 or 2. Option 3 May be better off with 4".
    ivanhoe likes this.
  14. slvrblkk
    slvrblkk
    Northampton, PA
    I run a 45...out 2 feet to a tee....up three feet to a cap....I guess your basic 3" corner install. I do have some rise in my 2' of horizontal section
  15. IHATEPROPANE
    IHATEPROPANE
    My corner install would have to go up past the roof on the outside. There is no way to get the clearances because of where the window and roof are. So I would a 45, tee, about 10 feet of vertical. I believe that would qualify for 4".
    ivanhoe likes this.
  16. slvrblkk
    slvrblkk
    Northampton, PA
    Would it be 2' of horizontal?
    ivanhoe likes this.
  17. IHATEPROPANE
    IHATEPROPANE
    Oh, missed that. But yes.
    ivanhoe likes this.
  18. slvrblkk
    slvrblkk
    Northampton, PA
    Looks like that route you would be borderline for 3".......hmmm
  19. slvrblkk
    slvrblkk
    Northampton, PA
    Which option would be your easiest?
    ivanhoe likes this.
  20. IHATEPROPANE
    IHATEPROPANE
    Yeah, it would depend on how high I actually need to go. But would probably err on the side of caution and go 4" regardless there. Most likely I will be doing option one or two. I have plenty of room to meet the above window(12"), beneath roof overhang requirements(24").
    ivanhoe likes this.
